Serviio 1.3 update - MediaBrowser not playing Audio in IE10
AvBeynum
Post Fri Aug 09, 2013 1:19 pm
Just upgraded from 1.21 pro to 1.3 pro. When using MediaBrowser in Internet Explorer 10 the Audio Player no longer pops up when selecting a file. I can drag a file to the playlist, but also when starting from there the player is not starting. I also tried Google Chrome and another computer, but still can not do...
Any suggestions?
Thx in advance,
A+
Post Fri Aug 09, 2013 5:00 pm
Re: Serviio 1.3 update - MediaBrowser not playing Audio in I
try to clean your browser cache
tnbruno
Post Fri Aug 09, 2013 5:30 pm
Tried clearing browser cache. Also tried running MediaBrowser via Firefox as well as Chrome and IE10. Not having any success. Same problems as OP.
Post Fri Aug 09, 2013 6:20 pm
Ok, there was a bug. I uploaded new release, so just download and reinstall 1.3 again.
tnbruno
Post Fri Aug 09, 2013 7:10 pm
Downloaded, reinstalled, rebooted. Cleared browser cache again to be safe. Made sure Adblock was disabled.
It seems to play some files. Other files the player will come on for a second, no music will play, and then close.
If you click on the file repeatedly it will eventually start playing.
IE10 seems to have a lot more trouble than the other two browsers. Had to update Java before it would work in IE, and still even with repeated clicks appears not to be functioning and playing songs. Although the player does pop-up for a second.
Post Fri Aug 09, 2013 9:58 pm
You sure the file size of the newly downloaded file is the correct one? (check the Download page on serviio.org)
AvBeynum
Post Sat Aug 10, 2013 2:40 pm
New release is working, big thx!
A+
mad3063
Post Sun Aug 11, 2013 8:53 pm
Hi
Running Serviio on CentOS release 6.4 (Final) I had the same problem with different browsers. Using the "New" Version solved it. TNX
