Most MP3 files not being added
steveUK
Post Sun Mar 24, 2013 9:19 pm
The only music that has been added to the library is from 0 - B (artist name). After that every file seems to have a parsing error with the Time metadata. Here is an example. Any ideas? It doesn't seem like parseInt() should be used for the Time field. I am using 1.2.1 and Java 6 Update 43. Thanks!
2013-03-24 16:00:00,823 WARN [LibraryAdditionsCheckerThread] Cannot add file 05 Lost Cause.mp3 because of an unexpected error. Message: For input string: "03:47"
java.lang.NumberFormatException: For input string: "03:47"
at java.lang.NumberFormatException.forInputString(Unknown Source)
at java.lang.Integer.parseInt(Unknown Source)
at java.lang.Integer.valueOf(Unknown Source)
at org.serviio.library.local.metadata.extractor.embedded.MP3ExtractionStrategy.extractMetadata(MP3ExtractionStrategy.java:78)
at org.serviio.library.local.metadata.extractor.embedded.EmbeddedMetadataExtractor.retrieveAudioMetadata(EmbeddedMetadataExtractor.java:191)
at org.serviio.library.local.metadata.extractor.embedded.EmbeddedMetadataExtractor.retrieveMetadata(EmbeddedMetadataExtractor.java:129)
at org.serviio.library.local.metadata.extractor.MetadataExtractor.extract(MetadataExtractor.java:47)
at org.serviio.library.local.LibraryManager.extractMetadata(LibraryManager.java:225)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.addNewMediaFile(LibraryAdditionsCheckerThread.java:178)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.searchForNewFiles(LibraryAdditionsCheckerThread.java:145)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.searchForNewFiles(LibraryAdditionsCheckerThread.java:134)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.run(LibraryAdditionsCheckerThread.java:83)
ffmpeg version 1.1.1 Copyright (c) 2000-2013 the FFmpeg developers
built on Feb 5 2013 21:59:54 with gcc 4.7.2 (GCC)
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-libass --enable-librtmp --enable-fontconfig --enable-libfreetype --enable-zlib --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-mingw32- --pkg-config=pkg-config
libavutil 52. 13.100 / 52. 13.100
libavcodec 54. 86.100 / 54. 86.100
libavformat 54. 59.106 / 54. 59.106
libavdevice 54. 3.102 / 54. 3.102
libavfilter 3. 32.100 / 3. 32.100
libswscale 2. 1.103 / 2. 1.103
[mp3 @ 014B5AE0] max_analyze_duration 5000000 reached at 5015510
[mp3 @ 014B5AE0] Estimating duration from bitrate, this may be inaccurate
Input #0, mp3, from 'D:\Media\SharedMusic\Beck\Sea Change\05 Lost Cause.mp3':
TSRC : USIR10211441
TOWN : MusicNet
TOFN : 934841_070.mp3
TIME : 03:47
encoded_by : MusicNet, Inc.
title : Lost Cause
track : 5
artist : Beck
copyright : (P) 2002 Interscope Geffen (A&M) Records A Divis
publisher : Universal Music Group
genre : Rock
album : Sea Change
album_artist : Beck
disc : 1
composer : Beck
date : 2002
Duration: 00:03:49.25, start: 0.000000, bitrate: 320 kb/s
Stream #0:0: Audio: mp3, 44100 Hz, stereo, s16p, 320 kb/s
Stream #0:1: Video: mjpeg, yuvj420p, 800x800 [SAR 72:72 DAR 1:1], 90k tbr, 90k tbn, 90k tbc
title :
comment : Cover (front)
Post Mon Mar 25, 2013 12:55 am
Re: Most MP3 files not being added
Could you send me the mp3 to my email address? It's failing on year extraction, it looks like the mp3 has duration stored in it. Not sure if it's allowed or the metadata is wrong, hopefully can get some more details from looking at the file.
daol
Post Wed Aug 07, 2013 4:36 am
Me too!
I am using 1.2.1 and Java 6 Update 43 in NAS4FREE.
at java.lang.Integer.valueOf(Integer.java:570)
2013-08-07 01:27:42,072 WARN [LibraryAdditionsCheckerThread] Cannot add file 14-nancy_sinatra-how_does_that_grab_you_darlin-ser.mp3 because of an unexpected error. Message: For input string: "2006-03-13"
java.lang.NumberFormatException: For input string: "2006-03-13"
at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65)
at java.lang.Integer.parseInt(Integer.java:481)
Regards.
ChrisArgyle
Post Fri Aug 09, 2013 1:37 am
This is being caused by the id3v2 "Year" field. If you clear the field (or just strip the id3v2 entirely) then Serviio will be able to scan the file.
Serviio v1.2.1 on a Synology DS213.
Edit: Here's the id3 tag editor I used for this fix http://www.id3tageditor.com/
Post Fri Aug 09, 2013 5:05 pm
1.3 fixes this
Users browsing this forum: Baidu [Spider] and 12 guests
