Poster for TV Shows
kissskoool
Post Fri Aug 09, 2013 3:15 am
Poster for TV Shows
I have a folder with TV shows in it named correctly.
Serviio finds all the episodes and seasons, but it doesn't show poster for the show.
I tried to put an image in the top parent folder, but serviio doesn't seem to see it.
Nothing is shown in MediaBrowser either.
So, is it possible to have a poster for TV shows ?
Thanks !
Post Fri Aug 09, 2013 5:04 pm
Re: Poster for TV Shows
do you mean the episode or the show (folder)?
kissskoool
Post Sat Aug 10, 2013 2:29 am
i mean the show and the season, not the episode.
For the episode, there are already the generated thumbnails.
But for this question, i also had some answer in my other topic : viewtopic.php?f=17&t=12153
Post Sat Aug 10, 2013 5:36 pm
Show should work (via thetvdb.com), but you need a renderer that supports thumbnails for folders.
Seasons don't have any thumbnails.
kissskoool
Post Tue Aug 13, 2013 1:27 pm
I've just upgraded my server to 1.3, and something changed about episodes thumbnails.
In the previous version episodes thumbnails were generated by ffmpeg, and now they are all the same, the tv show poster.
Is there a way to have the generated thumbnails like in the previous version ?
Post Tue Aug 13, 2013 2:37 pm
They will be the same only if there is a jpg file in the folder
kissskoool
Post Tue Aug 13, 2013 3:46 pm
You're right, it took the image already in the folder, and put it for all the episodes.
But it's strange, i deleted the jpg image in the serie folder, and the thumbnail for each episode doesn't change.
I cleared the browser cache.
How can i reset the images for the episodes ?
Post Tue Aug 13, 2013 4:31 pm
Click Refresh video metadata
