All thumbnails identical and wrong
pointer2null
Post Sat Aug 10, 2013 9:34 pm
Image says it all really....
Post Sat Aug 10, 2013 9:36 pm
Re: All thumbnails identical and wrong
Can't see anything on that image.... do you have a larger version?
pointer2null
Post Sat Aug 10, 2013 9:41 pm
Seems the forum didn't like the link...
ok try the url directly http://s56.photobucket.com/user/excessi ... sort=3&o=0
It should be public, else can email etc.
p.s forgot to say in original this is V1.2
Post Sun Aug 11, 2013 11:54 am
Are all these files in one folder? If yes, it's possible you have a folder.jpg (possibly hidden) or similar image file there, which is used instead of the proper embedded art.
pointer2null
Post Sun Aug 11, 2013 6:17 pm
Correct :D
There were a few image files in the dir. Cleaned them out and now we're back to normal.
Users browsing this forum: Baidu [Spider] and 13 guests
