WD Live TV Plus Subtitles Issue with 1.3 version
ivan787
Post Sat Aug 10, 2013 5:50 pm
Hi I had version 1.2.1 and i was having some issues trying to get the devices discoverd but everything worked fine after everything was detected now that i have updated to 1.3 the discovery has been improvement and also the refresh but none of the srt files are being detected when i play the videos o my wd tv live plus, it is just playing embebed subtitles not taking the srt files on the directory this is happening just with my wd tv live plus, when i try with my Samsung TV, everything works fine.
Im suing serviio 1.3 on a mountain lions macmini computer.
Any help will be appreciated.
Post Sat Aug 10, 2013 6:05 pm
Re: WD Live TV Plus Subtitles Issue with 1.3 version
Do you have the wdtv profile selected?
ivan787
Post Sat Aug 10, 2013 8:46 pm
yes, also tried generic profile and samsung one as the tv is working fine none is detecting srt files.
Post Sat Aug 10, 2013 9:37 pm
post detailed log of browsing to the file and playing it.
ivan787
Post Sat Aug 10, 2013 10:45 pm
I have attached the logs
Archive.zip
(96.11 KiB) Downloaded 392 times
ivan787
Post Sat Aug 10, 2013 10:51 pm
I think i forgot to upload the last log here it is
(210.37 KiB) Downloaded 462 times
Post Sun Aug 11, 2013 11:57 am
What is the file with subtitles?
ivan787
Post Sun Aug 11, 2013 4:54 pm
the.avengers.2012.1080p.bluray.dts.x264-publichd.mkv
This is what i found on log 2
2013-08-10 17:41:04,865 DEBUG [SubtitlesService] Found external subtitles file: the.avengers.2012.1080p.bluray.dts.x264-publichd.srt
2013-08-10 17:41:04,865 DEBUG [ResourceValuesBuilder] Softsubs for media item 271 found, will be server as a resource
Post Sun Aug 11, 2013 6:00 pm
Can you try to install 1.2.1 (possibly a different PC) to see if this files works with it? From the log it looks fine.
ivan787
Post Sun Aug 11, 2013 8:58 pm
don't have another computer, downloaded and installed 1.2.1 and the subtitles works again but i got the same problem that devices are not being recognized and takes like 10min which its solved for me on 1.3
Post Sun Aug 11, 2013 11:42 pm
Could you do this (first with 1.2.1 and then with 1.3)?
1. Install Intel UPnP tools (link in my signature)
2. run AV Media Controller (AVMC)
3. go to Serviio Console, find the IP address of the PC you're running the AVMC on and assign it WDTV Live profile
4. restart AVMC
5. Find Serviio server and browse to the file with subtitles.
6. Right-click -> properties
7. There should be a number of resources, one of them the subtitles file. Select it and post here the image with the resource's properties
I'll compare if there are any differences between the 2.
ivan787
Post Mon Aug 12, 2013 1:23 am
im sorry but how do you install the first step dont see an installer for osx i download the zip and under tools cant see either avmc
ivan787
Post Mon Aug 12, 2013 2:58 am
Was able to get a windows computer and do it.
on 1.3 there is no resource for the srt with 1.2.1 it is. attaching screens
fotos.zip
two photos attached
(209.93 KiB) Downloaded 401 times
Post Mon Aug 12, 2013 12:40 pm
Great, thanks. That's it. I'll investigate.
Post Mon Aug 12, 2013 5:45 pm
What if you remove this line from the WDTV profile and restart the service / pc?
ivan787
Post Mon Aug 12, 2013 8:11 pm
where is this line located? do you want me to perform this on the mac suppose with 1.3 and restart both service on 1.3 and the profile on the av media controller?
Post Mon Aug 12, 2013 8:32 pm
in profiles.xml http://www.serviio.org/index.php?option ... icle&id=16
On Mac, you have to right-click on Serviio.app and browse contents to find the file.
Then just try to play the file via wdtv
Post Tue Aug 13, 2013 3:49 pm
any news?
ivan787
Post Tue Aug 13, 2013 4:59 pm
we got a big storm here and i have been 2 days without electricity i will reply you as soon as i get it back with my findings
ivan787
Post Tue Aug 13, 2013 10:55 pm
line removed from profile.
On AV Media controller the resource for the srt is available, but on the device it just shows the embebed subtitles not the srt option.
FILES.zip
LOGS
(59.96 KiB) Downloaded 385 times
