problem with rss feeds
siriusblack
Post Mon Aug 12, 2013 10:59 am
Hi
just wondering if anyone can help me out please
Got a problem some Work some Dont
Here is my rss feeds which was working
working rss feed (Livefeedssportlivenet).txt
(65.88 KiB) Downloaded 511 times
working rss feed (DalyMotion).txt
(107.77 KiB) Downloaded 461 times
Here is my rss feeds which are not working
Hope this can help
Thanks really appreciate it
Beta Tester
Post Mon Aug 12, 2013 1:08 pm
Re: problem with rss feeds
So they work if you only have one or the other, but not together? Is that 100% reproducible?
I will try it at home.
siriusblack
Post Mon Aug 12, 2013 2:51 pm
No they both work at the same time
Only It seems to work now and then
the only thing is, If DailyMotion works the other rss feeds work
its a Strange one
The other thing is soon as I restart the laptop some of the rss feeds don't come back
even know there were just working
Thanks Zip
Beta Tester
Post Mon Aug 12, 2013 8:26 pm
It works for me...
I've added some more logging to try to see what happens when this fails.
siriusblack
Post Tue Aug 13, 2013 8:09 am
Zip
I installed the new beta and its still not working for me
Here is the log you asked for
log.txt
(133.21 KiB) Downloaded 441 times
When the rss feeds start to load up
I will send you the other log when they fail
Thanks appreciate it
Beta Tester
Users browsing this forum: No registered users and 58 guests
