server unreachable error with mkv sony 2009 W5500
jusefd
Post Mon Aug 12, 2013 9:43 pm
Hey guys... I've got this problem for a very long time...
Using 1.3
The problem is that alot of h264 movies wont play. If I try to play them, I get "server unreachable" error. Whilst I try to run other files (avi, even AVCHD/m2ts) they work perfectly...
I don't understand why...
please help me! =(
when I was using 1.2.1... the movies worked, but only audio would show... no image..
here's the mediainfo of a file that worked, and doesnt work.
!!!!!WORKS!!!!
Unique ID : 183361023634252560541362500259475812262 (0x89F20C7161C337BEB43EDCE7455EEFA6)
Complete name : P:\films\movies\Despicable Me.mkv
Format : Matroska
Format version : Version 2
File size : 4.37 GiB
Duration : 1h 34mn
Overall bit rate : 6 595 Kbps
Encoded date : UTC 2008-11-26 23:49:30
Writing application : mkvmerge v2.9.8 ('C'est le bon') built on Aug 21 2009 13:21:42
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 34mn
Bit rate : 5 085 Kbps
Width : 1 280 pixels
Height : 696 pixels
Display aspect ratio : 1.85:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.238
Stream size : 3.28 GiB (75%)
Writing library : x264 core 110 r1804 e89c4cf
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.20 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=5085 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Format : DTS
Mode : 16
Codec ID : A_DTS
Duration : 1h 34mn
Bit rate mode : Constant
Bit rate : 1 509 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1 023 MiB (23%)
Language : English
Default : Yes
Forced : No
!!!!DOESN'T WORK!!!!!
Unique ID : 240575116027461548756806416009366536567 (0xB4FD14FCD963598997157423CA4B0177)
Complete name : P:\films\movies\17 Again\17 Again.mkv
Format : Matroska
Duration : 1h 41mn
Overall bit rate : 6 142 Kbps
Encoded date : UTC 2009-07-08 12:18:32
Writing application : mkvmerge v2.9.5 ('Tu es le seul') built on Jun 7 2009 11:07:07
Format : AVC
Duration : 1h 41mn
Bit rate : 5 500 Kbps
Height : 536 pixels
Display aspect ratio : 2.40:1
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.334
Stream size : 3.83 GiB (88%)
Writing library : x264 core 67 r1173 f6d3166
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=5500 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 1h 41mn
Bit rate : 640 Kbps
Bit depth : 16 bits
Stream size : 467 MiB (10%)
Language : English
Default : Yes
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English
Default : No
Forced : No
Post Tue Aug 13, 2013 1:08 pm
Re: server unreachable error with mkv sony 2009 W5500
uncheck "Enable Extraction ...." on serviio console then save.
sysrage
Post Wed Aug 14, 2013 12:40 am
I'm willing to bet this is the exact same problem I'm encountering. You can either disable extraction of embedded subs or disable the burned-in subs. Both allow videos to start playing for me that would previously fail to play.
jusefd
Post Sun Sep 01, 2013 10:47 pm
Thanks so far man... Now it only plays the audio... and I have some weird fragments on the screen... same fragments as I would have in VLC but that would go away in a few seconds... not in the Bravia..
jusefd
Post Mon Sep 02, 2013 8:48 am
I already switched maxVBrate to 12000 but that didn't do anything.
Users browsing this forum: Google [Bot] and 4 guests
