(solved) How to upgrade to 1.3 from 1.2.1 on Ubuntu 12.04
• Page 1 of 1
Hi all, anybody can help me to upgrade at the 1.3 version? I don't want to crash my setup! The last time it was a little bit too messy for me.
Last edited by thenamelessthing on Tue Aug 13, 2013 3:00 pm, edited 1 time in total.
My Setup : BDT220 Panasonic Bluray player, TC-L55ET5 and TC-L42ET5 Panasonic TV. My home media server run Serviio 1.4.2 Pro under GNU/Linux Ubuntu 14.04 LTS server x64 and the hardware is Amd 1045t Phenom II X6, 6Gb DDR3 1333 mhz on SSD and data on soft raid 5 (3x1tb).
Re: How to upgrade to 1.3 from 1.2.1 on Ubuntu 12.04
Petr
Help translate Serviio
The update doesn't seem to work. I'm stock on the 1.2.1 version. I have no sound too after the upgrade!
I have follow the step below:
in my home directory I have do:
ps -ef | grep serviio
I see many serviio process.. so I stop serviio.
sudo /opt/serviio/serviio-1.x/bin/serviio.sh -stop
I doesn't see any serviio process
wget http://download.serviio.org/releases/se ... nux.tar.gz
tar -xvf serviio-1.3-linux.tar.gz
rm -R serviio-1.3/library
sudo cp -R serviio-1.3/* /opt/serviio/serviio-1.x/
I start serviio with /serviio.sh in /opt/serviio/serviio-1.x/bin
What I'm doing wrong??
Thanks you!
Thanks you!
first..look around this forum for a startup script for serviio for ubuntu. This will make it much easier to start/stop serviio service.
As for the upgrade, so far the problems that I usually face is the serviio DB. According to the tutorial, we can keep the DB in order for serviio to preserve configuration and scanned files. However, if I don't delete them, my serviio service will not start. I had to actually remove everything. That means sort of like fresh installation. Then it will work. Try that.
Also, check in your system logs. Usually /var/log/messages or /var/log/syslog or /opt/serviio/serviio-1.x/log/serviio.log
What is the problem you have after doing what you did?
Petr
No sound and servidroid always detect 1.2.1 version!
check serviio.jar in lib folder has really been overriden with the 1.3 version
Petr
Problem solved! I have deleted my library folder and copied the library folder from 1.3!
Re: (solved) How to upgrade to 1.3 from 1.2.1 on Ubuntu 12.0
library or lib?
Petr
library!
I have follow the step: http://www.serviio.org/support?id=21#q8
But I think this step is wrong.
For working I have to overwrite the library folder...
Overwrite all files in the current Serviio location with the new ones but keep folder library intact
But then you lose all your data, right?
Petr
Yes, but after a rescan Everything look fine..
but it's not upgrade then, it's a clean reinstall
Petr
• Page 1 of 1
Users browsing this forum: No registered users and 49 guests
