Detection - LN40C610
guysmiley
Post Fri Jan 21, 2011 12:47 am
I have a Samsung LN40C610 and I have a couple of questions re: detection.
First, if in the Serviio Console I specify to use the Renderer Profile for the Samsung TV C-Series, does it only use this profile for devices that it can't auto-detect? It appears to me that Samsung TVs can't be auto-detected using the default profiles. In other words, would my Sony Bravia TV and PS3 still use their respective profiles, or would every device use the Samsung TV C-Series profile?
Second, I would like to enable auto-detection for my LN40C610. Looking at the HTTP headers, the first time the TV "pings" Serviio, the User-Agent is set as "SEC_HHP_TV-40C610/1.0". However, in subsequent messages the User-Agent is "DLNADOC/1.50". Can I set up auto-detection using User-Agent? Alternatively, can I set up auto-detection based on the Host header field? I can set my TV to use a static IP address.
Thanks in advance.
Post Fri Jan 21, 2011 12:20 pm
Re: Detection - LN40C610
This should work in 0.5
