some problems with 1.3.1
cisop
Post Mon Aug 19, 2013 1:32 am
I installed Serviio 1.3.1 this morning. It seemed to work fine. The computer did not slowdown as it did with 1.3. I added the crackle plug-in to see how they worked. It started to pick up items almost immediately. It is now 9 in the evening and I have 30 pages (14 items per page) from crackle. I assumed there would be a limit but it just seems to keep going. The maximum number of feed items to return is set for 20. I now have over 400 hundred.
I do not know if that is what is causing the problem or not.
I have attached the log file up until the time I restarted the machine. If I can help with anymore info let me know.Hopefully there is something there that may shed some light on it.
My machine is pretty reliable. I often leave it running overnight or even for days at a time without a problem. It is an HP laptop running Vista.
thanks
pete
serviio.log.zip
(369.26 KiB) Downloaded 312 times
Post Mon Aug 19, 2013 3:44 am
Re: some problems with 1.3.1
You should post your crackle problem in the crackle plugin thread since it is not something that worked for you previously. You also need to post "DEBUG" logs and the link you are using to invoke crackle.
