Upnp DIAL service : for DIscovery And Launch
Post Wed Aug 21, 2013 7:01 am
For information...
I looked at the Upnp Device Capability of new Sony Bravia 2013 model and I saw some new services:
Already used or knowed:
urn:schemas-upnp-org:service:RenderingControl:1
urn:schemas-upnp-org:service:ConnectionManager:1
urn:schemas-upnp-org:service:AVTransport:1
         <service>
            <serviceType>urn:schemas-upnp-org:service:RenderingControl:1</serviceType>
            <serviceId>urn:upnp-org:serviceId:RenderingControl</serviceId>
            <SCPDURL>/RenderingControlSCPD.xml</SCPDURL>
            <controlURL>/upnp/control/RenderingControl</controlURL>
            <eventSubURL>/upnp/event/RenderingControl</eventSubURL>
         </service>
         <service>
            <serviceType>urn:schemas-upnp-org:service:ConnectionManager:1</serviceType>
            <serviceId>urn:upnp-org:serviceId:ConnectionManager</serviceId>
            <SCPDURL>/ConnectionManagerSCPD.xml</SCPDURL>
            <controlURL>/upnp/control/ConnectionManager</controlURL>
            <eventSubURL>/upnp/event/ConnectionManager</eventSubURL>
         </service>
         <service>
            <serviceType>urn:schemas-upnp-org:service:AVTransport:1</serviceType>
            <serviceId>urn:upnp-org:serviceId:AVTransport</serviceId>
            <SCPDURL>/AVTransportSCPD.xml</SCPDURL>
            <controlURL>/upnp/control/AVTransport</controlURL>
            <eventSubURL>/upnp/event/AVTransport</eventSubURL>
         </service>
         <service>
            <serviceType>urn:schemas-sony-com:service:IRCC:1</serviceType>
            <serviceId>urn:schemas-sony-com:serviceId:IRCC</serviceId>
            <SCPDURL>/IRCCSCPD.xml</SCPDURL>
            <controlURL>http://192.168.0.110/sony/IRCC</controlURL>
            <eventSubURL />
         </service>
Some new:
urn:dial-multiscreen-org:service:dial:1
urn:schemas-sony-com:service:ScalarWebAPI:1
         <service>
            <serviceType>urn:dial-multiscreen-org:service:dial:1</serviceType>
            <serviceId>urn:dial-multiscreen-org:serviceId:dial</serviceId>
            <SCPDURL>/DIALSCPD.xml</SCPDURL>
            <controlURL>/upnp/control/DIAL</controlURL>
            <eventSubURL />
         </service>
         <service>
            <serviceType>urn:schemas-sony-com:service:ScalarWebAPI:1</serviceType>
            <serviceId>urn:schemas-sony-com:serviceId:ScalarWebAPI</serviceId>
            <SCPDURL>/ScalarWebApiSCPD.xml</SCPDURL>
            <controlURL>/upnp/control/ScalarAPI</controlURL>
            <eventSubURL />
         </service>
I look at UPNP DIAL service (DIAL—for DIscovery And Launch—is a simple protocol that 2nd screen devices can use to discover and launch apps on 1st screen devices. )
and I wondered : For which purpose Serviio could use these functions? How Serviio could use these functions?
For Example :
With Chrome, which would make it possible to launch apps on your TV straight from your browser.
When you listen to music on the mobile and then when you get home you can easily just switch it to your speakers.
http://gigaom.com/2013/01/23/dial-open- ... ompetitor/
http://www.dial-multiscreen.org/home
http://www.w3.org/TR/discovery-api/
Zip, I don't know if you see some good new features to be added to serviio using this DIAL service.
thenamelessthing
Post Fri Sep 06, 2013 6:12 pm
Re: Upnp DIAL service : for DIscovery And Launch
How can I do this on my tv to know what function is available? Panasonic ET5...
Thanks you
My Setup : BDT220 Panasonic Bluray player, TC-L55ET5 and TC-L42ET5 Panasonic TV. My home media server run Serviio 1.4.2 Pro under GNU/Linux Ubuntu 14.04 LTS server x64 and the hardware is Amd 1045t Phenom II X6, 6Gb DDR3 1333 mhz on SSD and data on soft raid 5 (3x1tb).
Post Fri Sep 06, 2013 6:19 pm
use Intel Device spy tools --> get Device XML and check service list.
Return to General discussion
