1.3.x:WD Live unable to display jpegs using WD Live profile
ianch99
Post Thu Aug 22, 2013 9:51 am
Since upgrading to 1.3 (and then 1.3.1), my WD Live box (latest firmware) is unable to display (jpeg) image files when connecting to Serviio (running on Debian Squeeze) using the WD Live renderer profile. If I change the profile to Generic DNLA and re-connect, all is well and the images are displayed fine. Switch back to WD Live profile, you get an error message after a short delay ...
Any one else seen this problem?
Post Thu Aug 22, 2013 12:46 pm
Re: 1.3.x:WD Live unable to display jpegs using WD Live prof
Weird..
try to remove this from the profile
<ProtocolInfo>simple</ProtocolInfo>
ianch99
Post Thu Aug 22, 2013 5:38 pm
zip wrote:Weird..
Commented this line out from the WDTV Live profile, restarted Serviio and I can see the image files again :-) Thanks ...
Post Fri Aug 23, 2013 10:45 am
cool. Does everything else (audio/video) work still?
ianch99
Post Fri Aug 23, 2013 11:19 am
zip wrote:cool. Does everything else (audio/video) work still?
All seems ok: movies, picture & music ..
Users browsing this forum: Google [Bot] and 15 guests
