Serviio Pro v.1.3.1 breaks mkv on PS3?
Twitch_City
Post Wed Aug 21, 2013 10:12 pm
I am a happy Serviio Pro user, and have upgraded our server to the latest version. It streams from our iMac to our PS3 (which is set to the Playstation profile). However, I just noticed that mkv files that used to stream fine now give an error (the PS3 claims that "this file type is not supported"). I have restarted the PS3 and the Serviio server and the problem persists - even on files that I have streamed in the past. Other files still stream fine, so it seems localized to mkvs.
Is this a known issue? How can I help figure out what is going on?
Thanks!
edit: Here is the log from FFMPEG ( I really hope to get this working again soon, as you will notice from the log, we are trying to stream Adventure Time, which is one of my son's favourite shows)
Mumbles-iMac:MacOS Mumbles$ ./ffmpeg -i /Volumes/TheVault/HUXLEY\ SHOWS/Adventure\ Time/Season\ 5/Adventure.Time.S05E01-02.720p.hdtv.x264-2hd.mkv
  built on Jun 18 2013 11:47:55 with gcc 4.0.1 (GCC) (Apple Inc. build 5493)
  configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-libmp3lame --enable-librtmp --enable-libfreetype --enable-fontconfig --enable-libass --enable-pthreads --enable-libx264 --enable-gpl --disable-mmx --extra-ldflags=-L/Users/MacAdmin/Desktop/build/target/lib --extra-cflags=-I/Users/MacAdmin/Desktop/build/target/include --extra-libs='-lpolarssl -lfreetype -lexpat -liconv'
Input #0, matroska,webm, from '/Volumes/TheVault/HUXLEY SHOWS/Adventure Time/Season 5/Adventure.Time.S05E01-02.720p.hdtv.x264-2hd.mkv':
    creation_time   : 2012-11-13 01:08:29
  Duration: 00:22:28.58, start: 0.000000, bitrate: 2201 kb/s
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0:1: Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s (default)
And here is the output from MediaInfo:
Unique ID                                : 303327356341568762773558191425609104208 (0xE432B94E6E355A534D3EEB6B414D7B50)
Complete name                            : /Volumes/TheVault/HUXLEY SHOWS/Adventure Time/Season 5/Adventure.Time.S05E01-02.720p.hdtv.x264-2hd.mkv
File size                                : 354 MiB
Duration                                 : 22mn 28s
Overall bit rate                         : 2 201 Kbps
Encoded date                             : UTC 2012-11-13 01:08:29
Writing application                      : mkvmerge v2.7.0 ('Do It Again') built on Jul  2 2010 16:49:42
Writing library                          : libebml v0.7.7 + libmatroska v0.8.1
Format settings, ReFrames                : 5 frames
Duration                                 : 22mn 28s
Bit rate                                 : 1 710 Kbps
Bits/(Pixel*Frame)                       : 0.077
Stream size                              : 275 MiB (78%)
Writing library                          : x264 core 129 r2230 1cffe9f
Encoding settings                        : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Duration                                 : 22mn 28s
Bit rate                                 : 448 Kbps
Channel count                            : 6 channels
Stream size                              : 72.0 MiB (20%)
Post Thu Aug 22, 2013 12:51 pm
Re: Serviio Pro v.1.3.1 breaks mkv on PS3?
post detailed log of when playing the file
Twitch_City
Post Thu Aug 22, 2013 1:34 pm
Hi Zip,
Thanks for the reply. Here is the DEBUG log (I think only the relevant lines, but I'm not sure. The log files sure get huge with media information!)
I tried to play the first two files in the directory (E01-02, and E03). Both gave the "This data type is not supported" error on the PS3. I actually tested this on two different PS3s to make sure the problem wasn't on that end.
Here is the log:
2013-08-22 09:25:18,915 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 09:25:18,915 DEBUG [VideoDAOImpl] Reading a Video (id = 59233)
2013-08-22 09:25:18,915 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 59233 and profile Playstation 3
2013-08-22 09:25:18,915 DEBUG [MediaItemDAOImpl] Getting file of media item 59233
2013-08-22 09:25:18,916 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E31.720p.HDTV.x264-EVOLVE.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 09:25:18,916 DEBUG [MediaItemDAOImpl] Getting file of media item 59233
2013-08-22 09:25:18,916 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 5731 (filter: ALL) [No_Restriction]
2013-08-22 09:25:18,918 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2013-08-22 09:25:18,927 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-08-22 09:25:19,174 DEBUG [ServiioHttpService] Incoming request from /192.168.0.33:62682: POST /serviceControl HTTP/1.1, headers = [X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";,Host: 192.168.0.2:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 276,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"]]
2013-08-22 09:25:19,174 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.33
2013-08-22 09:25:19,174 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.0.33
2013-08-22 09:25:19,177 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-08-22 09:25:19,181 DEBUG [ServiioHttpService] Incoming request from /192.168.0.33:62681: POST /serviceControl HTTP/1.1, headers = [X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";,Host: 192.168.0.2:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 944,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2013-08-22 09:25:19,181 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.33
2013-08-22 09:25:19,181 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.33
2013-08-22 09:25:19,184 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = V_F^FOL_R7$F199$F5731, browseFlag = BrowseMetadata, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 0, count = 1, sortCriteria =
2013-08-22 09:25:19,184 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-08-22 09:25:19,184 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2013-08-22 09:25:19,186 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-08-22 09:25:23,190 DEBUG [ServiioHttpService] Incoming request from /192.168.0.33:62680: GET /resource/57188/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.0.2:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Streaming,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";,TimeSeekRange.dlna.org: npt=0.000-]]
2013-08-22 09:25:23,190 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.33
2013-08-22 09:25:23,191 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.33
2013-08-22 09:25:23,202 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.33, Profile=Playstation 3'
2013-08-22 09:25:23,203 DEBUG [ResourceDeliveryProcessor] Request for resource 57188 and type 'MEDIA_ITEM' received
2013-08-22 09:25:23,203 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 57188 (local)
2013-08-22 09:25:23,203 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 57188)
2013-08-22 09:25:23,209 DEBUG [VideoDAOImpl] Reading a Video (id = 57188)
2013-08-22 09:25:23,209 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 57188, format AVC_TS_MP_HD_AC3_ISO and profile Playstation 3
2013-08-22 09:25:23,209 DEBUG [MediaItemDAOImpl] Getting file of media item 57188
2013-08-22 09:25:23,210 DEBUG [MediaItemDAOImpl] Getting file of media item 57188
2013-08-22 09:25:23,210 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Adventure.Time.S05E01-02.720p.hdtv.x264-2hd.mkv
2013-08-22 09:25:23,211 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E01-02.720p.hdtv.x264-2hd.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 09:25:23,212 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 57188 (local)
2013-08-22 09:25:23,212 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 57188)
2013-08-22 09:25:23,212 DEBUG [VideoDAOImpl] Reading a Video (id = 57188)
2013-08-22 09:25:23,213 DEBUG [VideoDeliveryEngine] Delivering item '57188' for client 'Identifier=192.168.0.33, Profile=Playstation 3'
2013-08-22 09:25:23,213 DEBUG [MediaItemDAOImpl] Getting file of media item 57188
2013-08-22 09:25:23,213 DEBUG [VideoDeliveryEngine] Delivering file 'Adventure.Time.S05E01-02.720p.hdtv.x264-2hd.mkv' using transcoding
2013-08-22 09:25:23,214 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.0.33, Profile=Playstation 3'
2013-08-22 09:25:23,214 DEBUG [MediaItemDAOImpl] Getting file of media item 57188
2013-08-22 09:25:23,214 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: /Volumes/TheVault/HUXLEY SHOWS/Adventure Time/Season 5/Adventure.Time.S05E01-02.720p.hdtv.x264-2hd.mkv
2013-08-22 09:25:23,215 DEBUG [ProcessExecutor] Starting /Applications/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg -fflags +genpts -threads 2 -i /Volumes/TheVault/HUXLEY SHOWS/Adventure Time/Season 5/Adventure.Time.S05E01-02.720p.hdtv.x264-2hd.mkv -y -threads 2 -c:v copy -bsf:v h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts /var/folders/zn/38pkg9p56md4kdc0_spgvk5w0000gn/T/Serviio/transcoding-temp-57188-4-ORIGINAL.stf
2013-08-22 09:25:23,770 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2013-08-22 09:25:23,772 DEBUG [MediaItemDAOImpl] Getting file of media item 57188
2013-08-22 09:25:23,773 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E01-02.720p.hdtv.x264-2hd.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 09:25:23,773 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 57188) as read
2013-08-22 09:25:23,896 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-08-22 09:25:23,896 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-08-22 09:25:23,897 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-08-22 09:25:23,897 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Thu, 22 Aug 2013 13:25:23 GMT,Server: Mac OS X, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=0-1348/1348,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-08-22 09:25:24,502 DEBUG [WebServer] I/O error: Broken pipe
2013-08-22 09:25:31,534 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2013-08-22 09:25:34,971 DEBUG [ServiioHttpService] Incoming request from /192.168.0.33:62679: GET /resource/57189/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.0.2:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Streaming,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";,TimeSeekRange.dlna.org: npt=0.000-]]
2013-08-22 09:25:34,971 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.33
2013-08-22 09:25:34,972 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.33
2013-08-22 09:25:34,972 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.33, Profile=Playstation 3'
2013-08-22 09:25:34,972 DEBUG [ResourceDeliveryProcessor] Request for resource 57189 and type 'MEDIA_ITEM' received
2013-08-22 09:25:34,972 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 57189 (local)
2013-08-22 09:25:34,973 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 57189)
2013-08-22 09:25:34,973 DEBUG [VideoDAOImpl] Reading a Video (id = 57189)
2013-08-22 09:25:34,973 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 57189, format AVC_TS_MP_HD_AC3_ISO and profile Playstation 3
2013-08-22 09:25:34,973 DEBUG [MediaItemDAOImpl] Getting file of media item 57189
2013-08-22 09:25:34,974 DEBUG [MediaItemDAOImpl] Getting file of media item 57189
2013-08-22 09:25:34,974 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Adventure.Time.S05E03.720p.hdtv.x264-2hd.mkv
2013-08-22 09:25:34,975 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E03.720p.hdtv.x264-2hd.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 09:25:34,975 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 57189 (local)
2013-08-22 09:25:34,975 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 57189)
2013-08-22 09:25:34,975 DEBUG [VideoDAOImpl] Reading a Video (id = 57189)
2013-08-22 09:25:34,975 DEBUG [VideoDeliveryEngine] Delivering item '57189' for client 'Identifier=192.168.0.33, Profile=Playstation 3'
2013-08-22 09:25:34,975 DEBUG [MediaItemDAOImpl] Getting file of media item 57189
2013-08-22 09:25:34,976 DEBUG [MediaItemDAOImpl] Getting file of media item 57189
2013-08-22 09:25:34,976 DEBUG [VideoDeliveryEngine] Delivering file 'Adventure.Time.S05E03.720p.hdtv.x264-2hd.mkv' using transcoding
2013-08-22 09:25:34,977 DEBUG [AbstractTranscodingDeliveryEngine] No other client uses transcoding job of file 'transcoding-temp-57188-4-ORIGINAL.stf', will stop the job
2013-08-22 09:25:34,977 DEBUG [AbstractTranscodingDeliveryEngine] Stopping previous transcoding job of file 'transcoding-temp-57188-4-ORIGINAL.stf'
2013-08-22 09:25:35,010 DEBUG [TranscodingJobListener] Deleted temp file '/var/folders/zn/38pkg9p56md4kdc0_spgvk5w0000gn/T/Serviio/transcoding-temp-57188-4-ORIGINAL.stf': true
2013-08-22 09:25:35,011 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.0.33, Profile=Playstation 3'
2013-08-22 09:25:35,011 DEBUG [MediaItemDAOImpl] Getting file of media item 57189
2013-08-22 09:25:35,011 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: /Volumes/TheVault/HUXLEY SHOWS/Adventure Time/Season 5/Adventure.Time.S05E03.720p.hdtv.x264-2hd.mkv
2013-08-22 09:25:35,012 DEBUG [ProcessExecutor] Starting /Applications/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg -fflags +genpts -threads 2 -i /Volumes/TheVault/HUXLEY SHOWS/Adventure Time/Season 5/Adventure.Time.S05E03.720p.hdtv.x264-2hd.mkv -y -threads 2 -c:v copy -bsf:v h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts /var/folders/zn/38pkg9p56md4kdc0_spgvk5w0000gn/T/Serviio/transcoding-temp-57189-4-ORIGINAL.stf
2013-08-22 09:25:35,513 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2013-08-22 09:25:35,514 DEBUG [MediaItemDAOImpl] Getting file of media item 57189
2013-08-22 09:25:35,515 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E03.720p.hdtv.x264-2hd.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 09:25:35,515 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 57189) as read
2013-08-22 09:25:35,590 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-08-22 09:25:35,590 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-08-22 09:25:35,591 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-08-22 09:25:35,591 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Thu, 22 Aug 2013 13:25:35 GMT,Server: Mac OS X, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=0-670/670,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-08-22 09:25:36,279 DEBUG [WebServer] I/O error: Broken pipe
2013-08-22 09:25:36,940 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-08-22 09:25:36,941 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-08-22 09:25:41,592 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
Post Thu Aug 22, 2013 2:13 pm
Twitch_City wrote:However, I just noticed that mkv files that used to stream fine now give an error
What is your previous Serviio version ?
Post Thu Aug 22, 2013 2:19 pm
This is probably because on previous version, audio has been transcoded to AC3 with 384 kb/s and with latest serviio version the ac3 audio is remuxed with the original 448 kb/s bitrate. I don't know if the PS3 support this audio bitrate.
Twitch_City
Post Thu Aug 22, 2013 2:20 pm
Upgraded from 1.3.0, and was running 1.2.1 before that. Each upgrade I have backup the library folder within Serviio.app, deleted Serviio.app and Serviio-Console.app, installed the new version, and then replaced the blank library folder with my old one.
edit: Oh, that sounds promising! Any idea how I can fix that?
Post Thu Aug 22, 2013 2:30 pm
So if you try with 1.2.1 now (just add the one single file to the shared library to make it a fast test) it works?
Twitch_City
Post Thu Aug 22, 2013 3:18 pm
Unfortunately, reverting to 1.2.1 now gives the same problem (we have watched these files many times, so I'm really surprised about this).
Here is the complete log from the 1.2.1 install. I simply added the folder and tried streaming the first two files.
2013-08-22 10:58:40,000 DEBUG [ServiioHttpService] Incoming request from /192.168.0.33:57101: POST /serviceControl HTTP/1.1, headers = [X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";,Host: 192.168.0.2:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 940,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2013-08-22 10:58:40,000 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.33
2013-08-22 10:58:40,001 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.33
2013-08-22 10:58:40,001 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.33
2013-08-22 10:58:40,004 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = V_F^FOL_R1, browseFlag = BrowseDirectChildren, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 0, count = 10, sortCriteria =
2013-08-22 10:58:40,004 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-08-22 10:58:40,005 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder null [No_Restriction]
2013-08-22 10:58:40,019 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 1 (from=0, count=10) [No_Restriction]
2013-08-22 10:58:40,055 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2013-08-22 10:58:40,066 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,071 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2013-08-22 10:58:40,085 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1 and profile Playstation 3
2013-08-22 10:58:40,088 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E01-02.720p.hdtv.x264-2hd.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,089 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2013-08-22 10:58:40,090 DEBUG [MediaItemDAOImpl] Getting file of media item 2
2013-08-22 10:58:40,091 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,091 DEBUG [VideoDAOImpl] Reading a Video (id = 2)
2013-08-22 10:58:40,092 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 2 and profile Playstation 3
2013-08-22 10:58:40,092 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E03.720p.hdtv.x264-2hd.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,092 DEBUG [MediaItemDAOImpl] Getting file of media item 2
2013-08-22 10:58:40,093 DEBUG [MediaItemDAOImpl] Getting file of media item 3
2013-08-22 10:58:40,094 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,094 DEBUG [VideoDAOImpl] Reading a Video (id = 3)
2013-08-22 10:58:40,094 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 3 and profile Playstation 3
2013-08-22 10:58:40,095 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E04.720p.hdtv.x264-2hd.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,095 DEBUG [MediaItemDAOImpl] Getting file of media item 3
2013-08-22 10:58:40,096 DEBUG [MediaItemDAOImpl] Getting file of media item 4
2013-08-22 10:58:40,096 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,097 DEBUG [VideoDAOImpl] Reading a Video (id = 4)
2013-08-22 10:58:40,097 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 4 and profile Playstation 3
2013-08-22 10:58:40,098 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E05.720p.hdtv.x264-2hd.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,098 DEBUG [MediaItemDAOImpl] Getting file of media item 4
2013-08-22 10:58:40,099 DEBUG [MediaItemDAOImpl] Getting file of media item 5
2013-08-22 10:58:40,099 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,100 DEBUG [VideoDAOImpl] Reading a Video (id = 5)
2013-08-22 10:58:40,100 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 5 and profile Playstation 3
2013-08-22 10:58:40,101 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E06.720p.hdtv.x264-2hd.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,101 DEBUG [MediaItemDAOImpl] Getting file of media item 5
2013-08-22 10:58:40,102 DEBUG [MediaItemDAOImpl] Getting file of media item 6
2013-08-22 10:58:40,102 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,103 DEBUG [VideoDAOImpl] Reading a Video (id = 6)
2013-08-22 10:58:40,103 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 6 and profile Playstation 3
2013-08-22 10:58:40,104 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E07.720p.hdtv.x264-sys.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,104 DEBUG [MediaItemDAOImpl] Getting file of media item 6
2013-08-22 10:58:40,105 DEBUG [MediaItemDAOImpl] Getting file of media item 7
2013-08-22 10:58:40,105 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,106 DEBUG [VideoDAOImpl] Reading a Video (id = 7)
2013-08-22 10:58:40,106 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 7 and profile Playstation 3
2013-08-22 10:58:40,107 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E08.720p.hdtv.x264-2hd.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,107 DEBUG [MediaItemDAOImpl] Getting file of media item 7
2013-08-22 10:58:40,107 DEBUG [MediaItemDAOImpl] Getting file of media item 8
2013-08-22 10:58:40,108 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,108 DEBUG [VideoDAOImpl] Reading a Video (id = 8)
2013-08-22 10:58:40,109 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 8 and profile Playstation 3
2013-08-22 10:58:40,109 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E09.720p.hdtv.x264-2hd.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,110 DEBUG [MediaItemDAOImpl] Getting file of media item 8
2013-08-22 10:58:40,111 DEBUG [MediaItemDAOImpl] Getting file of media item 9
2013-08-22 10:58:40,111 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,112 DEBUG [VideoDAOImpl] Reading a Video (id = 9)
2013-08-22 10:58:40,112 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 9 and profile Playstation 3
2013-08-22 10:58:40,113 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E10.720p.hdtv.x264-2hd.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,113 DEBUG [MediaItemDAOImpl] Getting file of media item 9
2013-08-22 10:58:40,114 DEBUG [MediaItemDAOImpl] Getting file of media item 10
2013-08-22 10:58:40,114 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,115 DEBUG [VideoDAOImpl] Reading a Video (id = 10)
2013-08-22 10:58:40,115 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 10 and profile Playstation 3
2013-08-22 10:58:40,116 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E11.720p.hdtv.x264-2hd.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,116 DEBUG [MediaItemDAOImpl] Getting file of media item 10
2013-08-22 10:58:40,117 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root' (filter: ALL) [No_Restriction]
2013-08-22 10:58:40,120 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2013-08-22 10:58:40,142 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-08-22 10:58:40,462 DEBUG [ServiioHttpService] Incoming request from /192.168.0.33:57100: POST /serviceControl HTTP/1.1, headers = [X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";,Host: 192.168.0.2:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 941,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2013-08-22 10:58:40,462 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.33
2013-08-22 10:58:40,463 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.33
2013-08-22 10:58:40,463 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.33
2013-08-22 10:58:40,466 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = V_F^FOL_R1, browseFlag = BrowseDirectChildren, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 10, count = 10, sortCriteria =
2013-08-22 10:58:40,466 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-08-22 10:58:40,467 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder null [No_Restriction]
2013-08-22 10:58:40,467 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 1 (from=10, count=10) [No_Restriction]
2013-08-22 10:58:40,502 DEBUG [MediaItemDAOImpl] Getting file of media item 11
2013-08-22 10:58:40,502 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,503 DEBUG [VideoDAOImpl] Reading a Video (id = 11)
2013-08-22 10:58:40,503 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 11 and profile Playstation 3
2013-08-22 10:58:40,504 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E12.720p.hdtv.x264-orenji.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,504 DEBUG [MediaItemDAOImpl] Getting file of media item 11
2013-08-22 10:58:40,505 DEBUG [MediaItemDAOImpl] Getting file of media item 12
2013-08-22 10:58:40,505 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,505 DEBUG [VideoDAOImpl] Reading a Video (id = 12)
2013-08-22 10:58:40,506 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 12 and profile Playstation 3
2013-08-22 10:58:40,506 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E13.720p.hdtv.x264-orenji.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,507 DEBUG [MediaItemDAOImpl] Getting file of media item 12
2013-08-22 10:58:40,507 DEBUG [MediaItemDAOImpl] Getting file of media item 13
2013-08-22 10:58:40,508 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,508 DEBUG [VideoDAOImpl] Reading a Video (id = 13)
2013-08-22 10:58:40,509 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 13 and profile Playstation 3
2013-08-22 10:58:40,509 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E14.720p.hdtv.x264-2hd.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,509 DEBUG [MediaItemDAOImpl] Getting file of media item 13
2013-08-22 10:58:40,510 DEBUG [MediaItemDAOImpl] Getting file of media item 14
2013-08-22 10:58:40,510 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,510 DEBUG [VideoDAOImpl] Reading a Video (id = 14)
2013-08-22 10:58:40,511 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 14 and profile Playstation 3
2013-08-22 10:58:40,511 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E15.720p.hdtv.x264-orenji.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,512 DEBUG [MediaItemDAOImpl] Getting file of media item 14
2013-08-22 10:58:40,512 DEBUG [MediaItemDAOImpl] Getting file of media item 15
2013-08-22 10:58:40,513 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,513 DEBUG [VideoDAOImpl] Reading a Video (id = 15)
2013-08-22 10:58:40,514 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 15 and profile Playstation 3
2013-08-22 10:58:40,514 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E16.720p.hdtv.x264-2hd.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,514 DEBUG [MediaItemDAOImpl] Getting file of media item 15
2013-08-22 10:58:40,515 DEBUG [MediaItemDAOImpl] Getting file of media item 16
2013-08-22 10:58:40,515 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,516 DEBUG [VideoDAOImpl] Reading a Video (id = 16)
2013-08-22 10:58:40,517 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 16 and profile Playstation 3
2013-08-22 10:58:40,517 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E17.720p.HDTV.x264-EVOLVE.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,517 DEBUG [MediaItemDAOImpl] Getting file of media item 16
2013-08-22 10:58:40,518 DEBUG [MediaItemDAOImpl] Getting file of media item 17
2013-08-22 10:58:40,519 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,519 DEBUG [VideoDAOImpl] Reading a Video (id = 17)
2013-08-22 10:58:40,519 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 17 and profile Playstation 3
2013-08-22 10:58:40,520 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E18.proper.720p.hdtv.x264-2hd.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,520 DEBUG [MediaItemDAOImpl] Getting file of media item 17
2013-08-22 10:58:40,521 DEBUG [MediaItemDAOImpl] Getting file of media item 18
2013-08-22 10:58:40,521 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,522 DEBUG [VideoDAOImpl] Reading a Video (id = 18)
2013-08-22 10:58:40,522 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 18 and profile Playstation 3
2013-08-22 10:58:40,523 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E19.720p.HDTV.x264-EVOLVE.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,523 DEBUG [MediaItemDAOImpl] Getting file of media item 18
2013-08-22 10:58:40,527 DEBUG [MediaItemDAOImpl] Getting file of media item 19
2013-08-22 10:58:40,528 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,528 DEBUG [VideoDAOImpl] Reading a Video (id = 19)
2013-08-22 10:58:40,529 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 19 and profile Playstation 3
2013-08-22 10:58:40,529 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E20.720p.hdtv.x264-orenji.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,530 DEBUG [MediaItemDAOImpl] Getting file of media item 19
2013-08-22 10:58:40,530 DEBUG [MediaItemDAOImpl] Getting file of media item 20
2013-08-22 10:58:40,535 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,535 DEBUG [VideoDAOImpl] Reading a Video (id = 20)
2013-08-22 10:58:40,536 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 20 and profile Playstation 3
2013-08-22 10:58:40,536 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E21.720p.HDTV.x264-EVOLVE.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,536 DEBUG [MediaItemDAOImpl] Getting file of media item 20
2013-08-22 10:58:40,537 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root' (filter: ALL) [No_Restriction]
2013-08-22 10:58:40,540 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2013-08-22 10:58:40,563 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-08-22 10:58:40,802 DEBUG [ServiioHttpService] Incoming request from /192.168.0.33:57099: POST /serviceControl HTTP/1.1, headers = [X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";,Host: 192.168.0.2:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 941,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2013-08-22 10:58:40,803 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.33
2013-08-22 10:58:40,803 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.33
2013-08-22 10:58:40,806 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = V_F^FOL_R1, browseFlag = BrowseDirectChildren, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 20, count = 10, sortCriteria =
2013-08-22 10:58:40,806 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-08-22 10:58:40,807 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder null [No_Restriction]
2013-08-22 10:58:40,808 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 1 (from=20, count=10) [No_Restriction]
2013-08-22 10:58:40,840 DEBUG [MediaItemDAOImpl] Getting file of media item 21
2013-08-22 10:58:40,840 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,840 DEBUG [VideoDAOImpl] Reading a Video (id = 21)
2013-08-22 10:58:40,841 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 21 and profile Playstation 3
2013-08-22 10:58:40,841 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E22.720p.HDTV.x264-EVOLVE.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,842 DEBUG [MediaItemDAOImpl] Getting file of media item 21
2013-08-22 10:58:40,842 DEBUG [MediaItemDAOImpl] Getting file of media item 22
2013-08-22 10:58:40,843 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,843 DEBUG [VideoDAOImpl] Reading a Video (id = 22)
2013-08-22 10:58:40,843 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 22 and profile Playstation 3
2013-08-22 10:58:40,844 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E23.720p.HDTV.x264-EVOLVE.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,844 DEBUG [MediaItemDAOImpl] Getting file of media item 22
2013-08-22 10:58:40,844 DEBUG [MediaItemDAOImpl] Getting file of media item 23
2013-08-22 10:58:40,845 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,845 DEBUG [VideoDAOImpl] Reading a Video (id = 23)
2013-08-22 10:58:40,846 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 23 and profile Playstation 3
2013-08-22 10:58:40,846 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E24.720p.HDTV.x264-EVOLVE.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,846 DEBUG [MediaItemDAOImpl] Getting file of media item 23
2013-08-22 10:58:40,847 DEBUG [MediaItemDAOImpl] Getting file of media item 24
2013-08-22 10:58:40,847 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,848 DEBUG [VideoDAOImpl] Reading a Video (id = 24)
2013-08-22 10:58:40,848 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 24 and profile Playstation 3
2013-08-22 10:58:40,849 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E25.720p.HDTV.x264-EVOLVE.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,849 DEBUG [MediaItemDAOImpl] Getting file of media item 24
2013-08-22 10:58:40,849 DEBUG [MediaItemDAOImpl] Getting file of media item 25
2013-08-22 10:58:40,850 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,850 DEBUG [VideoDAOImpl] Reading a Video (id = 25)
2013-08-22 10:58:40,851 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 25 and profile Playstation 3
2013-08-22 10:58:40,851 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E26.720p.HDTV.x264-EVOLVE.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,851 DEBUG [MediaItemDAOImpl] Getting file of media item 25
2013-08-22 10:58:40,852 DEBUG [MediaItemDAOImpl] Getting file of media item 26
2013-08-22 10:58:40,852 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,852 DEBUG [VideoDAOImpl] Reading a Video (id = 26)
2013-08-22 10:58:40,853 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 26 and profile Playstation 3
2013-08-22 10:58:40,853 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E27.720p.hdtv.x264-w4f.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,854 DEBUG [MediaItemDAOImpl] Getting file of media item 26
2013-08-22 10:58:40,854 DEBUG [MediaItemDAOImpl] Getting file of media item 27
2013-08-22 10:58:40,855 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,855 DEBUG [VideoDAOImpl] Reading a Video (id = 27)
2013-08-22 10:58:40,856 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 27 and profile Playstation 3
2013-08-22 10:58:40,856 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E28.720p.HDTV.x264-EVOLVE.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,856 DEBUG [MediaItemDAOImpl] Getting file of media item 27
2013-08-22 10:58:40,857 DEBUG [MediaItemDAOImpl] Getting file of media item 28
2013-08-22 10:58:40,857 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,857 DEBUG [VideoDAOImpl] Reading a Video (id = 28)
2013-08-22 10:58:40,858 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 28 and profile Playstation 3
2013-08-22 10:58:40,858 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file adventure.time.s05e29.720p.hdtv.x264-w4f.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,858 DEBUG [MediaItemDAOImpl] Getting file of media item 28
2013-08-22 10:58:40,859 DEBUG [MediaItemDAOImpl] Getting file of media item 29
2013-08-22 10:58:40,859 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,860 DEBUG [VideoDAOImpl] Reading a Video (id = 29)
2013-08-22 10:58:40,860 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 29 and profile Playstation 3
2013-08-22 10:58:40,861 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E30.720p.HDTV.x264-EVOLVE.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,861 DEBUG [MediaItemDAOImpl] Getting file of media item 29
2013-08-22 10:58:40,861 DEBUG [MediaItemDAOImpl] Getting file of media item 30
2013-08-22 10:58:40,862 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-08-22 10:58:40,862 DEBUG [VideoDAOImpl] Reading a Video (id = 30)
2013-08-22 10:58:40,863 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 30 and profile Playstation 3
2013-08-22 10:58:40,863 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E31.720p.HDTV.x264-EVOLVE.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:40,863 DEBUG [MediaItemDAOImpl] Getting file of media item 30
2013-08-22 10:58:40,864 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root' (filter: ALL) [No_Restriction]
2013-08-22 10:58:40,867 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2013-08-22 10:58:40,878 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-08-22 10:58:41,131 DEBUG [ServiioHttpService] Incoming request from /192.168.0.33:57098: POST /serviceControl HTTP/1.1, headers = [X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";,Host: 192.168.0.2:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 276,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"]]
2013-08-22 10:58:41,131 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.33
2013-08-22 10:58:41,132 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.0.33
2013-08-22 10:58:41,132 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.33
2013-08-22 10:58:41,135 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-08-22 10:58:41,138 DEBUG [ServiioHttpService] Incoming request from /192.168.0.33:57097: POST /serviceControl HTTP/1.1, headers = [X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";,Host: 192.168.0.2:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 933,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2013-08-22 10:58:41,138 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.33
2013-08-22 10:58:41,139 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.33
2013-08-22 10:58:41,139 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.33
2013-08-22 10:58:41,142 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = V_F^FOL_R1, browseFlag = BrowseMetadata, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 0, count = 1, sortCriteria =
2013-08-22 10:58:41,142 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-08-22 10:58:41,142 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2013-08-22 10:58:41,144 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-08-22 10:58:42,732 DEBUG [DiscoveryAdvertisementNotifier] Problem during DiscoveryAdvertisementNotifier, will try again
java.net.SocketException: Can't assign requested address
   at java.net.PlainDatagramSocketImpl.socketNativeSetOption(Native Method)
   at java.net.PlainDatagramSocketImpl.socketSetOption(PlainDatagramSocketImpl.java:412)
   at java.net.PlainDatagramSocketImpl.setOption(PlainDatagramSocketImpl.java:352)
   at java.net.MulticastSocket.setNetworkInterface(MulticastSocket.java:536)
   at org.serviio.util.MultiCastUtils.startMultiCastSocketForSending(MultiCastUtils.java:56)
   at org.serviio.upnp.discovery.DiscoveryAdvertisementNotifier.sendAliveToSingleInterface(DiscoveryAdvertisementNotifier.java:169)
   at org.serviio.upnp.discovery.DiscoveryAdvertisementNotifier.sendAlive(DiscoveryAdvertisementNotifier.java:134)
   at org.serviio.upnp.discovery.DiscoveryAdvertisementNotifier.run(DiscoveryAdvertisementNotifier.java:94)
   at java.lang.Thread.run(Thread.java:680)
2013-08-22 10:58:42,733 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2013-08-22 10:58:44,129 DEBUG [ServiioHttpService] Incoming request from /192.168.0.33:57096: GET /resource/1/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.0.2:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Streaming,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";,TimeSeekRange.dlna.org: npt=0.000-]]
2013-08-22 10:58:44,129 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.33
2013-08-22 10:58:44,130 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.33
2013-08-22 10:58:44,135 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.33, Profile=Playstation 3'
2013-08-22 10:58:44,136 DEBUG [ResourceDeliveryProcessor] Request for resource 1 and type 'MEDIA_ITEM' received
2013-08-22 10:58:44,136 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1 (local)
2013-08-22 10:58:44,136 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2013-08-22 10:58:44,146 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2013-08-22 10:58:44,147 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1, format AVC_TS_MP_HD_AC3_ISO and profile Playstation 3
2013-08-22 10:58:44,147 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Adventure.Time.S05E01-02.720p.hdtv.x264-2hd.mkv
2013-08-22 10:58:44,148 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E01-02.720p.hdtv.x264-2hd.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:44,150 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1 (local)
2013-08-22 10:58:44,150 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2013-08-22 10:58:44,150 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2013-08-22 10:58:44,151 DEBUG [VideoDeliveryEngine] Delivering item '1' for client 'Identifier=192.168.0.33, Profile=Playstation 3'
2013-08-22 10:58:44,151 DEBUG [VideoDeliveryEngine] Delivering file 'Adventure.Time.S05E01-02.720p.hdtv.x264-2hd.mkv' using transcoding
2013-08-22 10:58:44,151 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.0.33, Profile=Playstation 3'
2013-08-22 10:58:44,152 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2013-08-22 10:58:44,152 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: /Volumes/TheVault/HUXLEY SHOWS/Adventure Time/Season 5/Adventure.Time.S05E01-02.720p.hdtv.x264-2hd.mkv
2013-08-22 10:58:44,152 DEBUG [ProcessExecutor] Starting /Applications/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg -fflags +genpts -threads auto -i /Volumes/TheVault/HUXLEY SHOWS/Adventure Time/Season 5/Adventure.Time.S05E01-02.720p.hdtv.x264-2hd.mkv -y -c:v copy -bsf:v h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts /var/folders/zn/38pkg9p56md4kdc0_spgvk5w0000gn/T/Serviio/transcoding-temp-1-4-ORIGINAL.stf
2013-08-22 10:58:44,654 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2013-08-22 10:58:44,655 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E01-02.720p.hdtv.x264-2hd.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:44,656 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1) as read
2013-08-22 10:58:44,667 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-08-22 10:58:44,667 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-08-22 10:58:44,668 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-08-22 10:58:44,668 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Thu, 22 Aug 2013 14:58:44 GMT,Server: Mac OS X, UPnP/1.0 DLNADOC/1.50, Serviio/1.2.1,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=0-1348/1348,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-08-22 10:58:45,241 DEBUG [WebServer] I/O error: Broken pipe
2013-08-22 10:58:47,734 DEBUG [DiscoveryAdvertisementNotifier] Problem during DiscoveryAdvertisementNotifier, will try again
2013-08-22 10:58:47,735 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2013-08-22 10:58:52,736 DEBUG [DiscoveryAdvertisementNotifier] Problem during DiscoveryAdvertisementNotifier, will try again
2013-08-22 10:58:52,737 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2013-08-22 10:58:53,256 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2013-08-22 10:58:54,791 DEBUG [ServiioHttpService] Incoming request from /192.168.0.33:57095: GET /resource/2/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.0.2:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Streaming,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";,TimeSeekRange.dlna.org: npt=0.000-]]
2013-08-22 10:58:54,792 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.33
2013-08-22 10:58:54,793 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.33
2013-08-22 10:58:54,793 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.33, Profile=Playstation 3'
2013-08-22 10:58:54,794 DEBUG [ResourceDeliveryProcessor] Request for resource 2 and type 'MEDIA_ITEM' received
2013-08-22 10:58:54,794 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2 (local)
2013-08-22 10:58:54,794 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2)
2013-08-22 10:58:54,795 DEBUG [VideoDAOImpl] Reading a Video (id = 2)
2013-08-22 10:58:54,795 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 2, format AVC_TS_MP_HD_AC3_ISO and profile Playstation 3
2013-08-22 10:58:54,796 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Adventure.Time.S05E03.720p.hdtv.x264-2hd.mkv
2013-08-22 10:58:54,796 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E03.720p.hdtv.x264-2hd.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:54,796 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2 (local)
2013-08-22 10:58:54,796 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2)
2013-08-22 10:58:54,797 DEBUG [VideoDAOImpl] Reading a Video (id = 2)
2013-08-22 10:58:54,797 DEBUG [VideoDeliveryEngine] Delivering item '2' for client 'Identifier=192.168.0.33, Profile=Playstation 3'
2013-08-22 10:58:54,798 DEBUG [VideoDeliveryEngine] Delivering file 'Adventure.Time.S05E03.720p.hdtv.x264-2hd.mkv' using transcoding
2013-08-22 10:58:54,798 DEBUG [AbstractTranscodingDeliveryEngine] No other client uses transcoding job of file 'transcoding-temp-1-4-ORIGINAL.stf', will stop the job
2013-08-22 10:58:54,798 DEBUG [AbstractTranscodingDeliveryEngine] Stopping previous transcoding job of file 'transcoding-temp-1-4-ORIGINAL.stf'
2013-08-22 10:58:54,824 DEBUG [TranscodingJobListener] Deleted temp file '/var/folders/zn/38pkg9p56md4kdc0_spgvk5w0000gn/T/Serviio/transcoding-temp-1-4-ORIGINAL.stf': true
2013-08-22 10:58:54,824 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.0.33, Profile=Playstation 3'
2013-08-22 10:58:54,824 DEBUG [MediaItemDAOImpl] Getting file of media item 2
2013-08-22 10:58:54,825 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: /Volumes/TheVault/HUXLEY SHOWS/Adventure Time/Season 5/Adventure.Time.S05E03.720p.hdtv.x264-2hd.mkv
2013-08-22 10:58:54,826 DEBUG [ProcessExecutor] Starting /Applications/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg -fflags +genpts -threads auto -i /Volumes/TheVault/HUXLEY SHOWS/Adventure Time/Season 5/Adventure.Time.S05E03.720p.hdtv.x264-2hd.mkv -y -c:v copy -bsf:v h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts /var/folders/zn/38pkg9p56md4kdc0_spgvk5w0000gn/T/Serviio/transcoding-temp-2-4-ORIGINAL.stf
2013-08-22 10:58:55,271 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-08-22 10:58:55,272 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-08-22 10:58:55,327 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2013-08-22 10:58:55,327 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Adventure.Time.S05E03.720p.hdtv.x264-2hd.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-22 10:58:55,328 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2) as read
2013-08-22 10:58:55,477 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-08-22 10:58:55,477 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-08-22 10:58:55,477 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-08-22 10:58:55,477 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Thu, 22 Aug 2013 14:58:55 GMT,Server: Mac OS X, UPnP/1.0 DLNADOC/1.50, Serviio/1.2.1,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=0-670/670,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-08-22 10:58:56,184 DEBUG [WebServer] I/O error: Broken pipe
2013-08-22 10:58:57,738 DEBUG [DiscoveryAdvertisementNotifier] Problem during DiscoveryAdvertisementNotifier, will try again
2013-08-22 10:58:57,739 WARN  [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2013-08-22 10:58:59,742 DEBUG [ActionsServerResource] Action with name 'stopServer' was requested
2013-08-22 10:58:59,742 DEBUG [DiscoveryManager] UPNP device c41c5514-0d79-3774-967b-023b9e31d01f (192.168.0.2) is unavailable
2013-08-22 10:58:59,742 DEBUG [WebServer] Socket closed
2013-08-22 10:58:59,742 INFO  [WebServer] WebServer shutting down
2013-08-22 10:58:59,742 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2013-08-22 10:58:59,743 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2013-08-22 10:58:59,743 DEBUG [DiscoverySSDPMessageListener] Socket closed: Socket closed
2013-08-22 10:58:59,743 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2013-08-22 10:58:59,743 INFO  [EventDispatcher] Leaving EventDispatcher
2013-08-22 10:58:59,744 WARN  [DiscoveryAdvertisementNotifier] Problem sending bye-bye: Can't assign requested address
   at org.serviio.upnp.discovery.DiscoveryAdvertisementNotifier.sendByeByeToSingleInterface(DiscoveryAdvertisementNotifier.java:203)
   at org.serviio.upnp.discovery.DiscoveryAdvertisementNotifier.sendByeBye(DiscoveryAdvertisementNotifier.java:152)
   at org.serviio.upnp.discovery.DiscoveryManager.deviceUnavailable(DiscoveryManager.java:128)
   at org.serviio.MediaServer.stopServer(MediaServer.java:222)
   at org.serviio.ui.resources.server.ActionsServerResource.stopServer(ActionsServerResource.java:130)
   at org.serviio.ui.resources.server.ActionsServerResource.execute(ActionsServerResource.java:73)
   at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
   at java.lang.reflect.Method.invoke(Method.java:597)
   at org.restlet.resource.ServerResource.doHandle(ServerResource.java:446)
   at org.restlet.resource.ServerResource.post(ServerResource.java:1111)
   at org.restlet.resource.ServerResource.doHandle(ServerResource.java:530)
   at org.restlet.resource.ServerResource.doNegotiatedHandle(ServerResource.java:587)
   at org.restlet.resource.ServerResource.doConditionalHandle(ServerResource.java:299)
   at org.restlet.resource.ServerResource.handle(ServerResource.java:846)
   at org.restlet.resource.Finder.handle(Finder.java:510)
   at org.restlet.routing.Filter.doHandle(Filter.java:156)
   at org.restlet.routing.Filter.handle(Filter.java:203)
   at org.restlet.routing.Router.doHandle(Router.java:497)
   at org.restlet.routing.Router.handle(Router.java:737)
   at org.restlet.engine.application.StatusFilter.doHandle(StatusFilter.java:151)
   at org.restlet.engine.ChainHelper.handle(ChainHelper.java:111)
   at org.restlet.engine.application.ApplicationHelper.handle(ApplicationHelper.java:72)
   at org.restlet.Application.handle(Application.java:391)
   at org.restlet.Component.handle(Component.java:388)
   at org.restlet.Server.handle(Server.java:488)
   at org.restlet.engine.http.connector.BaseServerHelper.handle(BaseServerHelper.java:158)
   at org.restlet.engine.http.connector.BaseServerHelper.handleInbound(BaseServerHelper.java:167)
   at org.restlet.engine.http.connector.BaseHelper.handleNextInbound(BaseHelper.java:418)
   at org.restlet.engine.http.connector.Connection.readMessages(Connection.java:696)
   at org.restlet.engine.http.connector.Controller$2.run(Controller.java:95)
   at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:895)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:918)
2013-08-22 10:59:00,828 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
Twitch_City
Post Fri Aug 23, 2013 12:05 am
Similarly, I just tried a clean install of 1.3.1 (so reapplying my license file and starting with a blank library; again, with the PS3 using the Playstation 3 profile), and I still get the "unsupported data" issue. I'm really baffled! Could something be wrong with something Serviio relies upon for transcoding?
Post Fri Aug 23, 2013 7:57 am
Zip what is this warning message ?
Post Fri Aug 23, 2013 10:38 am
Illico wrote:Zip what is this warning message ?
Nothing related to playback and fixed in 1.3 anyway.
To the OP, are you 100% sure this particular file played before? It just remuxes the h264 stream, so if it's not properly encoded, it'd make sense. But if it played before, I'm lost.
Twitch_City
Post Fri Aug 23, 2013 12:48 pm
Yes, 100% sure. And I just tried streaming a few other mkv files I have lying around (some movies), and the success rate there was about 50/50. There is definitely something glitching when transcoding mkvs. Other filetypes still stream successfully (although all of the ones I tested probably didn't need transcoding)...
Could it have something to do with the version of java installed on the machine or anything like that? The computer doing the streaming/transcoding is an Intel iMac with 2.77 GHz Intel Core 2 Duo processor, 4 GB memory, running 10.8.4. It has Java 7 (update 25) installed.
Post Fri Aug 23, 2013 1:50 pm
No, it's done by ffmpeg, so Java should not matter.
Are you on wifi or wired? Maybe there is connectivity issue.
Twitch_City
Post Fri Aug 23, 2013 1:56 pm
Both PS3s are wired via ethernet to the router (a Time Capsule), which is also connected to the iMac via ethernet.
Oh no, I was really hoping that this was solvable! If it is the file (maybe it got corrupted somehow... but it still plays fine on the iMac itself via VLC), is there a transcoding setting I can change to make it more aggressive or something like that? I have "produce the best video quality" checked, but also "downmix to stereo". Or maybe I should try other device profiles, despite the output being sent to a PS3?
I don't know if this helps but I just went through and the season directory has 31 episodes, and oddly enough about 3 or 4 of them stream fine, while the rest give the "data type is not supported" error. They are all scene releases in the same format (720p.HDTV.x264), and some of the working files and the non-working files even come from the same release group.
Post Fri Aug 23, 2013 2:23 pm
Could you add the following code in profiles.xml file just before the last </Profiles> element, then restart serviio service or reboot, then select this new profile "Playstation 3 - MKV*" for files that does not work ?
   <Profile id="ps3bis" name="Playstation 3 - MKV*" extendsProfileId="4">
         <!-- Transcode MKV/h264 -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="384" >
Twitch_City
Post Fri Aug 23, 2013 2:39 pm
I just tried this, and unfortunately it still isn't transcoding properly (same error).
Post Fri Aug 23, 2013 3:14 pm
You could try to remux the file to mp4 using another tool and then try to play the file natively. If it still fails, then it's the video stream encoding, causing the problem.
Twitch_City
Post Mon Aug 26, 2013 1:15 am
Interesting. I took the directory and ran all the files through MKV2VOB (which actually produced mp4s). No transcoding was needed, just remuxing (so it only took the app a few seconds on each file) - and these stream perfectly.
So it still seems like something is awry in Serviio's on-the-fly transcoding, but I'm not sure what. In MKV2VOB I do have the "convert DTS to AC3" checked - could that have something to do with the issue? (I guess it shouldn't since the files are AC3 already...)
Post Mon Aug 26, 2013 7:09 am
Could you try in a local windows terminal the command line, then copy and add the output file to the serviio libary and check playback :
ffmpeg -fflags +genpts -threads auto -i /Volumes/TheVault/HUXLEY SHOWS/Adventure Time/Season 5/Adventure.Time.S05E03.720p.hdtv.x264-2hd.mkv -y -c:v copy -bsf:v h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts /var/folders/zn/38pkg9p56md4kdc0_spgvk5w0000gn/T/Serviio/transcoding-temp-2-4-ORIGINAL.mpg
(without fflags)
ffmpeg -threads auto -i /Volumes/TheVault/HUXLEY SHOWS/Adventure Time/Season 5/Adventure.Time.S05E03.720p.hdtv.x264-2hd.mkv -y -c:v copy -bsf:v h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts /var/folders/zn/38pkg9p56md4kdc0_spgvk5w0000gn/T/Serviio/transcoding-temp-2-4-ORIGINAL.mpg
Twitch_City
Post Thu Sep 05, 2013 1:23 am
Re: Serviio Pro v.1.3.1 breaks mkv on PS3?
Thanks for the reply. Sorry it took so long for me to get to this - been a busy week. I ran both of the conversions. Here is the terminal output:
Mumbles-iMac:~ Mumbles$ cd /Applications/Serviio.app/Contents/MacOS
Mumbles-iMac:MacOS Mumbles$ ./ffmpeg -fflags +genpts -threads auto -i /Volumes/TheVault/HUXLEY\ SHOWS/Adventure\ Time/Season\ 5/SceneReleases/Adventure.Time.S05E03.720p.hdtv.x264-2hd.mkv -y -c:v copy -bsf:v h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts /var/folders/zn/38pkg9p56md4kdc0_spgvk5w0000gn/T/Serviio/transcoding-temp-2-4-ORIGINAL.mpg
  built on Jun 18 2013 11:47:55 with gcc 4.0.1 (GCC) (Apple Inc. build 5493)
  configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-libmp3lame --enable-librtmp --enable-libfreetype --enable-fontconfig --enable-libass --enable-pthreads --enable-libx264 --enable-gpl --disable-mmx --extra-ldflags=-L/Users/MacAdmin/Desktop/build/target/lib --extra-cflags=-I/Users/MacAdmin/Desktop/build/target/include --extra-libs='-lpolarssl -lfreetype -lexpat -liconv'
Input #0, matroska,webm, from '/Volumes/TheVault/HUXLEY SHOWS/Adventure Time/Season 5/SceneReleases/Adventure.Time.S05E03.720p.hdtv.x264-2hd.mkv':
    creation_time   : 2012-11-20 00:51:13
  Duration: 00:11:10.91, start: 0.000000, bitrate: 2411 kb/s
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0:1: Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s (default)
Output #0, mpegts, to '/var/folders/zn/38pkg9p56md4kdc0_spgvk5w0000gn/T/Serviio/transcoding-temp-2-4-ORIGINAL.mpg':
    encoder         : Lavf55.9.100
    Stream #0:0(eng): Video: h264, yuv420p, 1280x720 [SAR 1:1 DAR 16:9], q=2-31, 23.98 fps, 90k tbn, 23.98 tbc (default)
    Stream #0:1: Audio: ac3, 48000 Hz, 5.1(side), 448 kb/s (default)
Stream mapping:
  Stream #0:0 -> #0:0 (copy)
  Stream #0:1 -> #0:1 (copy)
frame=  116 fps=0.0 q=-1.0 size=    4591kB time=00:00:04.89 bitrate=7682.2kbits/frame= 1008 fps=996 q=-1.0 size=   34425kB time=00:00:42.27 bitrate=6671.3kbits/frame= 2364 fps=1521 q=-1.0 size=   54526kB time=00:01:38.68 bitrate=4526.1kbitsframe= 4172 fps=2031 q=-1.0 size=   79821kB time=00:02:54.04 bitrate=3757.0kbitsframframe= 7522 fps=frame= 8264 fps=2268 qframframe=16085 fps=2552 q=-1.0 Lsize=  215773kB time=00:11:10.91 bitrate=2634.6kbits/s
video:160625kB audio:36690kB subtitle:0 global headers:0kB muxing overhead 9.354382%
And the output from the second file:
Mumbles-iMac:MacOS Mumbles$ ./ffmpeg -threads auto -i /Volumes/TheVault/HUXLEY\ SHOWS/Adventure\ Time/Season\ 5/SceneReleases/Adventure.Time.S05E03.720p.hdtv.x264-2hd.mkv -y -c:v copy -bsf:v h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts /var/folders/zn/38pkg9p56md4kdc0_spgvk5w0000gn/T/Serviio/transcoding-temp-2-4-ORIGINAL2.mpg
Output #0, mpegts, to '/var/folders/zn/38pkg9p56md4kdc0_spgvk5w0000gn/T/Serviio/transcoding-temp-2-4-ORIGINAL2.mpg':
Stream mapping:
frame=16085 fps=2129 q=-1.0 Lsize=  215773kB time=00:11:10.91 bitrate=2634.6kbits/s
For both scenarios, I went into the temp directory and copied the mpg files to my Serviio library. Unfortunately, in both cases I still get the same error - the PS3 says that the filetype is unsupported :(
Users browsing this forum: Baidu [Spider], Google [Bot] and 6 guests
