Compiling FFMPEG on Ubuuntu 13
spudy12
Post Wed Aug 21, 2013 10:25 am
If anyone is struggling to compile FFMPEG for Ubuntu following the guide on the Wiki, try this
http://ffmpeg.org/trac/ffmpeg/wiki/Ubun ... ationGuide
When following the guide on the wiki, I was getting ffmpeg build failed among other errors but after lots of searching found this guide worked well.
If you follow this guide to compile it, you will then need to add
 -Dffmpeg.location=/home/[user-name]/bin/ffmpeg
replacing [user-name] with your username (and no square brackets) to the serviio.sh file under the bin directory where you installed serviio.
Spud
Post Thu Aug 22, 2013 12:56 pm
Re: Compiling FFMPEG on Ubuuntu 13
cool. maybe you could update the wiki guide with this?
spudy12
Post Thu Aug 22, 2013 5:01 pm
Yes i'd be happy to. Give me a few days to test it out with Mac devices and iOS then i'll be happy to write it up
Spud
Post Thu Aug 22, 2013 5:19 pm
Its referenced in the main how to build ffmpeg guide (http://wiki.serviio.org/doku.php?id=build_ffmpeg_linux) which is ubuntu/debian based, so maybe we just just point to that from the ubuntu page.
