Network problem (local IP address) with Serviio 1.3.1
edsic
Post Thu Aug 22, 2013 4:59 pm
I tried to upgrade to Serviio 1.3.1 on xubuntu 12.04 desktop PC.
Serviio 1.2.1 (Free license) still works, but Serviio 1.3.1 does not show up in my UPnP browser (XBMC).
I connect over a link-local network (IPv4 addresses look like 169.254.x.y)
File serviio.log for 1.3.1 contains:
2013-08-18 18:02:36,159 WARN  [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 9 times
2013-08-18 18:02:41,161 WARN  [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 8 times
2013-08-18 18:02:46,162 WARN  [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 7 times
2013-08-18 18:02:51,165 WARN  [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 6 times
2013-08-18 18:02:54,461 INFO  [ServiioConsole] Initializing Serviio Console
2013-08-18 18:02:54,492 INFO  [ServiioConsole] Starting Serviio Console
2013-08-18 18:02:55,246 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2013-08-18 18:02:56,249 WARN  [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 5 times
2013-08-18 18:03:01,282 WARN  [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 4 times
2013-08-18 18:03:06,284 WARN  [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 3 times
2013-08-18 18:03:11,286 WARN  [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 2 times
2013-08-18 18:03:16,290 WARN  [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 1 times
2013-08-18 18:03:21,328 INFO  [Device] Created UPnP Device with UUID: 12486d15-079e-3f2f-932c-6be88964d93a, bound address: 127.0.0.1
whereas the log for 1.2.1 (the one I can still connect to) finds a 169.254.* IP address :
2013-07-24 11:51:17,283 INFO  [Device] Created UPnP Device with UUID: 4d1a872e-2ed4-311b-b0f1-721e326f3855, bound address: 169.254.x.y
Version details:
2013-08-18 18:02:31,749 INFO  [MediaServer] ------------------------------------------------------------------------
2013-08-18 18:02:31,751 INFO  [MediaServer] Serviio DLNA media streaming server v 1.3.1 (rev. f1fc8bc55657+)
2013-08-18 18:02:31,751 INFO  [MediaServer] Petr Nejedly 2009-2013
2013-08-18 18:02:31,751 INFO  [MediaServer] http://www.serviio.org
2013-08-18 18:02:31,752 INFO  [MediaServer]
2013-08-18 18:02:31,752 INFO  [MediaServer] Java 1.6.0_27-Sun Microsystems Inc.
2013-08-18 18:02:31,752 INFO  [MediaServer] OS Linux i386 3.2.0-49-generic
2013-08-18 18:02:31,752 INFO  [MediaServer] File encoding: UTF-8
2013-08-18 18:02:31,752 INFO  [MediaServer] Headless mode enabled: true
Can you help ?
Post Thu Aug 22, 2013 5:41 pm
Re: Network problem (local IP address) with Serviio 1.3.1
169.254.X.X is a special IP address, it is normally automatically assigned by your PC after failing to get one from a DHCP server. This often happens straight after resuming from sleep, hence why Serviio now ignores them.
In your case you will need to use a proper IP address. Why are you using that in the first place? (It's not clear if you are doing it intentionally)
edsic
Post Thu Aug 22, 2013 6:05 pm
Another PC (machine A) is linked to the server PC (machine B) with an Ethernet cable.
This creates a so-called link-local network with 169.254.* addresses, no problem with that I think.
The problem is that serviio.log for the new 1.3.1 version complains along the lines of
and then announces 127.0.0.1 for a bound address, which is not very interesting.
whereas serviio 1.2.1 finds the link-local address of machine B;
machine A can still connect to B and play some music.
Post Thu Aug 22, 2013 6:14 pm
Yes because those addresses usually indicate that the machine hasn't had a chance to get a valid IP address yet when resuming from sleep, so they are now ignored so that Serviio can retry later.
Just assign 192.168.1.1 to the server and 192.168.1.2 or machine A, or similar.
edsic
Post Thu Aug 22, 2013 6:41 pm
Do you mean that serviio 1.3 changed in such a way that my setup needs to be changed, or is there some other way to go ?
Post Thu Aug 22, 2013 6:53 pm
You will need to change to a more standard setup, which shouldn't be a problem, just set a static IP on each machine.
edsic
Post Thu Aug 22, 2013 9:00 pm
Isn't setting a static IP incompatible with Avahi/Zeroconf services ? I use Avahi.
Why is it no longer possible to bind to a 169.254.* address ?
I tried to set the java property serviio.boundAddr, and to set the bound address on the serviio console, to no avail.
Post Thu Aug 22, 2013 9:38 pm
Can you give some more details about your setup, presumably one of the machines has a second NIC for Internet access?
As I've tried to explain, those IP are now blocked as they are usually always a symptom of a network problem, especially after resuming from sleep.
edsic
Post Fri Aug 23, 2013 8:55 am
will wrote:Can you give some more details about your setup, presumably one of the machines has a second NIC for Internet access?
This is the only thing I do not like about Serviio so far :)
It feels arbitrary to me. Why not let users tell serviio to honor 169.254.* if it's what they want ?
I do not like to mess with networking settings, and I think that my setup has nothing fancy to it:
I only ever use Network Manager GUI, which has a 'link-local' button.
Machine A is a linux (ubuntu) PC, it connects to the internet with wifi (wlan).
Machine B with serviio is a linux (xubuntu 12.04 LTS) PC, with a similar setup (except it does not need to connect to the internet everyday).
An ethernet cable links A and B.
The link-local network connects automatically.
All is well with Avahi/Zeroconf.
It does not seem that difficult to define a new connection with static IP addresses,
but I'd rather keep my current setup which is more comfortable.
Post Fri Aug 23, 2013 6:33 pm
Lots of users were having problems with not being able to access Serviio after resuming from sleep. In a number of cases, Serviio was finding and binding to one of those temp IP addresses straight after resuming from sleep, because it started looking before the PC got a proper one from the DHCP server. The solution was to ignore those addresses, so that Serviio could retry and hopefully pick up a proper one once available.
So far you appear to be the only user that actually uses a 169.254.* address, so I guess call it an oversight, but it really is quite a niche setup. While there may be plenty of other users that connect a PC directly to their TV/HTPC, one would usually either set a static IP on each machine, or set a static IP on one and make it give the other an IP using DHCP. Off the top of my head, I cannot think of any service that works with a link-local address that won't work with a proper IP address, so I really would recommend that you do it. I also belive there is no reason you cannot set it using the network manager UI, if you don't want to do it via a terminal.
edsic
Post Sat Aug 24, 2013 10:22 am
Understood. Link-local connections go well with my physical setup but this setup is uncommon among serviio users, which does not come as a surprise.
And I tried to make the network between the two machines with static IP addresses: it turns out that it was not that hard;
XBMC is streaming music from serviio 1.3.1 as I type this message.
Thanks for all your comments.
Post Sat Aug 24, 2013 10:24 am
Thats good, glad you got it working.
Users browsing this forum: Baidu [Spider] and 29 guests
