Bravia 2013 models (W6 W8 W9 & X9005A serie)
Post Thu Aug 22, 2013 6:17 am
Re: Bravia 2013 models (W & X9005A serie)
guru1d wrote:Unfortunately I was wrong Online Sources...
Sorry, but I don't understand, what to you mean by wrong "Online Sources"?
Could you download some 3gp samples and add them to your local library?
guru1d
Post Thu Aug 22, 2013 9:09 pm
I meant I accidently wrote online sources like "Online RSS" or "live streams" would work with new 2013 profile, but I was wrong. Even I saw profile Bravia 2013 profile active, but it was not seems still Bravia 2009 profile was choosen. Might be a bug: sometimes it is not possible to click on save button after switching profiles.
I downloaded and added to library following 3pgs:
1) dolphins_1800k.3gp
2) Media-Convert_test1_3GPv4_H263_xbit_352x288_AR1.22_15fps_KFx_374kbps_AMRNB_Mono_8000Hz_12.2kbps.3gp
3) Quicktime_test9_3GPv5_MPEG4SP_24bit_320x240_1.33_24fps_KF1in30_320kbps_AMR-NB_Mono_48000Hz_7.95kbps.3gp
4) 3GP_AAC_48kbps_H263_208kbps_25fps_QCIF.3gp
Profile 2013 beta official from 20.08.2013
1) displayed and working fine 2) displayed, but video and sound not working 3) displayed, but sound not supported 4) not displayed in folder
if I use an older 2013 beta with improvements chilano made
all 1) 2) 3) 4) displayed and working fine
also added 3g2:
5) SUPER_test1_3GP2_MPEG4SP_xbit_320x240_AR1.77_29.97fps_KFx_64kbps_AAC-LC_Stereo_48000Hz_256kbps.3G2
6) Quicktime_test1_3GP2_H263_xbit_176x144_AR1.22_25fps_KF1in15_256kbps_AAC_Mono_48000Hz_96kbps.3g2
7) HelixMobileProducer_test4_3G2_H.263_xbit_352x288_AR1.22_25fps_KFx_128kbps_QCELP_x_xHz_14kbps.3g2
all not displayed
Post Fri Aug 23, 2013 7:50 am
guru1d wrote:I downloaded and added to library following 3pgs:...
Thanks, to resume...
1) dolphins_1800k.3gp => 3GPP6/H264/AAC works
2) Media-Convert_test1_3GPv4_H263_xbit_352x288_AR1.22_15fps_KFx_374kbps_AMRNB_Mono_8000Hz_12.2kbps.3gp => 3GP4/H263/AMR_nb Failed (but displayed) => Audio codec probably not supported
3) Quicktime_test9_3GPv5_MPEG4SP_24bit_320x240_1.33_24fps_KF1in30_320kbps_AMR-NB_Mono_48000Hz_7.95kbps.3gp => 3GP5/MPEG4-Simple@L3/AMR_nb Failed no sound (but displayed) => Audio codec probably not supported
4) 3GP_AAC_48kbps_H263_208kbps_25fps_QCIF.3gp => 3GP5/H263/AAC Failed (not displayed) - probably because video and audio stream are not in first position or h263 not supported
5) SUPER_test1_3GP2_MPEG4SP_xbit_320x240_AR1.77_29.97fps_KFx_64kbps_AAC-LC_Stereo_48000Hz_256kbps.3G2 => 3GP5/MPEG4-Simple Scalable@L1/AAC Failed (not displayed) => Simple Scalable mpeg4 profile probably not supported
6) Quicktime_test1_3GP2_H263_xbit_176x144_AR1.22_25fps_KF1in15_256kbps_AAC_Mono_48000Hz_96kbps.3g2 => 3GPP2/H263/AAC Failed (not displayed) => So h263 not supported
7) HelixMobileProducer_test4_3G2_H.263_xbit_352x288_AR1.22_25fps_KFx_128kbps_QCELP_x_xHz_14kbps.3g2 => 3GPP2/H263/QCELP Failed (not displayed) => probably h263 and Qcelp ot supported
So could you retry with these two lines added from the Profile 2013 beta official from 20.08.2013 ?
<Matches container="3gp" aCodec="amrnb" />
<Matches container="3gp" vCodec="h263" />
( only [5] ) should failed )
guru1d
Post Fri Aug 23, 2013 2:45 pm
I did as you asked:
1) 2) 3) 4) work now :).
5) 6) 7) not shown in folder. (the ending is 3G2 not 3gp)
I didn't pay attention to it, because headline of website says 3gp
http://download.wavetlan.com/SVV/Media/HTTP/http-3gp.htm.
Post Fri Aug 23, 2013 6:01 pm
guru1d wrote:5) 6) 7) not shown in folder. (the ending is 3G2 not 3gp)
Zip, does serviio support 3GPP2 stream ?
Serviio support these profile...
<MediaFormatProfile mime-type="video/3gpp">MPEG4_P2_3GPP_SP_L0B_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/3gpp">MPEG4_P2_3GPP_SP_L0B_AMR</MediaFormatProfile>
<MediaFormatProfile mime-type="video/3gpp">AVC_3GPP_BL_QCIF15_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/3gpp">MPEG4_H263_3GPP_P0_L10_AMR</MediaFormatProfile>
<MediaFormatProfile mime-type="video/3gpp">MPEG4_H263_MP4_P0_L10_AAC</MediaFormatProfile>
And Sony need following mimetype:
http-get:*:video/3gpp:*,
http-get:*:video/3gpp2:*,
guru1d
Post Fri Aug 23, 2013 11:26 pm
btw. online resourses are still not shown in "online" folder. Do you have any idea which file these would have (to add them in profil)?? As mentioned before I added "LiveFeeds_HD_Sports.rss".
Thank you.
Edit:
made further tests as Live stream:
1)
mmsh://live1.wm.skynews.servecast.net/skynews_wmlz_live300k
- displayed and working
2)
rtmp://cdn.rtmp1.yupptv.tv:1935/nwk/ swfUrl=http://cdn.freedocast.com/player-octo/yume/v5/infinite-hd-player-FREEDOCAST.SWF pageURL=http://www.yupptv.com/streams/newsx1.aspx playpath=newsx
- not displayed
guru1d
Post Wed Aug 28, 2013 6:27 am
Format                                   : MPEG-4 Visual
Format settings, BVOP                    : 1
Format settings, QPel                    : No
Format settings, GMC                     : No warppoints
Format settings, Matrix                  : Default (H.263)
Muxing mode                              : Packed bitstream
Codec ID                                 : DX50
Codec ID/Hint                            : DivX 5
Duration                                 : 1h 30mn
Bit rate                                 : 1 613 Kbps
Width                                    : 720 pixels
Height                                   : 544 pixels
Display aspect ratio                     : 4:3
Frame rate                               : 25.000 fps
Bits/(Pixel*Frame)                       : 0.165
Stream size                              :
Writing library                          : DivX 6.8.5 (UTC 2009-08-20)
Format                                   : MPEG Audio
Format version                           : Version 1
Format profile                           : Layer 3
Mode                                     : Joint stereo
Mode extension                           : MS Stereo
Codec ID                                 : 55
Codec ID/Hint                            : MP3
Duration                                 : 1h 30mn
Bit rate                                 : 101 Kbps
Nominal bit rate                         : 128 Kbps
Stream size                              : 65.4 MiB (6%)
Alignment                                : Aligned on interleaves
Interleave, duration                     : 24 ms (0.60 video frame)
Interleave, preload duration             : 586 ms
Writing library                          : LAME3.98r
Encoding settings                        : -m j -V 4 -q 2 -lowpass 17 --abr 128
This Video is only played with Profile 2013 when I add
<Matches container="avi" vCodec="mpeg4" vFourCC="div3,div4,div5,divx,dm4v,dx50" />
Post Wed Aug 28, 2013 6:50 am
guru1d wrote:This Video is only played with Profile 2013 when I add
Do you try to change the fourcc to XVID with that tools ? viewtopic.php?f=17&t=4599
chilano
Post Wed Aug 28, 2013 5:36 pm
Illico, any idea what needs adding to the profile to get an MKV container with h264 and FLAC to play correctly? Using the current 2013 profile allows the video to be played but an error is displayed on the TV stating the audio format is not supported. If I try with the 2012 profile it plays back fine, although the AR is incorrect as the video is 2.40:1 rather than 16:9. Here's the MediaInfo output:
Format                           : Matroska
Format_Version                   : Version 4 / Version 2
OverallBitRate_Mode/String       : Variable
OverallBitRate/String            : 15.7 Mbps
ID/String                        : 1
Format_Profile                   : High@L4.0
Format_Settings_CABAC/String     : Yes
Format_Settings_RefFrames/String : 5 frames
CodecID                          : V_MPEG4/ISO/AVC
Width/String                     : 1 920 pixels
Height/String                    : 800 pixels
DisplayAspectRatio/String        : 2.40:1
FrameRate_Mode/String            : Constant
FrameRate/String                 : 23.976 fps
ColorSpace                       : YUV
ChromaSubsampling                : 4:2:0
BitDepth/String                  : 8 bits
ScanType/String                  : Progressive
ID/String                        : 2
Format                           : FLAC
Format/Info                      : Free Lossless Audio Codec
CodecID                          : A_FLAC
Channel(s)/String                : 8 channels
SamplingRate/String              : 48.0 KHz
BitDepth/String                  : 24 bits
Thanks,
Chilano
Post Wed Aug 28, 2013 6:34 pm
chilano wrote:Illico, any idea what needs adding to the profile to get an MKV container with h264 and FLAC to play correctly?
Could you retry with the updated profile ? viewtopic.php?f=11&t=11147
For aspect ratio, the original is not a standard DAR, so nothing to do...or have to force h264 transcoding to mpeg2video, but that will be for all h264 video, not so good.
chilano
Post Wed Aug 28, 2013 9:45 pm
Illico wrote:Could you retry with the updated profile ? viewtopic.php?f=11&t=11147
I did try with the updated profile from 20/08/2013, but I think it might be missing Media Format Profile elements. I experimented with a few settings this evening and I've eventually got the format working, including the AR issue. I added an extra target container specifically for the format I'm testing, which restricts the bitrate of the audio, and I've added the Media Format Profiles from the sony2012 profile:
<Profile id="sony2013c" name="Sony Bravia TV (2013-chilano)" extendsProfileId="1">
   <!-- 2013 models
      Codec list supported : http://pdf.crse.com/manuals/13MW802111/FR/codeclist.html#5
      - Still images: JPEG (*.jpg / *.jpe / *.jpeg), MPO (*.mpo), RAW (*.arw)
      - Music: LPCM, MP1L1 / MP1L2 / MP1L3 / MP2L1 / MP2L2 / MP2L3 / MP2.5L3 (*.mp3), AAC-LC / HE-AAC v1/v2 (*.mp4 / *.m4a / *.3gp / *.3g2), WMA9 (*.wma)
      - Video: MPEG1 / MPEG2PS / AVCHD , MP4, Xvid, Motion JPEG, VC1, MKV, 3gpp, MOV, WebM
   <Detection>
      <UPnPSearch>
         <FriendlyName>BRAVIA (KDL-\d{2}W[689]\d{2}A.*)|(KD-\d{2}X9005A.*)</FriendlyName>
      </UPnPSearch>
   </Detection>
   <DeviceDescription>
      <!-- act as WMP so that the TV doesn't show root categories -->
      <ModelName>Windows Media Player Sharing</ModelName>
      <ModelNumber>3.0</ModelNumber>
      <Manufacturer>Microsoft Corporation</Manufacturer>
   </DeviceDescription>
   <ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.SonyDLNAMessageBuilder</ContentDirectoryMessageBuilder>
   <ContentDirectoryDefinitionFilter>org.serviio.upnp.service.contentdirectory.definition.WMPContentDirectoryDefinitionFilter</ContentDirectoryDefinitionFilter>
   <MediaFormatProfiles>
      <!-- Rename native avi formats to those supported by the tv -->
      <MediaFormatProfile mime-type="video/avi" name="">AVI</MediaFormatProfile>
      <!-- Rename native mpeg2ts with h264+ac3/aac formats to those supported by the tv (aac support is not advertised by the renderer but it works) -->
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3,AVC_TS_HD_50_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_HD_AC3</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3,AVC_TS_HD_50_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_SD_AC3</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3,AVC_TS_HD_50_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_HD_AAC_MULT5</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3,AVC_TS_HD_50_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_SD_AAC_MULT5</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_HP_HD_MPEG1_L2_T</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_HP_SD_MPEG1_L2_T</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_HD_AAC_MULT5_T</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_AAC_MULT5_T</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_MPEG1_L3</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_MPEG1_L3_T</MediaFormatProfile>
      <!-- Rename transcoded mpeg2ts with h264 to one of the TV's supported profiles -->
      <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_HP_HD_MPEG1_L2_ISO</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_HP_SD_MPEG1_L2_ISO</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_HD_AAC_MULT5_ISO</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_SD_AAC_MULT5_ISO</MediaFormatProfile>
      <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_SD_MPEG1_L3_ISO</MediaFormatProfile>
   </MediaFormatProfiles>
      <!-- Transcode all h264 video with HIGH/MAIN > Level 4.2 on MPEG-TS stream with MPEG2VIDEO and ac3 audio transcoding -->
      <!-- expected profile MPEG_TS_SD_EU/MPEG_TS_SD_NA/MPEG_TS_SD_KO -->
      <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" DAR="16:9" forceInheritance="true">
         <Matches container="*" vCodec="h264" profile="high_10" />
         <Matches container="*" vCodec="h264" profile="high" levelGreaterThan="4.2" />
         <Matches container="*" vCodec="h264" profile="main" levelGreaterThan="4.2" />
      <!-- Remux containers with h264 video + AC3 audio to MPEG-TS stream without transcoding -->
      <Video targetContainer="mpegts" forceInheritance="true">
         <Matches container="avi" vCodec="h264" aCodec="ac3" />
         <Matches container="flv" vCodec="h264" aCodec="ac3" />
         <Matches container="wtv" vCodec="h264" aCodec="ac3" />
      <!-- Remux h264 video to MPEG-TS stream with ac3 audio transcoding at a fixed bit rate when FLAC is being used -->
      <!-- expected profile AVC_TS_MP_HD_AC3_ISO -->
      <Video targetContainer="mpegts" targetACodec="ac3" aBitrate="384" DAR="16:9" forceInheritance="true">
      <!-- Remux all other h264 video to MPEG-TS stream with ac3 audio transcoding -->
      <Video targetContainer="mpegts" targetACodec="ac3" forceInheritance="true">
         <Matches container="*" vCodec="h264" aCodec="truehd" />
         <Matches container="wtv" vCodec="h264" />
      <!-- All Others video/audio codec will be transcoded into mpeg2ts, mpeg2video and ac3 audio -->
         <Matches container="mpegts" vCodec="vc1" />
         <Matches container="flv" />
         <!-- example: flv/vp6/mp3 -->
         <Matches container="wtv" />
         <Matches container="ogg" />
         <Matches container="rm" />
         <Matches container="3gp" vCodec="mpeg4" />
         <!-- digital camera video formats -->
         <Matches container="asf" vCodec="vc1" aCodec="wmapro" />
         <Matches container="mp4" vCodec="dvvideo" />
      <Audio targetContainer="lpcm" forceInheritance="true">
         <Matches container="rtp" />
         <Matches container="rtsp" />
         <Matches container="flac" />
         <Matches container="adts" />
      </Audio>
   <HardSubsTranscoding>
      <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" DAR="16:9" />
   </HardSubsTranscoding>
   <Subtitles>
      <HardSubs>
         <RequiredFor container="mpegts" />
         <RequiredFor container="mp4" />
         <RequiredFor container="avi" />
      </HardSubs>
   </Subtitles>
I suspect not all of the Media Format Profile elements are required to resolve the issue, but unfortunately I don't know enough about the formats they specify to pick out the required elements.
Post Thu Aug 29, 2013 7:23 am
Flac audio is not supported, so must be transcode to AC3 or LPCM...
I updated the profile by adding this line :
<Matches container="*" vCodec="h264" aCodec="flac" />
Then could you retry with the updated profile : viewtopic.php?f=11&t=11147&p=72112#p72112
PS: The DAR="16:9" option only have sense when video is transcoded for exemple with targetVCodec="mpeg2video"...so on your previous exemple, DAR option is not used, and not revelant.
chilano
Post Thu Aug 29, 2013 12:42 pm
So I've done some more testing with this today with the sony2013 profile (http://forum.serviio.org/viewtopic.php?f=11&t=11147&p=72112#p72112).
Using that profile the video isn't displayed in the library at all. It is only displayed if add these Media Format Profiles to the the sony2013 profile:
The video now shows up in the library but when played it is displayed with the wrong AR. The video resolution is 1920x800 (2.40:1) and is being stretched to 1920x1080 (16:9) rather than displayed in 16:9 with black bars. When ffmpeg is invoked the following parameters are being used:
C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -fflags +genpts -threads auto -i C:\video.mkv -y -threads auto -c:v copy -bsf:v h264_mp4toannexb -c:a ac3 -b:a 192k -ac 6 -map 0:0 -map 0:1 -sn -f mpegts C:\transcoding-temp-20587-sony2013-ORIGINAL.stf
Now if I add a target container to the profile which explicitly specifies the intended DAR:
<Video targetContainer="mpegts" targetACodec="ac3" DAR="16:9" forceInheritance="true">
The video is now displayed in 1920x1080 (16:9) with black bars. When ffmpeg is invoked a very different set of parameters are being used which is clearly specifying padding the vertical resolution from 800 pixels to 1080 pixels:
C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -threads auto -i C:\video.mkv -y -threads auto -c:v libx264 -profile:v baseline -level 3 -preset veryfast -crf 10 -vf pad=1920:1080:0:140:black,setdar=4:3 -r 24000/1001 -g 15 -bsf:v h264_mp4toannexb -flags -global_header -c:a ac3 -b:a 192k -ac 6 -map 0:0 -map 0:1 -sn -f mpegts C:\transcoding-temp-20587-sony2013c-ORIGINAL.stf
This seems to me like this could be a bug in Serviio's transcoding/remuxing?
guru1d
Post Fri Aug 30, 2013 7:10 am
Wow thank you it is working :). Not only that it plays now the not supportet avi files with codex DX50. Now no problems with fast forward when jumping in middle of the movie. Before it seems with transcoding it need much time like the computer is rendering the hole movie before a wide jump was popssible.
Any idea how to fake this with serviio? to tell the sony DX50 = xvid without transcoding?
Any new ideas to get online recourses / RSS file shown with official profile?
And 3GPP?
Thank you.
guru1d
Post Sat Sep 07, 2013 8:11 am
No ideas?
Post Sat Sep 07, 2013 8:44 am
guru1d wrote:Any idea how to fake this with serviio? to tell the sony DX50 = xvid without transcoding?
without transcoding, there is no solution yet with serviio.
guru1d wrote:Any new ideas to get online recourses / RSS file shown with official profile?
Could you provide some more informations?
guru1d wrote:And 3GPP?
There is a ticket opened :https://bitbucket.org/xnejp03/serviio/issue/704/add-support-of-3gpp2
guru1d
Post Sun Sep 08, 2013 10:51 am
1) "DX50" Thx. Do you know a method to make a batch rewriting DX50 to XVID like with "AVI FourCC Code changer"?
2) "3GPP" Thank you. I make another test. If I rename a *.3G2 file to *.3GP then it is listed and working! So maybe there is a trick to make serviio tell SONY to list/show a *.3G2 file? Maybe then it will played, too? Maybe because most important to make sony list the fileformat in his player.
3) "online recourses / RSS" I think the not listing/showing of files is the problem for this problem, too.
a) If I add "https://sites.google.com/site/neilsrss/LiveFeeds_HD_Sports.rss" under Library -> Online sources -> add -> online Rss/Atom feed nothing is shown on current "bravia profile" (empty folder)
If I switch to profile 2012 I can see 8 channels and they work (if they are online)
b) If I do same for: "https://sites.google.com/site/serviiorss/LiveFeeds_TV_Sports.rss" nothing is listed even not with 2012 profile. So I wonder if there is a new file extension and how to make Seviio show it to Sony.
Previous
