Servioo Log - Library Refresh Info
JamesUK
Post Mon Aug 26, 2013 2:36 pm
When I press the "Force refresh" button in the Serviio Console, the following are added to the Serviio log:
2013-08-26 12:52:11,200 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2013-08-26 12:52:11,200 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2013-08-26 12:52:11,201 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-08-26 12:52:11,214 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
I realise it's not a big deal, but the "finished" lines are before the "started" lines... :)
Post Wed Sep 04, 2013 9:21 pm
Re: Servioo Log - Library Refresh Info
that is correct, it just stops and starts again the updater threads
JamesUK
Post Wed Sep 04, 2013 9:34 pm
Ahhh, I see what you mean. (I did later wonder, but never checked, if I'd perhaps neglected to notice the initial 'Starting' entries in the log.)
Anyway, I guess I mentioned it as I thought that it might be more useful to see when a particular update check started and stopped, just so that you can see how long it took. Maybe that would be something for a different INFO message though, in light of your reply? (It could perhaps summarise the number of additions, removals and updates too.)
Note: The Serviio Console is currently a bit opaque when it comes to seeing what is going on with database/library updates - Both in terms of what has recently happened, as well as an indication of what progress has been made.
