Video Metadata
darkcloud784
Post Tue Aug 27, 2013 3:32 am
Video Metadata
I just upgraded to 1.3.1, after the upgrade a couple of my movies cover changed. I use filebot and directly pull information from IMDB and TheMovieDB. One example is a movie I have "Unleashed" with jet li (http://www.themoviedb.org/movie/10027-danny-the-dog). This is what it USED to show. Now it shows some sort of porn, the name of the file is "Unleashed (2005)". As it was pulled directly from TheMovieDB (also tried imdb both show the same results). I have no idea why it keeps showing the wrong cover or metadata when everything points to the correct movie. Keep in mind, this only occured after I updated. I have no idea why it just started now. Just want to know how to fix it.
Post Wed Sep 04, 2013 10:07 pm
Re: Video Metadata
Serviio now uses a new search API for themoviedb.org, so there might be different results. Try to remove the year from the file name.
darkcloud784
Post Thu Sep 12, 2013 3:55 pm
Re: Video Metadata
zip wrote:Serviio now uses a new search API for themoviedb.org, so there might be different results. Try to remove the year from the file name.
Still seems to come back as porn.
