Playing MKV embedded subtitles help?
Welsh_J_2000
Post Wed Aug 28, 2013 6:34 pm
I have Serviio 1.3 and a Sony BDV-E490. Can anyone help me to get MKV embedded subtitles to work? I can select the option if I play through VLC player but on my Blu-Ray player they don't load and nothing happens when I select the subtitle option.
Cheers
Jazz.
Post Wed Aug 28, 2013 6:39 pm
Re: Playing MKV embedded subtitles help?
What is your serviio console subtitles settings?
What is the size of your mkv file ?
Where did you store your mkv file, on a local hard drive, or a remote (network) drive ?
Welsh_J_2000
Post Wed Aug 28, 2013 6:55 pm
All the below are ticked :
Enable Subtitles
Enable extraction of subtitles embedded in video files
Enable burned in subitles - Always
MKV file size is 4.73gb
Stored on a local hard drive running on the serviio console
Cheers
Post Thu Aug 29, 2013 7:35 am
Do you read this : http://www.serviio.org/index.php?option ... icle&id=33
You have to set a preferred language like "en,eng,english" or "fr,fre,french", then the subtitle character encoding should be the same than UTF-8
After that, you can try to enable detailed logging, and check on log how serviio will process your mkv file.
