cannot play the video while check "burn in" option
wweeii
Post Thu Aug 22, 2013 9:12 pm
hi,
I cannot stream the video from NAS (ds213j) to sony bravia smart TV (2012 model) if I check the "burn in" subtitle option.
the video can be played only if I disable "burn in" function.
please find log in attachment (print screen is the only way I can get the log out, sorry ;) )
Any suggestions?
serviio log
serviio log.jpg (444.43 KiB) Viewed 6515 times
Post Fri Aug 23, 2013 7:18 am
Re: cannot play the video while check "burn in" option
You have to update your ffmpeg with proper configuration file to load all library for subtitle support.
http://wiki.serviio.org/doku.php?id=build_ffmpeg_linux
Post Mon Aug 26, 2013 12:20 pm
Does it work if you remove the [Public HD] from the file name?
wweeii
Post Thu Aug 29, 2013 8:15 pm
zip wrote:Does it work if you remove the [Public HD] from the file name?
Thanks, I'll give it a shot.
Meanwhile, could you please tell me if I need manually update/ install the "ffmpeg" on my synology NAS.
thank you
Post Mon Sep 02, 2013 9:04 am
It should work if you used Patters' pacakage. But the NAS will most likely not be powerful enough to transcode in realtime anyway.
Users browsing this forum: Baidu [Spider], Google [Bot] and 18 guests
