Locked out of Remote
ElToro1966
Post Fri Sep 06, 2013 2:59 pm
Have a problem with the server console. All fields under the Remote-tab have been greyed out and I am unable to change the values in the fields, including User Password under Security. What could be wrong? Thanks.
Post Fri Sep 06, 2013 5:03 pm
Re: Locked out of Remote
Your Pro evaluation license has experied, to continue using remote access you will need to purchase a license.
Admittedly the console could be clearer by showing a message, rather than just disabling it.
ElToro1966
Post Fri Sep 06, 2013 7:26 pm
Thanks for your swift reply. Yes, that could be clearer... :P
