[SOLVED: Caused by SSD] Bravia picture freeze
Lowlander
Post Tue Aug 20, 2013 2:58 pm
Hi there,
I've been experiencing this effect since quite a few Serviio versions and decided to dig a bit deeper now: Some of my mkv/avc/ac3 files start to play, and after somewhere between 30 and 60 seconds the picture gets jerky and finally freezes. I press pause and try to resume, no reaction. If I stop the video and start it right again from the list, it resumes from the point where it had freezed before and continues to play flawlessly right to the end.
I'm not quite sure where to poke first. The files in question should be fine bandwithwise and they don't get transcoded by Serviio either.
I'm currently in the process of re-encoding almost my entire collection, and my basic x264 encoding settings are preset veryslow, film tuning, profile high@L3.1, crf20. I found those settings a good compromise between used space, quality I might lose too much and time I'd spend if I'd fiddle around with all settings for every individual video.
Perhaps there are non-standard x264 settings that are more Bravia compatible?
Does anybody else share my experience with the freezing picture at all?
CU
Low
Post Tue Aug 20, 2013 4:14 pm
Re: Bravia 2010 picture freeze after 30 to 60 seconds
Lowlander wrote:... I press pause and try to resume, no reaction. If I stop the video and start it right again from the list, it resumes from the point where it had freezed before and continues to play flawlessly right to the end.
Its probably because the transcoding process at this point (30s - 60s) is too slow compare to the video playing rate (fps) and buffer in Sony Bravia device become empty...and freezed and become unresponsive to pause/play function.
But when you stop and restart video, the transcoding process was reached and data are always ready for the Sony bravia rendering process.
Suggest:
First could you enabled detailed logging, and check that this problematic file was transcoded, check the ffmpeg command line used.
Then try locally in a windows terminal the same command line with "-report" option added to the command line, then post the ffmpeg report log file (we will check the transcoding fps rate).
Lowlander
Post Wed Aug 21, 2013 3:36 pm
Thanks a lot for pointing me to something to start with, I will collect more info this weekend and report back.
So far I found that the effect seems to be unrelated to the server's load. And videos which freeze will freeze each and every time when played from the start and each of them freezes at its own distinct point. A video that freezes 36 seconds from the start will always freeze at 36 seconds.
I THINK those videos freeze after xx MB of stream delivered [too fast], which supports your Bravia buffer theory.
And I got the impression that videos which have higher bitrates at their very beginning (panning cityscapes, helicopter flights or the like) tend to be those which freeze, even if the maximum bitrate does not exceed the Bravia's capabilities. Videos that start with several calm studio logos tend to be more likely to pass their first minute without interruption.
Post Wed Aug 21, 2013 6:51 pm
You can check the video bitrate with that tool : viewtopic.php?f=17&t=2133
Lowlander
Post Wed Aug 21, 2013 8:39 pm
Ok, here we go, here are my lengthy results. I have to admit I mistyped Bravia 2011 as 2010 when starting the thread. Sorry...
According to Bitrate Viewer my randomly chosen freezing video has an average bitrate of 3607kbps with a peak of 11094 kbps. As I mentioned before, I'm currently in the process of re-encoding almost my entire collection with a different x264 preset (veryslow, because CPU is faster now than it was in former days), and thought high@L3.1 would be even less demanding for the renderer than the old high@L4.1. To my surprise, the freezes still happen with L3.1.
MediaInfo output:
Unique ID                                : 263435537560286597817505566003585349975 (0xC62FD6CA08F9FF68D82415E7057BF957)
Complete name                            : V:\Videos\mm2\Krimis (75001)\Henning Mankell\Mankells Wallander (Serie)\Mankells Wallander S02E08 (HD) - Der Scharfschütze (S D 2009) 130714.HDTV.avc-720p25-crf20-high@L3.1.ac3-2ch-tc.mkv
File size                                : 2.34 GiB
Duration                                 : 1h 27mn
Overall bit rate                         : 3 804 Kbps
Writing application                      : HandBrake 0.9.9
Writing library                          : libmkv 0.6.5
Format profile                           : High@L3.1
Format settings, ReFrames                : 5 frames
Duration                                 : 1h 27mn
Bit rate                                 : 3 537 Kbps
Frame rate                               : 25.000 fps
Bits/(Pixel*Frame)                       : 0.153
Stream size                              : 2.17 GiB (93%)
Writing library                          : x264 core 130 r2273 b3065e6
Encoding settings                        : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=17500 / vbv_bufsize=17500 / crf_max=0.0 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Duration                                 : 1h 27mn
Bit rate                                 : 192 Kbps
Stream size                              : 121 MiB (5%)
Language                                 : German
Serviio debug log 1st start, video freezes after about 30s:
2013-08-21 22:00:39,126 DEBUG [ServiioHttpService] Incoming request from /10.240.11.207:48751: HEAD /resource/65800/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40EX728";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40EX728"; mv="1.7";,Host: 10.240.11.11:8895]]
2013-08-21 22:00:39,126 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.240.11.207
2013-08-21 22:00:39,126 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.240.11.207, Profile=Sony Bravia TV (2011)'
2013-08-21 22:00:39,126 DEBUG [ResourceDeliveryProcessor] Request for resource 65800 and type 'MEDIA_ITEM' received
2013-08-21 22:00:39,126 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 65800 (local)
2013-08-21 22:00:39,126 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 65800)
2013-08-21 22:00:39,126 DEBUG [VideoDAOImpl] Reading a Video (id = 65800)
2013-08-21 22:00:39,126 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 65800, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2011)
2013-08-21 22:00:39,126 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Mankells Wallander S02E08 (HD) - Der Scharfschütze (S D 2009) 130714.HDTV.avc-720p25-crf20-high@L3.1.ac3-2ch-tc.mkv
2013-08-21 22:00:39,126 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Mankells Wallander S02E08 (HD) - Der Scharfschütze (S D 2009) 130714.HDTV.avc-720p25-crf20-high@L3.1.ac3-2ch-tc.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-21 22:00:39,126 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Wed, 21 Aug 2013 20:00:39 GMT,Server: Windows 2003, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-08-21 22:00:39,126 DEBUG [ServiioHttpService] Incoming request from /10.240.11.207:48752: GET /resource/65800/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=0.000-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40EX728";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40EX728"; mv="1.7";,Host: 10.240.11.11:8895]]
2013-08-21 22:00:39,126 DEBUG [VideoDeliveryEngine] Delivering item '65800' for client 'Identifier=10.240.11.207, Profile=Sony Bravia TV (2011)'
2013-08-21 22:00:39,126 DEBUG [VideoDeliveryEngine] Delivering file 'Mankells Wallander S02E08 (HD) - Der Scharfschütze (S D 2009) 130714.HDTV.avc-720p25-crf20-high@L3.1.ac3-2ch-tc.mkv' using transcoding
2013-08-21 22:00:39,126 DEBUG [AbstractTranscodingDeliveryEngine] No other client uses transcoding job of file 'transcoding-temp-65796-sony2011-ORIGINAL.stf', will stop the job
2013-08-21 22:00:39,126 DEBUG [AbstractTranscodingDeliveryEngine] Stopping previous transcoding job of file 'transcoding-temp-65796-sony2011-ORIGINAL.stf'
2013-08-21 22:00:39,142 DEBUG [TranscodingJobListener] Deleted temp file 'E:\temp\Serviio\transcoding-temp-65796-sony2011-ORIGINAL.stf': true
2013-08-21 22:00:39,142 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=10.240.11.207, Profile=Sony Bravia TV (2011)'
2013-08-21 22:00:39,142 DEBUG [MediaItemDAOImpl] Getting file of media item 65800
2013-08-21 22:00:39,142 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: G:\Daten\mm2\videos\Krimis (75001)\Henning Mankell\Mankells Wallander (Serie)\Mankells Wallander S02E08 (HD) - Der Scharfschütze (S D 2009) 130714.HDTV.avc-720p25-crf20-high@L3.1.ac3-2ch-tc.mkv
2013-08-21 22:00:39,142 DEBUG [ProcessExecutor] Starting C:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe -fflags +genpts -threads 2 -i G:\Daten\mm2\videos\Krimis (75001)\Henning Mankell\Mankells Wallander (Serie)\Mankells Wallander S02E08 (HD) - Der Scharfschütze (S D 2009) 130714.HDTV.avc-720p25-crf20-high@L3.1.ac3-2ch-tc.mkv -y -threads 2 -c:v copy -bsf:v h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts E:\temp\Serviio\transcoding-temp-65800-sony2011-ORIGINAL.stf
2013-08-21 22:00:39,642 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2013-08-21 22:00:39,642 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Mankells Wallander S02E08 (HD) - Der Scharfschütze (S D 2009) 130714.HDTV.avc-720p25-crf20-high@L3.1.ac3-2ch-tc.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-21 22:00:39,642 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 65800) as read
2013-08-21 22:00:39,673 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-08-21 22:00:39,673 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-08-21 22:00:39,673 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-08-21 22:00:39,673 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Wed, 21 Aug 2013 20:00:39 GMT,Server: Windows 2003, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=0-5275/5275,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-08-21 22:00:42,845 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2013-08-21 22:00:42,861 DEBUG [ServiioHttpService] Incoming request from /10.240.11.207:48753: GET /resource/65800/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=0.000-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40EX728";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40EX728"; mv="1.7";,Host: 10.240.11.11:8895]]
2013-08-21 22:00:42,861 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.240.11.207
2013-08-21 22:00:42,861 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.240.11.207, Profile=Sony Bravia TV (2011)'
2013-08-21 22:00:42,861 DEBUG [ResourceDeliveryProcessor] Request for resource 65800 and type 'MEDIA_ITEM' received
2013-08-21 22:00:42,861 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 65800 (local)
2013-08-21 22:00:42,861 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 65800)
2013-08-21 22:00:42,861 DEBUG [VideoDAOImpl] Reading a Video (id = 65800)
2013-08-21 22:00:42,861 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 65800, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2011)
2013-08-21 22:00:42,861 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Mankells Wallander S02E08 (HD) - Der Scharfschütze (S D 2009) 130714.HDTV.avc-720p25-crf20-high@L3.1.ac3-2ch-tc.mkv
2013-08-21 22:00:42,861 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Mankells Wallander S02E08 (HD) - Der Scharfschütze (S D 2009) 130714.HDTV.avc-720p25-crf20-high@L3.1.ac3-2ch-tc.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-21 22:00:42,861 DEBUG [VideoDeliveryEngine] Delivering item '65800' for client 'Identifier=10.240.11.207, Profile=Sony Bravia TV (2011)'
2013-08-21 22:00:42,861 DEBUG [VideoDeliveryEngine] Delivering file 'Mankells Wallander S02E08 (HD) - Der Scharfschütze (S D 2009) 130714.HDTV.avc-720p25-crf20-high@L3.1.ac3-2ch-tc.mkv' using transcoding
2013-08-21 22:00:42,861 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=10.240.11.207, Profile=Sony Bravia TV (2011)'
2013-08-21 22:00:42,861 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2013-08-21 22:00:42,861 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 65800) as read
2013-08-21 22:00:42,892 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-08-21 22:00:42,892 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-08-21 22:00:42,892 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-08-21 22:00:42,892 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Wed, 21 Aug 2013 20:00:42 GMT,Server: Windows 2003, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=0-5275/5275,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-08-21 22:00:55,673 DEBUG [SearchManager] Committing search index
2013-08-21 22:01:26,203 DEBUG [SearchManager] Committing search index
2013-08-21 22:01:31,047 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2013-08-21 22:01:33,375 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2nd start, playback resumes at about 30s, manual stop at 1min:
2013-08-21 22:01:37,171 DEBUG [ServiioHttpService] Incoming request from /10.240.11.207:43817: HEAD /resource/65800/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40EX728";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40EX728"; mv="1.7";,Host: 10.240.11.11:8895]]
2013-08-21 22:01:37,171 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.240.11.207
2013-08-21 22:01:37,171 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.240.11.207, Profile=Sony Bravia TV (2011)'
2013-08-21 22:01:37,171 DEBUG [ResourceDeliveryProcessor] Request for resource 65800 and type 'MEDIA_ITEM' received
2013-08-21 22:01:37,171 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 65800 (local)
2013-08-21 22:01:37,171 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 65800)
2013-08-21 22:01:37,171 DEBUG [VideoDAOImpl] Reading a Video (id = 65800)
2013-08-21 22:01:37,171 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 65800, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2011)
2013-08-21 22:01:37,171 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Mankells Wallander S02E08 (HD) - Der Scharfschütze (S D 2009) 130714.HDTV.avc-720p25-crf20-high@L3.1.ac3-2ch-tc.mkv
2013-08-21 22:01:37,171 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Mankells Wallander S02E08 (HD) - Der Scharfschütze (S D 2009) 130714.HDTV.avc-720p25-crf20-high@L3.1.ac3-2ch-tc.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-21 22:01:37,171 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Wed, 21 Aug 2013 20:01:37 GMT,Server: Windows 2003, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-08-21 22:01:37,171 DEBUG [ServiioHttpService] Incoming request from /10.240.11.207:43818: GET /resource/65800/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=0.000-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40EX728";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40EX728"; mv="1.7";,Host: 10.240.11.11:8895]]
2013-08-21 22:01:37,171 DEBUG [VideoDeliveryEngine] Delivering item '65800' for client 'Identifier=10.240.11.207, Profile=Sony Bravia TV (2011)'
2013-08-21 22:01:37,171 DEBUG [VideoDeliveryEngine] Delivering file 'Mankells Wallander S02E08 (HD) - Der Scharfschütze (S D 2009) 130714.HDTV.avc-720p25-crf20-high@L3.1.ac3-2ch-tc.mkv' using transcoding
2013-08-21 22:01:37,171 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=10.240.11.207, Profile=Sony Bravia TV (2011)'
2013-08-21 22:01:37,171 DEBUG [FileBasedTranscodingDeliveryStrategy] Transcoded file 'E:\temp\Serviio\transcoding-temp-65800-sony2011-ORIGINAL.stf' is complete, sending simple stream
2013-08-21 22:01:37,171 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 65800) as read
2013-08-21 22:01:37,328 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-08-21 22:01:37,328 DEBUG [GETMethodProcessor] Stream entity has length: 2722706616
2013-08-21 22:01:37,328 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-08-21 22:01:37,328 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Wed, 21 Aug 2013 20:01:37 GMT,Server: Windows 2003, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=0-5275/5275,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-08-21 22:01:40,952 DEBUG [ServiioHttpService] Incoming request from /10.240.11.207:43820: GET /resource/65800/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=38.720-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40EX728";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40EX728"; mv="1.7";,Host: 10.240.11.11:8895]]
2013-08-21 22:01:40,952 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.240.11.207
2013-08-21 22:01:40,952 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.240.11.207, Profile=Sony Bravia TV (2011)'
2013-08-21 22:01:40,952 DEBUG [ResourceDeliveryProcessor] Request for resource 65800 and type 'MEDIA_ITEM' received
2013-08-21 22:01:40,952 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 65800 (local)
2013-08-21 22:01:40,952 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 65800)
2013-08-21 22:01:40,952 DEBUG [VideoDAOImpl] Reading a Video (id = 65800)
2013-08-21 22:01:40,952 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 65800, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2011)
2013-08-21 22:01:40,952 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Mankells Wallander S02E08 (HD) - Der Scharfschütze (S D 2009) 130714.HDTV.avc-720p25-crf20-high@L3.1.ac3-2ch-tc.mkv
2013-08-21 22:01:40,952 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Mankells Wallander S02E08 (HD) - Der Scharfschütze (S D 2009) 130714.HDTV.avc-720p25-crf20-high@L3.1.ac3-2ch-tc.mkv: AVC_TS_MP_HD_AC3_ISO
2013-08-21 22:01:40,952 DEBUG [VideoDeliveryEngine] Delivering item '65800' for client 'Identifier=10.240.11.207, Profile=Sony Bravia TV (2011)'
2013-08-21 22:01:40,952 DEBUG [VideoDeliveryEngine] Delivering file 'Mankells Wallander S02E08 (HD) - Der Scharfschütze (S D 2009) 130714.HDTV.avc-720p25-crf20-high@L3.1.ac3-2ch-tc.mkv' using transcoding
2013-08-21 22:01:40,952 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=10.240.11.207, Profile=Sony Bravia TV (2011)'
2013-08-21 22:01:40,952 DEBUG [FileBasedTranscodingDeliveryStrategy] Transcoded file 'E:\temp\Serviio\transcoding-temp-65800-sony2011-ORIGINAL.stf' is complete, sending simple stream
2013-08-21 22:01:40,952 DEBUG [GETMethodProcessor] Delivering bytes 20647936 - 50000000000 from transcoded file, based on time range 38.72 - 5275.0
2013-08-21 22:01:40,952 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-08-21 22:01:40,952 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-08-21 22:01:40,952 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Date: Wed, 21 Aug 2013 20:01:40 GMT,Server: Windows 2003, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=38.72-5275/5275,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-08-21 22:01:41,827 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2013-08-21 22:01:56,218 DEBUG [SearchManager] Committing search index
Running to command line yields an input line too long error. Shortening file name, removing the German special character and adding a few quotes gives this report:
ffmpeg started on 2013-08-21 at 22:30:37
Report written to "ffmpeg-20130821-223037.log"
Command line:
"C:\\Program Files (x86)\\Serviio\\lib\\ffmpeg.exe" -fflags +genpts -threads 2 -i "G:\\Daten\\mm2\\videos\\Krimis (75001)\\Henning Mankell\\Mankells Wallander (Serie)\\Wallander.mkv" -y -threads 2 -c:v copy -bsf:v h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts "E:\\temp\\Wallander-ORIGINAL.stf" -report
  configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-libass --enable-librtmp --enable-fontconfig --enable-libfreetype --enable-zlib --enable-libx264 --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-mingw32- --enable-gpl --pkg-config=pkg-config
Splitting the commandline.
Reading option '-fflags' ... matched as AVOption 'fflags' with argument '+genpts'.
Reading option '-threads' ... matched as AVOption 'threads' with argument '2'.
Reading option '-i' ... matched as input file with argument 'G:\Daten\mm2\videos\Krimis (75001)\Henning Mankell\Mankells Wallander (Serie)\Wallander.mkv'.
Reading option '-y' ... matched as option 'y' (overwrite output files) with argument '1'.
Reading option '-c:v' ... matched as option 'c' (codec name) with argument 'copy'.
Reading option '-bsf:v' ... matched as option 'bsf' (A comma-separated list of bitstream filters) with argument 'h264_mp4toannexb'.
Reading option '-c:a' ... matched as option 'c' (codec name) with argument 'copy'.
Reading option '-map' ... matched as option 'map' (set input stream mapping) with argument '0:0'.
Reading option '-map' ... matched as option 'map' (set input stream mapping) with argument '0:1'.
Reading option '-sn' ... matched as option 'sn' (disable subtitle) with argument '1'.
Reading option '-f' ... matched as option 'f' (force format) with argument 'mpegts'.
Reading option 'E:\temp\Wallander-ORIGINAL.stf' ... matched as output file.
Reading option '-report' ... matched as option 'report' (generate a report) with argument '1'.
Finished splitting the commandline.
Parsing a group of options: global .
Applying option y (overwrite output files) with argument 1.
Applying option report (generate a report) with argument 1.
Successfully parsed a group of options.
Parsing a group of options: input file G:\Daten\mm2\videos\Krimis (75001)\Henning Mankell\Mankells Wallander (Serie)\Wallander.mkv.
Opening an input file: G:\Daten\mm2\videos\Krimis (75001)\Henning Mankell\Mankells Wallander (Serie)\Wallander.mkv.
[matroska,webm @ 036CBF80] Format matroska,webm probed with size=2048 and score=100
st:0 removing common factor 1000000 from timebase
st:1 removing common factor 1000000 from timebase
[matroska,webm @ 036CBF80] File position before avformat_find_stream_info() is 4652
[h264 @ 01B3B600] no picture
[matroska,webm @ 036CBF80] All info found
[matroska,webm @ 036CBF80] File position after avformat_find_stream_info() is 14071
Input #0, matroska,webm, from 'G:\Daten\mm2\videos\Krimis (75001)\Henning Mankell\Mankells Wallander (Serie)\Wallander.mkv':
  Duration: 01:27:55.32, start: 0.000000, bitrate: 3804 kb/s
    Stream #0:0(eng), 4, 1/1000: Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 1k tbn, 50 tbc (default)
    Stream #0:1(ger), 9, 1/1000: Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s (default)
Successfully opened the file.
Parsing a group of options: output file E:\temp\Wallander-ORIGINAL.stf.
Applying option c:v (codec name) with argument copy.
Applying option bsf:v (A comma-separated list of bitstream filters) with argument h264_mp4toannexb.
Applying option c:a (codec name) with argument copy.
Applying option map (set input stream mapping) with argument 0:0.
Applying option map (set input stream mapping) with argument 0:1.
Applying option sn (disable subtitle) with argument 1.
Applying option f (force format) with argument mpegts.
Opening an output file: E:\temp\Wallander-ORIGINAL.stf.
[mpegts @ 03821740] muxrate VBR, pcr every 2 pkts, sdt every 200, pat/pmt every 40 pkts
Output #0, mpegts, to 'E:\temp\Wallander-ORIGINAL.stf':
    encoder         : Lavf55.9.100
    Stream #0:0(eng), 0, 1/90000: Video: h264, yuv420p, 1280x720 [SAR 1:1 DAR 16:9], q=2-31, 25 fps, 90k tbn, 25 tbc (default)
    Stream #0:1(ger), 0, 1/90000: Audio: ac3, 48000 Hz, stereo, 192 kb/s (default)
Stream mapping:
  Stream #0:0 -> #0:0 (copy)
  Stream #0:1 -> #0:1 (copy)
frame=  761 fps=0.0 q=-1.0 size=    9031kB time=00:00:30.46 bitrate=2428.5kbits/s
frame= 3392 fps=3289 q=-1.0 size=   69631kB time=00:02:15.64 bitrate=4205.1kbits/s
frame= 5031 fps=3252 q=-1.0 size=  102739kB time=00:03:21.24 bitrate=4182.1kbits/s
frame= 6297 fps=3053 q=-1.0 size=  139090kB time=00:04:11.90 bitrate=4523.3kbits/s
frame= 8089 fps=3138 q=-1.0 size=  174409kB time=00:05:23.58 bitrate=4415.4kbits/s
frame= 9823 fps=3175 q=-1.0 size=  209823kB time=00:06:32.92 bitrate=4374.5kbits/s
frame=11536 fps=3196 q=-1.0 size=  245009kB time=00:07:41.50 bitrate=4349.1kbits/s
frame=13324 fps=3230 q=-1.0 size=  280424kB time=00:08:52.92 bitrate=4310.6kbits/s
frame=14967 fps=3225 q=-1.0 size=  314057kB time=00:09:58.68 bitrate=4297.3kbits/s
frame=16818 fps=3262 q=-1.0 size=  347375kB time=00:11:12.73 bitrate=4230.0kbits/s
frame=18370 fps=2130 q=-1.0 size=  380721kB time=00:12:14.94 bitrate=4243.7kbits/s
frame=19823 fps=2169 q=-1.0 size=  413446kB time=00:13:12.92 bitrate=4271.5kbits/s
frame=21423 fps=2219 q=-1.0 size=  447860kB time=00:14:16.92 bitrate=4281.4kbits/s
frame=23275 fps=2288 q=-1.0 size=  481691kB time=00:15:30.97 bitrate=4238.6kbits/s
frame=25053 fps=2344 q=-1.0 size=  516749kB time=00:16:42.14 bitrate=4224.2kbits/s
frame=26940 fps=2405 q=-1.0 size=  550505kB time=00:17:57.60 bitrate=4185.0kbits/s
frame=28840 fps=2461 q=-1.0 size=  584831kB time=00:19:13.56 bitrate=4153.1kbits/s
frame=30498 fps=2493 q=-1.0 size=  618513kB time=00:20:19.93 bitrate=4153.4kbits/s
frame=32222 fps=2527 q=-1.0 size=  652648kB time=00:21:28.89 bitrate=4148.1kbits/s
frame=33836 fps=2551 q=-1.0 size=  686703kB time=00:22:33.50 bitrate=4156.2kbits/s
frame=35368 fps=2566 q=-1.0 size=  720927kB time=00:23:34.78 bitrate=4174.4kbits/s
frame=37024 fps=2590 q=-1.0 size=  753783kB time=00:24:40.99 bitrate=4169.5kbits/s
frame=38734 fps=2615 q=-1.0 size=  787010kB time=00:25:49.44 bitrate=4161.0kbits/s
frame=40488 fps=2642 q=-1.0 size=  820438kB time=00:26:59.48 bitrate=4150.1kbits/s
frame=42316 fps=2671 q=-1.0 size=  855088kB time=00:28:12.70 bitrate=4138.3kbits/s
frame=43971 fps=2688 q=-1.0 size=  887754kB time=00:29:18.84 bitrate=4134.8kbits/s
frame=45580 fps=2701 q=-1.0 size=  921765kB time=00:30:23.16 bitrate=4141.7kbits/s
frame=45580 fps=2491 q=-1.0 size=  921765kB time=00:30:23.20 bitrate=4141.7kbits/s
frame=46781 fps=2487 q=-1.0 size=  955747kB time=00:31:11.26 bitrate=4184.1kbits/s
frame=48377 fps=2503 q=-1.0 size=  990191kB time=00:32:15.10 bitrate=4191.8kbits/s
frame=50271 fps=2533 q=-1.0 size= 1024659kB time=00:33:30.84 bitrate=4174.4kbits/s
frame=52180 fps=2563 q=-1.0 size= 1058151kB time=00:34:47.26 bitrate=4153.0kbits/s
frame=54134 fps=2593 q=-1.0 size= 1091240kB time=00:36:05.37 bitrate=4128.4kbits/s
frame=55809 fps=2609 q=-1.0 size= 1125027kB time=00:37:12.38 bitrate=4128.4kbits/s
frame=57391 fps=2620 q=-1.0 size= 1159880kB time=00:38:15.64 bitrate=4139.0kbits/s
frame=58991 fps=2631 q=-1.0 size= 1194294kB time=00:39:19.64 bitrate=4146.2kbits/s
frame=60750 fps=2649 q=-1.0 size= 1228973kB time=00:40:30.08 bitrate=4143.0kbits/s
frame=62420 fps=2662 q=-1.0 size= 1262412kB time=00:41:36.80 bitrate=4142.0kbits/s
frame=63785 fps=2661 q=-1.0 size= 1297300kB time=00:42:31.42 bitrate=4165.3kbits/s
frame=65373 fps=2670 q=-1.0 size= 1331173kB time=00:43:34.94 bitrate=4170.3kbits/s
frame=66915 fps=2677 q=-1.0 size= 1365177kB time=00:44:36.60 bitrate=4178.2kbits/s
frame=68342 fps=2679 q=-1.0 size= 1400118kB time=00:45:33.66 bitrate=4195.7kbits/s
frame=70076 fps=2692 q=-1.0 size= 1433616kB time=00:46:43.04 bitrate=4189.8kbits/s
frame=71453 fps=2692 q=-1.0 size= 1467508kB time=00:47:38.14 bitrate=4206.2kbits/s
frame=73339 fps=2710 q=-1.0 size= 1500438kB time=00:48:53.56 bitrate=4190.0kbits/s
frame=74985 fps=2719 q=-1.0 size= 1534848kB time=00:49:59.39 bitrate=4192.0kbits/s
frame=76641 fps=2728 q=-1.0 size= 1568457kB time=00:51:05.69 bitrate=4191.2kbits/s
frame=78505 fps=2744 q=-1.0 size= 1602789kB time=00:52:20.22 bitrate=4181.2kbits/s
frame=79999 fps=2747 q=-1.0 size= 1636932kB time=00:53:19.96 bitrate=4190.6kbits/s
frame=81831 fps=2761 q=-1.0 size= 1670968kB time=00:54:33.24 bitrate=4182.0kbits/s
frame=83913 fps=2783 q=-1.0 size= 1703870kB time=00:55:56.54 bitrate=4158.5kbits/s
frame=85778 fps=2797 q=-1.0 size= 1737016kB time=00:57:11.10 bitrate=4147.2kbits/s
frame=87189 fps=2796 q=-1.0 size= 1771719kB time=00:58:07.58 bitrate=4161.6kbits/s
frame=88781 fps=2800 q=-1.0 size= 1805113kB time=00:59:11.26 bitrate=4164.0kbits/s
frame=90174 fps=2799 q=-1.0 size= 1839556kB time=01:00:06.94 bitrate=4178.0kbits/s
frame=91447 fps=2794 q=-1.0 size= 1873623kB time=01:00:57.88 bitrate=4196.1kbits/s
frame=92986 fps=2797 q=-1.0 size= 1906927kB time=01:01:59.42 bitrate=4200.0kbits/s
frame=92986 fps=2732 q=-1.0 size= 1906927kB time=01:01:59.45 bitrate=4200.0kbits/s
frame=94550 fps=2737 q=-1.0 size= 1938669kB time=01:03:01.98 bitrate=4199.3kbits/s
frame=96190 fps=2743 q=-1.0 size= 1971750kB time=01:04:07.61 bitrate=4198.1kbits/s
frame=96253 fps=2705 q=-1.0 size= 1973034kB time=01:04:10.14 bitrate=4198.0kbits/s
frame=98095 fps=2718 q=-1.0 size= 2006429kB time=01:05:23.80 bitrate=4189.0kbits/s
frame=98096 fps=2648 q=-1.0 size= 2006434kB time=01:05:23.80 bitrate=4189.0kbits/s
frame=99679 fps=2654 q=-1.0 size= 2036402kB time=01:06:27.16 bitrate=4184.0kbits/s
frame=101166 fps=2657 q=-1.0 size= 2068874kB time=01:07:26.65 bitrate=4188.2kbits/s
frame=101215 fps=2623 q=-1.0 size= 2070127kB time=01:07:28.60 bitrate=4188.7kbits/s
frame=102660 fps=2625 q=-1.0 size= 2104041kB time=01:08:26.40 bitrate=4197.4kbits/s
frame=102660 fps=2564 q=-1.0 size= 2104041kB time=01:08:26.43 bitrate=4197.4kbits/s
frame=104174 fps=2568 q=-1.0 size= 2137103kB time=01:09:26.97 bitrate=4201.4kbits/s
frame=105954 fps=2579 q=-1.0 size= 2171005kB time=01:10:38.14 bitrate=4196.4kbits/s
frame=106221 fps=2554 q=-1.0 size= 2177044kB time=01:10:48.86 bitrate=4197.4kbits/s
frame=108014 fps=2565 q=-1.0 size= 2209668kB time=01:12:00.57 bitrate=4189.6kbits/s
frame=108014 fps=2510 q=-1.0 size= 2209668kB time=01:12:00.60 bitrate=4189.6kbits/s
frame=109836 fps=2522 q=-1.0 size= 2241591kB time=01:13:13.40 bitrate=4179.7kbits/s
frame=111236 fps=2525 q=-1.0 size= 2277489kB time=01:14:09.44 bitrate=4193.2kbits/s
frame=111313 fps=2497 q=-1.0 size= 2279595kB time=01:14:12.54 bitrate=4194.1kbits/s
frame=112887 fps=2503 q=-1.0 size= 2311268kB time=01:15:15.48 bitrate=4193.1kbits/s
frame=112888 fps=2451 q=-1.0 size= 2311276kB time=01:15:15.48 bitrate=4193.1kbits/s
frame=112888 fps=2297 q=-1.0 size= 2311276kB time=01:15:15.52 bitrate=4193.1kbits/s
frame=112955 fps=2047 q=-1.0 size= 2312674kB time=01:15:18.20 bitrate=4193.1kbits/s
frame=114597 fps=2057 q=-1.0 size= 2344517kB time=01:16:23.90 bitrate=4189.9kbits/s
frame=116229 fps=2068 q=-1.0 size= 2376887kB time=01:17:29.18 bitrate=4188.1kbits/s
frame=118009 fps=2080 q=-1.0 size= 2408405kB time=01:18:40.38 bitrate=4179.7kbits/s
frame=119712 fps=2091 q=-1.0 size= 2441121kB time=01:19:48.44 bitrate=4176.2kbits/s
frame=121059 fps=2096 q=-1.0 size= 2472731kB time=01:20:42.36 bitrate=4183.2kbits/s
frame=122677 fps=2105 q=-1.0 size= 2505914kB time=01:21:47.10 bitrate=4183.4kbits/s
frame=124247 fps=2113 q=-1.0 size= 2537491kB time=01:22:49.88 bitrate=4182.6kbits/s
frame=125979 fps=2124 q=-1.0 size= 2569343kB time=01:23:59.16 bitrate=4176.9kbits/s
frame=127698 fps=2134 q=-1.0 size= 2601837kB time=01:25:07.93 bitrate=4172.8kbits/s
frame=127698 fps=2108 q=-1.0 size= 2601837kB time=01:25:07.96 bitrate=4172.7kbits/s
frame=129349 fps=2117 q=-1.0 size= 2631701kB time=01:26:13.98 bitrate=4166.8kbits/s
frame=129350 fps=2082 q=-1.0 size= 2631703kB time=01:26:13.98 bitrate=4166.8kbits/s
No more output streams to write to, finishing.
frame=131883 fps=2072 q=-1.0 Lsize= 2658893kB time=01:27:55.24 bitrate=4129.0kbits/s
video:2322653kB audio:123637kB subtitle:0 global headers:0kB muxing overhead 8.690848%
0 frames successfully decoded, 0 decoding errors
[AVIOContext @ 038212E0] Statistics: 0 seeks, 220412 writeouts
[AVIOContext @ 036D4760] Statistics: 2508545677 bytes read, 1 seeks
Lowlander
Post Mon Aug 26, 2013 12:33 pm
Re: Bravia 2011 picture freeze after 30 to 60 seconds
if someone is knowledgeable enough to look through my logfiles above, he might be able to answer this easy :o additional questions:
- Can we assume that keeping within the limits of profile high@L3.1 will restrict video bandwith enough to safely feed complex scenes to Bravias?
- I've read somewhere that it is wise to keep RefFrames below 6 to please Bravias. If this is true :?: and we use x264's --preset veryslow (which by default gives a much higher number of RefFrames) and we restrict RefFrames with --ref 4 as the only custom option, will this contradict other x264 options set by the --preset veryslow, rendering the encoding settings inconsistent? The command line options might look like so: --preset veryslow --tune film --profile high --level 31 --ref 5
CU
Low
| Serviio Pro 1.6 (Win Server 2008 R2, Athlon 240e, 4GB RAM, 6TB HDD) |
| Sony KDL-42W829B | Sony KDL-24EX320 | Yamaha BD-S677 | assorted iDevices |
Post Mon Aug 26, 2013 1:08 pm
If you look at this :
http://wiki.serviio.org/doku.php?id=get_h264_level
1280x720 with 5reframes :
dpbMbs = (1280* 720 * 5 ) / 256 = 18000 exactly match to 3.1 level MaxDpbMbs value (18000)
Lowlander
Post Mon Aug 26, 2013 1:26 pm
I've spent quite a bit of time looking AVC specifications, and do not fully understand yet if I do have to stay within high@L3.1 specs to please the Bravias or if it's enough to restrict bandwidth and RefFrames (--vbv-bufsize=17500 --vbv-maxrate=17500 --ref 5 ) while encoding with high@L4.1 otherwise.
I'm not even sure if there is any "otherwise" anyway, i.e. if a high@L4.1 file that is encoded with bandwidth and RefFrames restrictions already is high@L3.1 and could as well be flagged as such. Having a second look at the Mediainfo output a few posts above: The file already is within high@L3.1 specs, and still it freezes.
Did you find any hints in my logs that I'm actually having a video bandwidth issue here? The Bravias becoming unresponsive to pause/play commands looks pretty much like it.
Lowlander
Post Wed Aug 28, 2013 5:18 pm
I re-encoded my chosen testfile in the flavours high@L3.1 and main@L3.1, each in versions with 5 and 4 RefFrames, and all four resulting files freeze, each at its own distinctive point. Still can't figure out which encoding parameter makes the files so hard to digest for Bravias. :?
Post Wed Aug 28, 2013 6:44 pm
What is your encoder tool ? Could you post the complete command line used ?
Lowlander
Post Wed Aug 28, 2013 7:30 pm
I use Vidcoder, which is an alternative frontend for Handbrake and unfortunately does not show what the actual x264 command line looks like. According to the logfile, the following x264 parameters are passed on to Handbrake:
[20:47:56]    + encoder: H.264 (x264)
[20:47:56]      + x264 preset: veryslow
[20:47:56]      + x264 tune: film
[20:47:56]      + options: ref=5
[20:47:56]      + h264 profile: high
[20:47:56]      + h264 level: 3.1
[20:47:56]      + quality: 20.00 (RF)
which in MediaInfo reads as
Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=17500 / vbv_bufsize=17500 / crf_max=0.0 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Lowlander
Post Fri Aug 30, 2013 7:26 am
I think I'll give up on this. :(
I did countless encodes of my testfiles now and got a few mkvs that play without freezing, but when I look into MediaInfo, the Encoding settings of those file which play and those which don't are identical to the last digit. The safest bet seems to be high@L3.1 with ref=5, but I've seen files with those settings freeze while ref=9 or high@L4.1 files (from another source) play.
Thanks for looking into the issue.
Lowlander
Post Sun Sep 01, 2013 8:50 pm
:shock: Damn! It's the server. :shock: What a load of time wasted with encodes and re-encodes, testing parameters and stuff...
I've set up a second Serviio instance today on my Windows workstation and added the server's video directories to the new library as paths. All those videos that have a distinctive point within their first minute where they used to freeze play flawlessly when streamed to the Bravias from the new Serviio.
When streaming such a file from its own Serviio installation, some hard- or software component on the server apparently goes into saturation within the first minute. CPU is fine at 5-6%, because the files are just remuxed. The harddisk, SATA port, driver etc. are the very same components that deliver the same files to the other Serviio instance running on the workstation. And still, there's a difference.
Post Mon Sep 02, 2013 5:48 am
:shock: Look at NIC, network interface controller too... or Java installation...
Lowlander
Post Mon Sep 02, 2013 7:58 am
Short version: I switched the transcoding temp path from SSD to oldschool hdd, and the problem went away. Old files, new files, you name it, everything smooth.
Illico, if you are still with me, can you see anything from the log I posted above that points to an I/O-bottleneck?
Post Mon Sep 02, 2013 12:10 pm
Lowlander wrote:Illico, if you are still with me, can you see anything from the log I posted above that points to an I/O-bottleneck?
No, sorry, I see anything...
But your post is interesting, I already read something post about SSD disk limitation...but where..?
Lowlander
Post Mon Sep 02, 2013 8:44 pm
Thank you very much for looking through my logs again!
I swapped my OCZ Agility 3 series SSD for an Intel 330 today, and this one doesn't seem to have any problems with holding Serviio's tempdir.
Could be pretty tricky to find out what went wrong all the time. I'll check the OCZ drive for faults in another computer tomorrow, but if it's ok, I don't think it's worth digging deeper. Among other things, I've read that my nForce 630a mainboard chipset and its S-ATA drivers are not doing too well with SSDs in general. I'll see what I can find out.
Lowlander
Post Wed Sep 04, 2013 12:05 pm
Ok, I dug a bit deeper, for those interested. :geek:
The OCZ Agility 3 SSD and the Intel 330 use the same internal controller (STF 2281) and the same storage technology (MLC NAND), so basically there should be no major difference in how well the motherboard and the drivers handle them.
I did a firmware upgrade 2.15 > 2.25 to the OCZ, did a secure erase and put it back in the server using a new data cable. I restored the partitions with a little space (about 5%) unpartitioned. I've read that this overprovisioning is needed for SSDs that are heavily written to. Not sure if this is relevant for Windows Server 2003 at all or if OCZ has already overprovisioned, but it didn't do any harm to give up 5% capacity.
It put Serviio's transcoding tempdir back in the SSD, no more problems so far.
@mods: What do we do with this thread, which I started quite misleading, as it wasn't a Sony issue after all?
Post Wed Sep 04, 2013 1:48 pm
Edit your first post and change the title to whatever you'd like (or leave it as is, and add [SOLVED: Caused by SSD] or something like that...).
NX3
Post Sat Sep 07, 2013 9:19 am
Re: [SOLVED: Caused by SSD] Bravia picture freeze
Just FYI I have my Serviio temp folder on a SSD (relatively old Verbatim 64gb) as it helped improve FF / RW for me massively to Bravia 2011 tv. You got unlucky with your i/o issue I'd suggest
Users browsing this forum: Google [Bot] and 28 guests
