Sony BDP-S470 can't play any AVI
notbananas
Post Sun Sep 08, 2013 6:36 pm
Just upgraded to 1.3.1 hoping it will fix this problem. Sony BDP-S470 will not show any AVI files in folder. It said "There is no playable file". I have a Sharp Aquos 80" LCD TV which works fine with AVI. Unfortunately the Sharp cannot play any MKV files. I get the same message with the sharp: "There is no playable file" on all MKV types.
This was a problem with the previous version as well. I like to get the Sony to work with AVI files. What can I do?
Post Sun Sep 08, 2013 6:37 pm
Re: Sony BDP-S470 can't play any AVI
What is the profile selected on serviio console ?
notbananas
Post Sun Sep 08, 2013 6:44 pm
Appears to be correct profile:
Sony BDP-Sx70/SMP-N100 (2010)
Post Mon Sep 09, 2013 7:08 am
OK, and do you try with "Sony BDP-Sx70/SMP-N100 (2010) - US" ?
notbananas
Post Mon Sep 09, 2013 7:58 am
That fixed problem! Now all formats work fine.
Question is why did the other one get selected? I depend on the software to detect the correct one, but I guess in this case it didn't.
Thank you very much for your help.
Post Mon Sep 09, 2013 11:19 am
notbananas wrote:That fixed problem! Now all formats work fine.
Serviio can't distinguish EU vs US Sony BDP model, then EU profile is used by default.
But EU profile delivers AVI files in native format, and there is sometime problems with fourcc element that Sony device does not support (DX50,XVID,etc).
With the US profile, all avi will be transcoded so that solved your problem.
Enjoy-it.
Users browsing this forum: Baidu [Spider] and 7 guests
