apostrophe being stripped from file title
Karnith
Post Tue Sep 03, 2013 10:29 pm
I was watching my movies when I hit a snag in the last video of a series. I can verify that a comma in the title causes ffmpeg to fail in transcoding.
Version: 1.3.1
2013-09-03 15:18:45,903 DEBUG [VideoDeliveryEngine] Delivering item '3319' for client 'Identifier=192.168.1.1, Profile=Sony Bravia TV (2010)'
2013-09-03 15:18:45,903 DEBUG [MediaItemDAOImpl] Getting file of media item 3319
2013-09-03 15:18:45,905 DEBUG [SubtitlesService] Found external subtitle file: /media/Media/Anime/Words Worth/Words Worth - Episode 5 Glimmer's End (2000)/Words Worth - Episode 5 Glimmer's End.srt
2013-09-03 15:18:45,906 DEBUG [MediaItemDAOImpl] Getting file of media item 3319
2013-09-03 15:18:45,908 DEBUG [SubtitlesService] Found external subtitle file: /media/Media/Anime/Words Worth/Words Worth - Episode 5 Glimmer's End (2000)/Words Worth - Episode 5 Glimmer's End.srt
2013-09-03 15:18:45,908 DEBUG [VideoDeliveryEngine] Delivering file 'Words Worth - Episode 5 Glimmer's End.mkv' using transcoding
2013-09-03 15:18:45,908 DEBUG [MediaItemDAOImpl] Getting file of media item 3319
2013-09-03 15:18:45,911 DEBUG [SubtitlesService] Found external subtitle file: /media/Media/Anime/Words Worth/Words Worth - Episode 5 [color=#40BF00]Glimmer's[/color] End (2000)/Words Worth - Episode 5 Glimmer's End.srt
2013-09-03 15:18:45,914 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.1.1, Profile=Sony Bravia TV (2010)'
2013-09-03 15:18:45,916 DEBUG [MediaItemDAOImpl] Getting file of media item 3319
2013-09-03 15:18:45,919 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: /media/Media/Anime/Words Worth/Words Worth - Episode 5 Glimmer's End (2000)/Words Worth - Episode 5 Glimmer's End.mkv
2013-09-03 15:18:45,920 DEBUG [ProcessExecutor] Starting /usr/local/bin/ffmpeg -threads auto -i /media/Media/Anime/Words Worth/Words Worth - Episode 5 Glimmer's End (2000)/Words Worth - Episode 5 Glimmer's End.mkv -y -threads auto -c:v mpeg2video -b:v 17000k -maxrate:v 17000k -bufsize:v 17000k -vf pad=1280:720:160:0:black,setdar=4:3,subtitles=filename='/media/Media/Anime/Words Worth/Words Worth - Episode 5 [color=#40BF00]Glimmer\\\\\'s[/color] End (2000)/Words Worth - Episode 5 Glimmer\\\\\'s End.srt':original_size=960x720:charenc=UTF-8 -r 30000/1001 -g 15 -c:a ac3 -b:a 384k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts /tmp/Serviio/transcoding-temp-3319-sony2010-ORIGINAL-5facc9f32ad0c795c86afe4a1ef4b8db.stf
2013-09-03 15:18:46,096 WARN  [ProcessExecutor] Process /usr/local/bin/ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
Stream #0:3(eng): Subtitle: subrip (default)
[Parsed_setdar_1 @ 0x1f861a0] num:den syntax is deprecated, please use num/den or named options instead
[Parsed_subtitles_2 @ 0x202b580] Unable to open /media/Media/Anime/Words Worth/Words Worth - Episode 5 [color=#BF0040]Glimmer\\s[/color] End (2000)/Words Worth - Episode 5 Glimmer\s End.srt:original_size=960x720:charenc=UTF-8
[AVFilterGraph @ 0x1fe1160] Error initializing filter 'subtitles' with args 'filename=/media/Media/Anime/Words Worth/Words Worth - Episode 5 [b][color=#800040]Glimmer\\\\\s[/color][/b] End (2000)/Words Worth - Episode 5 Glimmer\\'s End.srt:original_size=960x720:charenc=UTF-8'
Error opening filters!
2013-09-03 15:18:46,096 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2013-09-03 15:18:46,521 DEBUG [ServiioHttpService] Incoming request from /192.168.1.1:35598: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-52NX800";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-52NX800"; mv="1.7";,Host: 192.168.1.14:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 649,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2013-09-03 15:18:46,522 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.1
2013-09-03 15:18:46,523 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.1
2013-09-03 15:18:46,523 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.1
2013-09-03 15:18:46,530 DEBUG [ContentDirectory] Browse() called for renderer KDL-52NX800 (profile sony2010) with parameters: objectID = V_T^INI_87, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:class,res@resolution,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 20, count = 10, sortCriteria =
2013-09-03 15:18:46,530 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-09-03 15:18:46,530 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2013-09-03 15:18:46,547 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-09-03 15:18:47,933 DEBUG [ServiioHttpService] Incoming request from /192.168.1.1:35599: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-52NX800";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-52NX800"; mv="1.7";,Host: 192.168.1.14:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 649,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2013-09-03 15:18:47,934 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.1
2013-09-03 15:18:47,935 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.1
2013-09-03 15:18:47,936 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.1
2013-09-03 15:18:47,953 DEBUG [ContentDirectory] Browse() called for renderer KDL-52NX800 (profile sony2010) with parameters: objectID = V_T^INI_87, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:class,res@resolution,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 30, count = 10, sortCriteria =
2013-09-03 15:18:47,953 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-09-03 15:18:47,954 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2013-09-03 15:18:47,960 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-09-03 15:18:55,945 DEBUG [TranscodingJobListener] Deleted temp file '/tmp/Serviio/transcoding-temp-3319-sony2010-ORIGINAL-5facc9f32ad0c795c86afe4a1ef4b8db.stf': true
2013-09-03 15:18:55,946 DEBUG [AbstractTranscodingDeliveryEngine] Removing transcoding listener with id transcoding-temp-3319-sony2010-ORIGINAL-5facc9f32ad0c795c86afe4a1ef4b8db.stf
2013-09-03 15:18:55,947 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
   at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:49)
   at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:134)
   at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:110)
   at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:153)
   at org.serviio.delivery.GETMethodProcessor.retrieveResource(GETMethodProcessor.java:121)
   at org.serviio.delivery.GETMethodProcessor.buildDeliveryContainer(GETMethodProcessor.java:48)
   at org.serviio.delivery.AbstractMethodProcessor.handleRequest(AbstractMethodProcessor.java:100)
   at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:81)
   at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:86)
   at org.serviio.upnp.webserver.ServiioHttpService.doService(ServiioHttpService.java:77)
Thanks,
Karnith
Post Wed Sep 04, 2013 9:51 pm
Re: apostrophe being stripped from file title
What is the actual srt file path?
Karnith
Post Sat Sep 07, 2013 5:25 pm
video file path = /media/Media/Anime/Words Worth/Words Worth - Episode 5 Glimmer's End (2000)/Words Worth - Episode 5 Glimmer's End.mkv
srt file path = /media/Media/Anime/Words Worth/Words Worth - Episode 5 Glimmer's End (2000)/Words Worth - Episode 5 Glimmer's End.srt
Just wanted to note that in the media browser the video plays but no subtitles and via dlna video file won't play regardless if srt is present or not. For the time being I removed the apostrophe from srt and video file name so that everythig will work over dnla and media browser.
Thanks,
Karnith
Post Sun Sep 08, 2013 6:45 pm
Thanks, I'll investigate
Post Sun Sep 15, 2013 3:33 pm
Fixed for 1.4
Users browsing this forum: No registered users and 51 guests
