Enable burned-in subs - Cannot Access the server
R3dBull
Post Sun Sep 08, 2013 4:05 pm
I have in the same file the movie (mp4) and under the same name the srt file. On Serviio console under Delivery Subtitles tab, the box Enable burned-in subtitles is not checked in. When try to play the movie on my Sony tv then the movie plays well but without subs (normal). If I tick the box on the console to enable subs and try to restart the movie in ordr to watch it with subs, then on my tv appears a message Temporarily cannot access the server. Please retry.
I will need some help on that.
Thanks in advance.
R3dBull
Post Sun Sep 08, 2013 5:44 pm
Re: Enable burned-in subs - Cannot Access the server
Just to mention that I am using win xp and I have followed your instructions from
http://wiki.serviio.org/doku.php?id=win_ffmpeg. I downloaded the the 32-bit static builds from http://ffmpeg.zeranoe.com/builds/. Inside the folder \bin I found the ffmpeg.exe which I used to replace the ffmpeg.exe in my folder C:\Program Files\Serviio\lib\. My movies with enabled burned-in subs still dont play.
Thank you
R3dBull
Post Sun Sep 08, 2013 5:45 pm
Finally, I tried also instructions for ffmpeg from http://www.wikihow.com/Install-FFmpeg-on-Windows but didnt help me too.
R3dBull
Post Sun Sep 08, 2013 7:10 pm
another weird, if burned-in subs box is ticked but there is no srt file in the folder but just the move then it plays normal...
Post Sun Sep 08, 2013 7:11 pm
post detailed log of when this happens
R3dBull
Post Sun Sep 08, 2013 7:14 pm
I attach my serviio log too
(98.01 KiB) Downloaded 577 times
Post Mon Sep 09, 2013 7:12 am
Could you remove the "[1080p]" on file path, force library refresh and retry?
R3dBull
Post Mon Sep 09, 2013 5:38 pm
I did it but no luck yet. I attach new log file plus some screenshots from console
untitled.TIF
untitled.TIF (113.79 KiB) Viewed 9765 times
untitled2.TIF
untitled2.TIF (114.33 KiB) Viewed 9765 times
(165.99 KiB) Downloaded 611 times
R3dBull
Post Mon Sep 09, 2013 7:17 pm
I removed the 1080p and encode subs again using microsoft word and notepad++ to utf8 and now I can play the movie and view the subs...but...the movie now stuck, playing in frames every 3 secs. Do you know why? If I play the movie without the subs everything looks fine. I removed the tick from "enable transcoding" but still the same. Any suggestions?
Thank you all
untitled4.TIF
untitled4.TIF (113.39 KiB) Viewed 9762 times
