UE40F6470 - Mac problems
Akira
Post Mon Sep 09, 2013 9:14 am
Hi there,
first of all thanks for the support forum. I've just discovered your software yesterday and think it's great.
Except I have a problem getting it running properly.
I open the console on my mac.
Serviio detects my Samsung TV right away. I can access Serviio though my TV too. No problem.
However, once I go to Library and use the "Add local" function, I can't choose any files.
For instance I can choose a folder saying "Series X".
Once I click on it there is a list off all episodes:
for example:
"Series XE01"
"Series XE02" and so on.
But all files are grey and unavailable to select.
I have the same problem with all files on my Mac - jpeg, mkv, avi, vob doesn't matter.
I can see them, but not select them.
The folder I'm trying to access is open to everyone. The DLNA profile is set to Samsung TV C/D/E Series without restriction.
Any idea?
Thanks a lot.
Post Mon Sep 09, 2013 9:19 am
Re: UE40F6470 - Mac problems
You need to add the Folder, not individual files. Once you have set the type of files it contains (video, music and/or photos), and press Save. Press force refresh (and if you like Show Status). Serviio will scan the folder you enter, and all subfolders, for media files.
Akira
Post Mon Sep 09, 2013 9:50 am
Damn, that was an easy fix.
Much appreciated DenyAll !!!
You've made my day!
Regards
Post Mon Sep 09, 2013 11:49 am
:D :D :D
You're welcome - and welcome aboard!
Users browsing this forum: Google [Bot] and 10 guests
