refresh media list
gael25m@gmail.com
Post Sun Sep 08, 2013 10:38 pm
refresh media list
I have problem when I delete my movies directory Serviio.
The files are still visible on my tv with xbmc
Thank you for your help
Best regards
gael
Post Tue Sep 10, 2013 1:46 am
Re: refresh media list
Ensure you refresh your library in Serviio (press Force Refresh from Serviio Console). This will remove the file from the Serviio database.
It also may be that the TV is caching the content list from Serviio - the way to check is to turn the TV off and on and see if the deleted media is still there (if it isn't it points to the TV having cached the content list - powering off/on clears the cache). If this is the case look for options that clear the cache on your TV. If none, it may unfortunately just be something that you have to live with on that TV.
Users browsing this forum: Google [Bot] and 44 guests
