No files found (video, audio, photo)
nfgb
Post Sat Sep 14, 2013 3:25 pm
I have serviio 1.3.1 installed on a raspberry pi and it works great on my tablet (except for subtitles) but on my samsung es5500 it doesn't show any files for all media types. And after trying for sometime it will simply give a message saying the device is disconnected.
It should't be a TV problem as it works fine with minidlna. I've search the detailed log but I didn't find any message which would give me a clue.
I attached an excerpt from the log file which contains the messages of the tv connection.
I know there are lots of similar posts but I've already read all these posts below and they weren't of any help:
viewtopic.php?f=5&t=8812
viewtopic.php?f=11&t=10273
viewtopic.php?f=10&t=8469
viewtopic.php?f=5&t=38
viewtopic.php?f=14&t=10470
viewtopic.php?f=11&t=2560
viewtopic.php?f=5&t=9330
viewtopic.php?f=5&t=9562
viewtopic.php?f=5&t=5073
viewtopic.php?f=5&t=6290
Can anyone give me a help?
pc5dczc_log.txt
Detailed log
(47.97 KiB) Downloaded 393 times
Post Sun Sep 15, 2013 6:21 pm
Re: No files found (video, audio, photo)
Can you see the main categories (e.g. Videos / Folders / Movies)?
Did you filter out the detailed log? If yes, provide a full one showing you going to an empty category.
Also make sure to select the right file type in Samsung's main menu (ie Videos -> Videos (Serviio folder)), otherwise the TV filters out all other file types (ie you will not see any video files when you browse Audio on the TV)
nfgb
Post Wed Sep 18, 2013 12:59 pm
After choosing media type in the TV doesn't show anything else.
I didn't filter the log, I just cutted from the time I connect the tv and stop trying to connect to facilitate its analysis.
I'm sureI select the right folders.
Meanwhile I found this thread viewtopic.php?f=5&t=6253, where someone mentioned removing some files and it worked fine then.
I removed all the files fom the library except the online resources (which was my main objective using serviio) it worked.
I have noticed in the log that serviio complained about some very common files like mp3, avi, etc which are supported by my tv (i've tested with minidlna).
I thought the only effect was to ignore these files and not to mess up the whole library.
I guess for now I'll be using serviio along with minidlna just for online resources util I find a way to get serviio working with the other files so can fully replace minidlna. It must be a problem with the profile, as it may be trying to transcode files which are already supported by the tv.
Post Thu Sep 19, 2013 4:21 pm
If you could post the log where it was complaining, maybe I can help / fix it for next release.
nfgb
Post Mon Sep 23, 2013 12:33 am
Here's part of the log where it complains about mp3, mp4, mkv, wmv, flac,...
pc5dczc_log2.txt
(15.35 KiB) Downloaded 473 times
Post Thu Sep 26, 2013 4:05 pm
what if you execute this
ffmpeg -i "/mnt/hd1/media/video/filmes/500 Days Of Summer (2009)/Audio 2 ch/(500) Days Of Summer audio track 2 ch.mp4"
viewtopic.php?f=5&t=1123
nfgb
Post Thu Sep 26, 2013 10:53 pm
I get this:
ffmpeg version git-2013-09-07-64c54f8 Copyright (c) 2000-2013 the FFmpeg developers
built on Sep 7 2013 17:06:36 with gcc 4.6 (Debian 4.6.3-14+rpi1)
configuration: --arch=armel --target-os=linux --enable-gpl --enable-libx264 --enable-nonfree --enable-libaacplus --enable-librtmp --enable-libmp3lame
libavutil 52. 43.100 / 52. 43.100
libavcodec 55. 31.101 / 55. 31.101
libavformat 55. 16.101 / 55. 16.101
libavdevice 55. 3.100 / 55. 3.100
libavfilter 3. 84.100 / 3. 84.100
libswscale 2. 5.100 / 2. 5.100
libswresample 0. 17.103 / 0. 17.103
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/mnt/hd1/media/video/filmes/500 Days Of Summer (2009)/Audio 2 ch/(500) Days Of Summer audio track 2 ch.mp4':
major_brand : mp42
minor_version : 0
compatible_brands: M4A mp42isomndia
creation_time : 2009-11-05 08:16:39
encoder : Nero AAC codec / 1.3.3.0
Duration: 01:35:04.63, start: 0.000000, bitrate: 129 kb/s
Chapter #0.0: start 0.054667, end 5704.629678
title :
Stream #0:0(und): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 127 kb/s (default)
handler_name : Sound Media Handler
Post Fri Sep 27, 2013 8:06 pm
It shows no Video track in the output, so Serviio ignores it.
Can you try with a different FFmpeg (eg on Windows)?
nfgb
Post Sat Sep 28, 2013 6:10 pm
Here it is. It seems that it has detected video now. I gess I'll have to find another ffmpeg binaries for raspberry pi.
ffmpeg version N-56704-g3e0c78b Copyright (c) 2000-2013 the FFmpeg developers
built on Sep 27 2013 18:01:57 with gcc 4.8.1 (GCC)
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av
isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab
le-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetyp
e --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --ena
ble-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-l
ibopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libsp
eex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aa
cenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavp
ack --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
libavutil 52. 46.100 / 52. 46.100
libavcodec 55. 33.101 / 55. 33.101
libavformat 55. 18.104 / 55. 18.104
libavfilter 3. 87.100 / 3. 87.100
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'P:\hd1\media\video\filmes\500 Days Of S
ummer (2009)\(500) Days Of Summer.mp4':
major_brand : isom
minor_version : 1
compatible_brands: isom
creation_time : 2009-11-04 07:48:55
Duration: 01:35:04.64, start: 0.000000, bitrate: 2083 kb/s
Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1280x544
[SAR 1:1 DAR 40:17], 1749 kb/s, 23.98 fps, 23.98 tbr, 66893 tbn, 47.95 tbc (defa
ult)
creation_time : 2009-11-04 01:00:23
handler_name : GPAC ISO Video Handler
Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 48000 Hz, 5.1, fltp, 330 k
b/s (default)
creation_time : 2009-11-04 07:49:18
handler_name : GPAC ISO Audio Handler
Post Wed Oct 02, 2013 7:55 pm
Yes, this one is fine
nfgb
Post Fri Oct 04, 2013 6:11 pm
I've compiled a recent version of ffmpeg but still cannot play this particular file. However most of files are added to the library (at least that what it seems according to the log).
The original issue still remains, but what I found out is that when serviio has only added a few files it works fine, then after adding all files to the library it stops working (i.e shows no files). It must be a matter of amount of files or maybe an issue concerning a particular file.
Users browsing this forum: No registered users and 75 guests
