CBS.com (US Only)
mike_metro
Post Wed Sep 11, 2013 11:13 pm
Re: CBS.com (US Only)
Updated the main file link to the latest version. Thanks much leo1981.
Apostate
Post Sun Sep 15, 2013 3:09 am
I've been using Serviio for a while now but I just discovered the joy of Serviio plugins. I've installed two plugins: cbs and discovery channel. The discovery channel works beautifully. The CBS, on the other hand, has some issues. I get video but no audio.
FYI, I have Sharp TV. The plugin didn't seem to work with that renderer profile so I've modified the original online transcoding script by cutting and pasting various scripts from other renderer profiles without avail.
I am about to pull my hair out. Any help and/or insight would be appreciated.
Xmantium
Post Sun Sep 15, 2013 6:50 am
@Apostate, which country are you from?
Please provide your logs, should show errors if videos are not there.
Use the latest v7 from the main post - viewtopic.php?f=20&t=5401
Apostate
Post Sun Sep 15, 2013 8:01 pm
Xmantium wrote:@Apostate, which country are you from?
I am in US. I am using the latest plugin. Specifically, I am trying to view Hawaii Five-O. The videos are there. I am able to see the video. The problem is I don't hear the audio.
I've tried to transcode the whatever audio in the video stream to ac3 and mp3, tried to limit the audio and video bitrate with no luck.
Where and how do I access the logs?
Thanks!
Apostate
Post Fri Sep 20, 2013 3:27 am
Thank you, Xmantium. I figured out how to check the log but I didn't see any errors. Nonetheless, I finally managed to get the audio working. Apparently, Sharp Aquos renderer profile was missing some media format profiles for mp4. I copied the media format profiles for mp4 from the generic DLNA section and pasted them into Sharp Aquos profile and, voila, everything is as should be. :D
jidrobbins
Post Thu Sep 26, 2013 2:06 am
Apostate wrote:Thank you, Xmantium. I figured out how to check the log but I didn't see any errors. Nonetheless, I finally managed to get the audio working. Apparently, Sharp Aquos renderer profile was missing some media format profiles for mp4. I copied the media format profiles for mp4 from the generic DLNA section and pasted them into Sharp Aquos profile and, voila, everything is as should be. :D
Apostste can you explain how to do this? I am streaming through a Sony BDV-E570, and am having the same audio issue (video seems to work fine, just no sound). I downloaded the new plugin V7. Windows 8 is my OS. Thanks in advance for the help!!
(Log file attached)
(edit 9/26/13): Appears to be either a Plugin issue or a CBS issue as I tried using the iPad app "AcePlayer" with the same results - video but no audio. Hulu streams and video from my hard drive work fine on both iPad and Blu-Ray player.
(314.88 KiB) Downloaded 1858 times
Thank you everyone involved in developing Serviio and the Plugins!!
SYSTEM INFO:
Using Serviio 1.4 to stream to my Sony BDV-E570 Blu-Ray via
wireless network using a Netgear N600 Wireless-N modem
My computer (connected directly to my Roadrunner broadband cable modem):
Dell Inspiron
Processor Intel(R) Core(TM) i7-3632QM CPU @ 2.20GHz
Memory (RAM) 8.00 GB
Windows 8 (64-bit operating system)
Apostate
Post Sat Sep 28, 2013 9:57 pm
My apologies for not replying sooner, jidrobbins. I've been out of town for the past week.
What I did was copy the following from generic DLNA profile to the media format profile section in Sharp profile:
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_AAC_MULT5</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_MPEG1_L3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_AC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_HD_720p_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_HD_1080i_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_HP_HD_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_LPCM</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_ASP_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_SP_L6_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_NDSD</MediaFormatProfile>
Save and restart Serviio service and you should be good to go. I run Windows 7 but hopefully it will work for you as well.
P.s. You know to stop the service before changing profile, etc., right?
drestauro
Post Wed Oct 02, 2013 5:29 am
This thing works like a charm on my X-box, but on my Vizio Smart TV I can see the show listed but when I try to play it nothing happens. Not even an error in the log. I'm using the Vizio Profile. Any ideas on what I can try?
Drestauro @ Grounded Reason
jidrobbins
Post Thu Oct 03, 2013 3:30 am
Apostate wrote:My apologies for not replying sooner, jidrobbins. I've been out of town for the past week.
Thanks for the reply! That might be a bit advanced for me :D are those changes made to the plugin?
SYSTEM INFO:
Dell Inspiron
jidrobbins
Post Mon Oct 07, 2013 10:21 pm
I'm still getting no sound on CBS shows. I looked at my log (attached) and I'm getting this:
2013-10-07 18:04:39,046 WARN [WebResourceParser] Plugin CBS.com returned no value for resource item 'null'
Does anyone know how to fix this? Thanks
(11.19 KiB) Downloaded 1852 times
SYSTEM INFO:
Dell Inspiron
leo1981
Post Wed Oct 09, 2013 3:07 am
This is not a plugin issue.
You need to use the right profile for your TV from the Serviio interface.
Try the one for your TV model, and if it doesn't work use the generic.
If that doesn't work, you need to edit the profiles.xml file in the Serviio config folder.
jidrobbins
Post Mon Oct 14, 2013 3:35 am
leo1981 wrote:This is not a plugin issue.
I ended up reinstalling Serviio and now I'm getting sound again.
SYSTEM INFO:
Dell Inspiron
funguide
Post Mon Dec 09, 2013 12:05 am
I git hawaii five 0 and other shows to work. All these shows show the url format
%%http://www.cbs.com/shows/hawaii_five_0/video/
on the CBS website and work fine but can anyone tell me how to get the 'tv classics' section to work. Wanted to watch Enterprise and they have all the seasons on CBS but can't get the episodes with the above URL format.
On the TV it shows the error 'CBS:carousel ID not found'
leo1981
Post Mon Dec 09, 2013 9:19 pm
Can you please share a link to one of the shows that doesn't work?
EDIT: Nevermind, I found them.
n9lya
Post Wed Feb 12, 2014 9:45 pm
Hello.. Been on here a while reading up. Finally got Serviio working.. However one thing I need is CBS. I have tried all the CBS.Groovys files in this thread.. I think... I cannot get them to work. Anyone care to tell me what I may be doing wrong, and which cbs.groovy is the correct one.. I have a Sony BDP-s5100 Actually 2... I cannot get any thing from CBS to load.. I do have the system set for web resources...
Registered Copy.. Thanks... Dumped DISHNET yesterday. !
Jerry
Mitchell IN USA.....
Todays log
(276.25 KiB) Downloaded 1922 times
Xmantium
Post Sat Feb 15, 2014 12:29 am
Version 7 on the main post is the latest - download/file.php?id=4181
Plugin working fine for me
Looking at you log is says
2014-02-11 18:13:36,936 INFO [PluginCompilerThread] Added Web Resouce plugin CBS.com (CBS.groovy), version: 1
you have version 1 installed, just copy over version 7
DrJay
Post Mon Apr 07, 2014 1:22 am
Is it me, or are the CBS links down/changed ? I checked tonight and haven't been able to get any playable files on any CBS programs. They were playing last week.
DrJay
Post Tue Apr 08, 2014 6:00 pm
DrJay wrote:Is it me, or are the CBS links down/changed ? I checked tonight and haven't been able to get any playable files on any CBS programs. They were playing last week.
Never mind. Sunday and Monday kept getting "no playable files" . Today all of the CBS shows are now available. Not sure what happened, but things are back to normal on CBS feeds.
Any hope for NBC or ABC ?
Dvalin21
Post Sat Apr 12, 2014 4:56 am
Hey I can't the plugins to work. Am I suppose to do one at a time or is there something else I have to do other than put them in the plugin folder?
Sent from my BLU Life View using Tapatalk
Using Tapatalk
drestauro
Post Sat Nov 01, 2014 6:23 pm
Has anyone figured out the guid they added to the web URL since they introduced their "service"?
Return to Available plugins
