streaming online feeds to wdtv
vincetownson
Post Sun Sep 15, 2013 11:07 pm
hey all,
I am having problems streaming online content, more specifically hockeystreams to my wd tv live gen 3. I also have a ps3 which works perfectly fine. The wdtv live works for the first few seconds then it goes mute and slowmotion. I've compared the CPU usages when using both units. When using the ps3 the CPU usage for ffmpeg is only about 3% but when I try streaming the exact same feed on the wdtv, the CPU usage for ffmpeg is closer to 300%. I don't know if it has something to do with the profiles for wdtv for if its trying transcode the video, either way, I really want to figure out whats going on here. Any help or suggestions for be really appriciated.
thanks
Vince.
Post Tue Sep 17, 2013 10:42 pm
Re: streaming online feeds to wdtv
post ffmpeg -i "stream url"
vincetownson
Post Wed Sep 18, 2013 12:37 am
I'm sorry for my lack on knowledge, but I do not know what you are saying or telling me to do. post ffmpeg -i "stream url"?
vincetownson
Post Wed Sep 18, 2013 12:47 am
I think what you're asking me to do is to post the url of the stream im trying to watch. if this is the case, I cannot because it is a secured stream..
Post Thu Sep 19, 2013 4:17 pm
no, I need you to post the output of the ffmpeg command above (you can remove/change the stream URL before posting it here).
vincetownson
Post Sat Sep 21, 2013 5:05 am
ok...next question is how the heck do I do that..believe it or not, i'm not that dumb, but I don't know exactly how to get that information. FYI, I'm running osx
Post Mon Sep 23, 2013 8:39 pm
Users browsing this forum: No registered users and 51 guests
