I need help setting up XBox 360 live stream
jamesgrey
Post Mon Sep 16, 2013 4:41 pm
I have a live stream playing on VLC (aceplayer), which I pass to an HTTP stream which is accessible via my pc.
I set up the link as http://192.168.1.102:8203/tv.asf
102 is the address of my pc.
If I launch this link WMP plays the live stream perfectly.
I have inserted this link into the SERVIIO console Online Sources. I also validated the link and a check mark became green.
I go to the xbox and launch the online sources directory and click the above link, but it fails to launch. It waits a few seconds an error says connection to your computer was lost, make sure your computer is turned on.
Is this not the correct method to launch a live stream??
I tried the FFMPEG test and it runs and shows me stream info but at the end in red it says "at least one output file must be specified"
Thanks for the help.
Post Thu Sep 19, 2013 4:15 pm
Re: I need help setting up XBox 360 live stream
Post detailed log trying to play the file.
Also post result of
ffmpeg -i "stream url"
jamesgrey
Post Fri Sep 20, 2013 5:51 pm
Okay here is the log file, as well I have the screen ffmpeg - i output.
Thanks for helping.
FFMPEG Output File.txt
(9.16 KiB) Downloaded 404 times
Serviio log file
(33.44 KiB) Downloaded 387 times
Post Mon Sep 23, 2013 8:34 pm
There is nothing in the log suggesting you tried to play the file, are you sure you did it right?
jamesgrey
Post Tue Sep 24, 2013 1:10 am
Ooops sorry about that here is the LOG after I try and run the file from the Xbox.
It starts opening then errors out.
Thanks again for assisting.
Let me know if I can supply more info.
(11.21 KiB) Downloaded 383 times
Post Thu Sep 26, 2013 8:23 am
It's not detailed log . There should be a lot of DEBUG statements.
jamesgrey
Post Thu Sep 26, 2013 12:16 pm
One of those weeks, I forgot to restart Serviio.
I checked before I uploaded this time and DEBUG info is present.
Thanks Zip.
(208.86 KiB) Downloaded 398 times
Post Fri Sep 27, 2013 11:27 am
How long does it take to start this command and create the output.asf file?
ffmpeg.exe -analyzeduration 10000000 -threads auto -i http://192.168.1.102:8903/tv.asf -y -threads auto -c:v wmv2 -b:v 15360k -maxrate:v 15360k -bufsize:v 15360k -vf scale=1024:576,setsar=1 -r 25 -g 15 -c:a wmav2 -b:a 128k -ac 1 -map 0:1 -map 0:0 -sn -f asf output.asf
jamesgrey
Post Fri Sep 27, 2013 12:07 pm
It took 10 seconds before the first line that says "frame= 56 fps=0.0 q=2.0 size= 569kB time=00:00:02.37 bitrate=1967.4kbits/s" appears in the output line.
I have attached the output file of this FFmpeg run as well.
FFmpeg-sept27.txt
(7.21 KiB) Downloaded 402 times
Post Fri Sep 27, 2013 8:23 pm
Try to set
keepStreamOpen="true"
on the OnlineTranscoding element of the profile.
jamesgrey
Post Fri Sep 27, 2013 10:22 pm
Changed setting under xbox 360 to <OnlineTranscoding keepStreamOpen="true"> in file profiles.xml.
Same issue. Attached new Logs.
Thank You
(88.66 KiB) Downloaded 395 times
FFmpeg-sept28.txt
(11.95 KiB) Downloaded 435 times
Post Sat Sep 28, 2013 10:43 am
Hmm... the XBox rejected the stream immediately. This device seems very picky with the live streams ( I never had problems during testing, but some other users did). Do other online streams (ie not local) work for you?
jamesgrey
Post Sat Sep 28, 2013 2:47 pm
I am able to get SOME live streams through the Windows Media Center app through the xbox, which I am streaming from online on my pc through Sopcast. I have been unable to get any of these streams even to play through Serviio however.
Do you have an xbox for development purposes?
Post Sun Sep 29, 2013 11:25 pm
yes I do
jamesgrey
Post Mon Sep 30, 2013 6:40 pm
Petr do you feel that there may be hope to getting the xbox 360 live stream working at all? Or is it a hopeless platform and the better option would be picking up a used WD Live?
The stupid thing is I bought a new Roku recently, and that can't live stream either no DLNA compliance I believe, so with the Xbox lying around and it being DLNA I figured give it a go.
If you have any other thoughts on things we could try as well I would gladly do that to try and get it working.
Post Tue Oct 01, 2013 1:25 pm
I had problems with it, so it's a bit dodgy. It's not really DLNA compliant (just UPnP AFAIK).
Roku - search the forum for Chaneru, it should be a DLNA plugin for Roku which works with Serviio (hopefully including live streams)
jamesgrey
Post Tue Oct 01, 2013 3:16 pm
Unfortunately my understanding is that the latest Chaneru still does not support live streams yet.
