Sorting order
sleky
Post Thu Sep 19, 2013 6:05 pm
Sorting order
Is it possible to get the sort order to use The as part of the name of the movie?
For example... It currently lists the movies like so:
The Abyss
Ted
The Aviator
But when I think of it alphabetically, it should read as so:
Ted
The Abyss
The Aviator
Is that a simple option to change? TIA! =D
Post Thu Sep 19, 2013 11:37 pm
Re: Sorting order
Not a current option. The word "The" is simply ignored when sorting - so your sort order at the moment should be:
The Abyss
The Aviator
Battleships
Ted
My two cents - I prefer it the way it is, otherwise in a large library you get a whole lot of movies sorted under "The" which doesn't add a lot of value. But perhaps a user option to include it or not might be a worthwhile feature request.
sleky
Post Fri Sep 20, 2013 1:09 pm
Re: Sorting order
Wasn't sure if that was something that could be configured at the moment. I hadn't seen it anywhere. I agree however! For normal, day to day browsing and using I would say omitting "the" "a" preceding title'd words like that do not add benefit when trying to find a movie. I would strongly agree. But adding and trying to figure out what movies aren't showing when I have 600+ movies is a PITA when the alphabetized sorting isn't alphabetized. Not all the way. ;D I just took the longer route, and circled back thru with "the"s. Hehe, works for me fine now, rather get cycles spun on more important requests. Thanks again!!!!!!!
Users browsing this forum: Google [Bot] and 44 guests
