Plugin Frustration
rverhoeve
Post Sun Sep 22, 2013 10:50 pm
Plugin Frustration
i am having an terrible time trying to get plugins to work. the only one that i have had success with is Veetle. all others attempted, CNN, TuneIn, PBSKids, Vevo, etc. all produce the same 'plugin not found' error message. can someone please offer some concreted examples of what works for a URL ? i have been going into the groovy plugin to see what may be required, but 1) in don't know groovy, and 2) there doesn't seem to be a standard that says what URL to use to get these things working. thanks, in advance...
i am on Serviio 1.2.1 on a QNAP TS-212 running with Java 7.
error message in Serviio log as follows:
2013-09-22 18:41:05,654 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Cannot parse resource from http://tunein.com/radio. Message: No plugin for web resource http://tunein.com/radio has been found.
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:179)
2013-09-22 18:41:06,017 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Cannot parse resource from http://www.vevo.com. Message: No plugin for web resource http://www.vevo.com has been found.
2013-09-22 18:41:13,326 WARN [ServiioStatusService] ValidationException occured. Returning error code 400 to the REST layer. Message: null
2013-09-22 18:41:59,157 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2013-09-22 18:41:59,159 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2013-09-22 18:41:59,161 INFO [PlaylistMaintainerThread] Finished looking for playlist changes
2013-09-22 18:41:59,386 INFO [PlaylistMaintainerThread] Started looking playlist changes
2013-09-22 18:41:59,390 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-09-22 18:41:59,396 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-09-22 18:42:00,016 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (pbskids.org): A JSON payload should start with an openning curly brace '{' or an openning square bracket '['.
Instead, '"This portal has been disabled."' was found on line: 1, column: 1
at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:58)
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:171)
Caused by: groovy.json.JsonException: A JSON payload should start with an openning curly brace '{' or an openning square bracket '['.
at groovy.json.JsonSlurper.parse(JsonSlurper.java:79)
at groovy.json.JsonSlurper.parseText(JsonSlurper.java:59)
at groovy.json.JsonSlurper$parseText.call(Unknown Source)
at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:108)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)
at PBSKids.extractItems(PBSKids.groovy:60)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:32)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:29)
at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
at java.util.concurrent.FutureTask.run(FutureTask.java:166)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:722)
Post Sun Sep 22, 2013 11:43 pm
Re: Plugin Frustration
Try them one at a time - for example I understand the PBSKids plugin is broken.
For Vevo, do you have it in as a web resource? Here is my ServiioLink for it (never done this before - I believe you just click on it):
:serviiolink: serviio://video:web?url=http%3A%2F%2Fww ... &name=Vevo
<Edit>Restart Serviio and check the top part of your log file to ensure the plugins are being compiled. You should see something like:
2013-09-19 23:48:01,667 INFO [PluginCompilerThread] Added Web Resouce plugin VevoBeta (VevoBeta.groovy), version: 20
If not, are you sure they're in the correct location? </edit>
Post Mon Sep 23, 2013 2:07 pm
Log implies that the plugins were not added to the plugins folder.
rverhoeve
Post Mon Sep 23, 2013 10:37 pm
here is my log at startup. does it not show that the plugins are being loaded?? the /plugins/ directory has 98 plugins in it... am i supposed to do something else to make them 'load' ??
Note also that Vevobeta.groovy is showing an error, so they must be being loaded ??
how about you send me the details for a plugin that you have working, and i'll try to re-create it on my end... again, so far the only one that i can find that works is Veetle. ... the rest seem dead.
my process is:
1) go to the Serviio console.
2) go to libary > online sources tab
3) click add, select Source Type: Web Resource (should match the plugin definition), put in the url: that i can usually find in the plugin in the Source URL (there should be a standard for plugin documentation and examples to be in the comments at the top of the plugin, showing one url that actually works), key-in a display name, set the Media Type to video, and click Add. done.
in a few minutes, if it works like Veetle, it is available on my Sony TV.
please tell me what i am doing wrong in this process.
2013-09-23 18:22:18,305 INFO [MediaServer] ------------------------------------------------------------------------
2013-09-23 18:22:18,311 INFO [MediaServer] Serviio DLNA media streaming server v 1.2.1 (rev. a2aa56064460+)
2013-09-23 18:22:18,312 INFO [MediaServer] Petr Nejedly 2009-2013
2013-09-23 18:22:18,312 INFO [MediaServer] http://www.serviio.org
2013-09-23 18:22:18,312 INFO [MediaServer] Java 1.7.0_21-Oracle Corporation
2013-09-23 18:22:18,313 INFO [MediaServer] OS Linux arm 2.6.33.2
2013-09-23 18:22:18,314 INFO [MediaServer] File encoding: UTF-8
2013-09-23 18:22:18,317 INFO [MediaServer] Headless mode enabled: true
2013-09-23 18:22:18,318 INFO [MediaServer] User: admin
2013-09-23 18:22:18,318 INFO [MediaServer] User home dir: /share/homes/admin
2013-09-23 18:22:18,318 INFO [MediaServer] Temp dir: /root/.serviio/tmp
2013-09-23 18:22:18,319 INFO [MediaServer] ------------------------------------------------------------------------
2013-09-23 18:22:19,378 INFO [WebServer] Socket buffer set to 65535 bytes
2013-09-23 18:22:19,392 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-09-23 18:22:19,761 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-09-23 18:22:19,763 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-09-23 18:22:19,885 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-09-23 18:22:31,170 INFO [Device] Created UPnP Device with UUID: 1c04cfd6-5c62-3e32-a9e2-63e87daff0e6, bound address: 192.168.0.36
2013-09-23 18:22:32,386 INFO [MediaServer] ------------------------------------------------------------------------
2013-09-23 18:22:32,387 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2013-09-23 18:22:32,388 INFO [MediaServer] ------------------------------------------------------------------------
2013-09-23 18:22:38,217 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2013-09-23 18:22:38,833 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2013-09-23 18:22:38,902 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2013-09-23 18:22:38,923 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2013-09-23 18:22:38,930 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2013-09-23 18:22:38,940 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2013-09-23 18:22:38,963 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2013-09-23 18:22:38,984 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2013-09-23 18:22:38,987 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2013-09-23 18:22:39,023 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2013-09-23 18:22:39,031 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2013-09-23 18:22:39,048 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2013-09-23 18:22:39,051 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2013-09-23 18:22:39,053 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2013-09-23 18:22:39,057 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2013-09-23 18:22:39,072 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2013-09-23 18:22:39,074 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2013-09-23 18:22:39,077 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2013-09-23 18:22:39,079 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2013-09-23 18:22:39,093 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2013-09-23 18:22:39,096 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2013-09-23 18:22:39,099 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2013-09-23 18:22:39,114 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2013-09-23 18:22:39,117 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2013-09-23 18:22:39,120 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2013-09-23 18:22:39,133 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2013-09-23 18:22:39,138 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2013-09-23 18:22:39,140 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2013-09-23 18:22:39,144 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2013-09-23 18:22:39,150 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2013-09-23 18:22:39,152 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2013-09-23 18:22:39,155 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2013-09-23 18:22:39,157 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2013-09-23 18:22:39,160 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2013-09-23 18:22:39,172 INFO [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2013-09-23 18:22:39,349 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2013-09-23 18:22:39,354 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2013-09-23 18:22:39,357 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2013-09-23 18:22:39,360 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2013-09-23 18:22:39,729 INFO [PluginCompilerThread] Looking for plugins at /share/HDA_DATA/.qpkg/Serviio/plugins
2013-09-23 18:22:39,761 INFO [UpdateChecker] Checking if a new version is available
2013-09-23 18:22:39,731 INFO [PluginCompilerThread] Started looking for plugins
2013-09-23 18:22:41,122 WARN [FFMPEGWrapper] FFmpeg is not compiled with libass support, rendering subtitles (hardsubs) will not work.
2013-09-23 18:22:43,125 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-09-23 18:22:43,511 INFO [WebServer] WebServer starting on port 8895
2013-09-23 18:22:43,661 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-09-23 18:22:43,664 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-09-23 18:22:43,668 INFO [EventDispatcher] Starting EventDispatcher
2013-09-23 18:22:43,675 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (eth0) and address 192.168.0.36, timeout = 0
2013-09-23 18:22:43,720 INFO [RendererSearchSender] Searching for Renderer devices
2013-09-23 18:22:43,721 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2013-09-23 18:22:48,106 INFO [PluginCompilerThread] Added Feed plugin Arte (Arte.groovy), version: 1
2013-09-23 18:22:48,857 INFO [PluginCompilerThread] Added Feed plugin ARD Mediathek RSS Extractor (ARDMediathek.groovy), version: 1
2013-09-23 18:22:51,364 INFO [PluginCompilerThread] Added Web Resouce plugin Walla (Walla.groovy), version: 1
2013-09-23 18:22:52,480 INFO [PluginCompilerThread] Added Web Resouce plugin pbskids.org (PBSKids.groovy), version: 1
2013-09-23 18:22:53,933 INFO [PluginCompilerThread] Added Web Resouce plugin Disney.com (Disney.groovy), version: 1
2013-09-23 18:22:55,607 INFO [PluginCompilerThread] Added Web Resouce plugin ComedyCentral (ComedyCentral.groovy), version: 1
2013-09-23 18:22:56,417 INFO [PluginCompilerThread] Added Feed plugin BlipTVUrlExtractor (BlipTVUrlExtractor.groovy), version: 1
2013-09-23 18:22:57,329 INFO [PluginCompilerThread] Added Web Resouce plugin CBS.com (CBS.groovy), version: 7
2013-09-23 18:22:57,974 INFO [PluginCompilerThread] Added Feed plugin LiveFeeds (LiveFeeds.groovy), version: 1
2013-09-23 18:22:59,075 INFO [PluginCompilerThread] Added Web Resouce plugin RedTube (RedTube.groovy), version: 3
2013-09-23 18:22:59,393 INFO [PluginCompilerThread] Added Feed plugin DailyMotion (DailyMotion.groovy), version: 1
2013-09-23 18:23:00,147 INFO [PluginCompilerThread] Added Web Resouce plugin zengatv.com (ZengaTV.groovy), version: 1
2013-09-23 18:23:02,832 INFO [PluginCompilerThread] Added Web Resouce plugin 4OD (UK only) (Channel4od.groovy), version: 1
2013-09-23 18:23:07,787 INFO [PluginCompilerThread] Added Web Resouce plugin myiplayer.com (MyiPlayer.groovy), version: 1
2013-09-23 18:23:09,185 INFO [PluginCompilerThread] Added Web Resouce plugin discovery.com (Discovery.groovy), version: 1
2013-09-23 18:23:09,893 INFO [PluginCompilerThread] Added Web Resouce plugin Castalba (Castalba.groovy), version: 5
2013-09-23 18:23:09,991 INFO [FeedUpdaterThread] Started looking for information about online resources
2013-09-23 18:23:10,011 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-09-23 18:23:10,289 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-09-23 18:23:10,291 INFO [PlaylistMaintainerThread] Started looking playlist changes
2013-09-23 18:23:11,137 INFO [PluginCompilerThread] Added Web Resouce plugin Sopcast (Sopcast.groovy), version: 5
2013-09-23 18:23:12,613 INFO [PluginCompilerThread] Added Feed plugin WAT (WAT.groovy), version: 13
2013-09-23 18:23:13,408 INFO [PluginCompilerThread] Added Feed plugin Hypem (Hypem.groovy), version: 1
2013-09-23 18:23:14,980 INFO [PluginCompilerThread] Added Web Resouce plugin XVIDEOS (XVIDEOS.groovy), version: 1
2013-09-23 18:23:15,010 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
2013-09-23 18:23:15,814 INFO [PluginCompilerThread] Added Feed plugin SnotrUrlExtractor (Snotr.groovy), version: 1
2013-09-23 18:23:17,597 INFO [PluginCompilerThread] Added Feed plugin Tv4Play (Tv4Play.groovy), version: 1
2013-09-23 18:23:20,935 INFO [PluginCompilerThread] Added Web Resouce plugin Pluzz (Pluzz.groovy), version: 15
2013-09-23 18:23:21,473 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video file type.
2013-09-23 18:23:24,019 INFO [PluginCompilerThread] Added Web Resouce plugin zonytvcom.info (ZonyTV.groovy), version: 1
2013-09-23 18:23:24,344 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video file type.
2013-09-23 18:23:25,381 INFO [PluginCompilerThread] Added Feed plugin Gulli (Gulli.groovy), version: 1
2013-09-23 18:23:26,923 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video file type.
2013-09-23 18:23:27,840 INFO [PluginCompilerThread] Added Web Resouce plugin TrailerAddict (TrailerAddict.groovy), version: 15
2013-09-23 18:23:29,287 INFO [PluginCompilerThread] Added Web Resouce plugin EightTracks (EightTracks.groovy), version: 1
2013-09-23 18:23:30,433 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video file type.
2013-09-23 18:23:33,211 INFO [PluginCompilerThread] Added Web Resouce plugin M6 group channels replay (M6group.groovy), version: 3
2013-09-23 18:23:33,281 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video file type.
2013-09-23 18:23:39,066 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video file type.
2013-09-23 18:23:40,112 INFO [PluginCompilerThread] Added Web Resouce plugin TouTV (TouTV.groovy), version: 1
2013-09-23 18:23:42,141 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video file type.
2013-09-23 18:23:42,564 INFO [PluginCompilerThread] Added Web Resouce plugin veetle.com (Veetle.groovy), version: 1
2013-09-23 18:23:46,522 INFO [PluginCompilerThread] Added Feed plugin ABC iView (Australia only) (ABCiView.groovy), version: 1
2013-09-23 18:23:54,454 INFO [PluginCompilerThread] Added Web Resouce plugin skysportsplus (SkysportsPlus.groovy), version: 24
2013-09-23 18:23:57,154 INFO [PluginCompilerThread] Added Web Resouce plugin APVideo (APVideo.groovy), version: 5
2013-09-23 18:23:59,468 INFO [PluginCompilerThread] Added Web Resouce plugin Uitzending Gemist (uzg.groovy), version: 1
2013-09-23 18:24:00,939 INFO [PluginCompilerThread] Added Web Resouce plugin Omroep NL (OmroepNL.groovy), version: 1
2013-09-23 18:24:02,547 INFO [PluginCompilerThread] Added Web Resouce plugin CONECTATE (CONECTATE.groovy), version: 1
2013-09-23 18:24:05,520 WARN [PluginCompilerThread] Plugin VevoBeta.groovy failed to compile: startup failed:
/share/HDA_DATA/.qpkg/Serviio/plugins/VevoBeta.groovy: 90: unable to resolve class YouTube
@ line 90, column 16.
return new YouTube().extractUrl(links, requestedQuality)
1 error
2013-09-23 18:24:06,823 INFO [PluginCompilerThread] Added Web Resouce plugin TED (TED.groovy), version: 1
2013-09-23 18:24:08,303 INFO [PluginCompilerThread] Added Web Resouce plugin cwtv.com (CW.groovy), version: 1
2013-09-23 18:24:11,124 INFO [PluginCompilerThread] Added Web Resouce plugin Syfy.com (Syfy.groovy), version: 3
2013-09-23 18:24:12,828 INFO [PluginCompilerThread] Added Web Resouce plugin Beeg (Beeg.groovy), version: 11
2013-09-23 18:24:14,647 INFO [PluginCompilerThread] Added Web Resouce plugin HDTrailers (HDTrailers.groovy), version: 11
2013-09-23 18:24:19,049 INFO [PluginCompilerThread] Added Web Resouce plugin SvtPlay (SvtPlay.groovy), version: 9
2013-09-23 18:24:19,467 INFO [PluginCompilerThread] Added Feed plugin Orf (Orf.groovy), version: 1
2013-09-23 18:24:20,255 INFO [PluginCompilerThread] Added Web Resouce plugin Escapist (Escapist.groovy), version: 1
2013-09-23 18:24:21,632 INFO [PluginCompilerThread] Added Feed plugin RTVE (RTVE.groovy), version: 1
2013-09-23 18:24:22,690 INFO [PluginCompilerThread] Added Feed plugin Yahoo Movies (YahooMovies.groovy), version: 1
2013-09-23 18:24:23,665 INFO [PluginCompilerThread] Added Feed plugin YouTube (Youtube.groovy), version: 1
2013-09-23 18:24:24,719 INFO [PluginCompilerThread] Added Web Resouce plugin Nickelodeon (Nickelodeon.groovy), version: 1
2013-09-23 18:24:26,044 INFO [PluginCompilerThread] Added Feed plugin Hulu (US only) (Hulu.groovy), version: 1
Post Mon Sep 23, 2013 11:09 pm
I only use a few, but Vevo is one of them and is working for me (thats why I picked on this one specifically). The error you get for Vevo is because the plugin is dependant on the YouTube plugin, which is loading later. I also get this error, but you should also see a "INFO [PluginCompilerThread] Added Web Resouce plugin VevoBeta (VevoBeta.groovy), version: 20" later in the log (confirm?).
I can't see that you've done anything wrong. Am wondering if one plug-in is faulty and stuffing it up for all the others. May want to try it with a limited set first (eg. just Veetle, Youtube and Vevo). Just move the plugins out of the folder (no need to change your online library - this will generate log errors, but otherwise shouldn't cause an issue).
rverhoeve
Post Tue Sep 24, 2013 11:46 am
yes, i do see that Vevo is loaded (version 20) later in the log, as you have expected.
i'll give it a try... i'll delete all but a few, and see if something, other than Veetle works, as well.
also, i have read in the forums that you can test these feeds/web resouces manually... how do you do that on a QNAP box ?? i have WinSCP, but don't know how to use it to load commands to any of the applications, or to the o/s itself ?
thanks, again.
Post Tue Sep 24, 2013 1:06 pm
I do not see anything wrong, but you need to post a log showing the subsequent parsing of the console entries using the plugins. That's where the problems exist.
You should be aware that the plugin sources often change (often to prevent direct access to their streams which bypasses their advertising revenue) and that screws up the plugins. I depend on people posting in my plugin threads when they break so I can release an update. Many of mine are currently broken but in the absence of anyone posting a problem I have not updated them since I am in the process of revamping them.
