No video with AVI on Sony KDL-32EX503
wheeliemonster
Post Tue Sep 24, 2013 4:44 pm
Hi
Have done some searching but cannot find a solution to my problem.
I'm trying to play AVI files created by my digital camera (Casio Exilim EX-Z600) which I'm sure used to play prior to version 1.3.1 (although I haven't used Serviio for a while so it's possible that the TV has updated to the latest firmware since, which may also be a problem)
I'm using the default Sony Bravia (2010) profile but have tried 2009/2011/2012, plus a couple of the BDP profiles with no luck.
I can see that the transcoding is happening from the log - the files are listed when browsing using the TV, and the file plays - but I only get audio, no video at all, just a black screen.
I tried editing the profile to force h264 video but I get the (Temporarily unavailable) message.
I also tried running the ffmpeg.exe command from the command-line and the ffmpeg seems to be doing it's job just fine - although it mentions that the yuv format is unspecified, so uses yuv422p
I've attached the log section which (I think) is important.
Can anyone diagnose why the TV is not showing a video?
Thanks in advance
Log.txt
(13.47 KiB) Downloaded 584 times
Post Tue Sep 24, 2013 5:53 pm
Re: No video with AVI on Sony KDL-32EX503
wheeliemonster wrote:... - although it mentions that the yuv format is unspecified, so uses yuv422p
issue knowed : https://bitbucket.org/xnejp03/serviio/i ... canon-vids
