1 Missing Folder?
Welsh_J_2000
Post Thu Sep 26, 2013 7:34 pm
1 Missing Folder?
Hi Guys,
I have all my TV programmes on Serviio with the exception of one, CSI, for some reason this doesn't show in my list of Shows like it hasn't downloaded the metadata for it? Can anyone help?
Post Thu Sep 26, 2013 11:04 pm
Re: 1 Missing Folder?
The filename(s) needs to match what is used in thetvdb.com. For CSI, try something like:
CSI Crime Scene Investigation SxxEyy - abcdef
where xx is the season number (eg. 02), yy is the episode number (eg. 03) and abcdef is the title of the episode (this is optional - Serviio doesn't need it). If you have any problems come back to us.
Welsh_J_2000
Post Fri Sep 27, 2013 12:00 pm
Hi DenyAll,
I did that, I matched all the files using Filebot so they are exactly as you described but still nothing.
Cheers
Post Fri Sep 27, 2013 12:17 pm
Works OK for me - maybe something in the folder name (eg. characters like [ or ])? Try copying a non-CSI file ( a known worker) into that folder and seeing if it shows up.
Welsh_J_2000
Post Fri Sep 27, 2013 12:30 pm
Odd!
If I set "Series" display to display content only it wont show but if I set it to display category it shows up?
Post Sat Sep 28, 2013 12:20 am
I couldn't fault it. Tried with Category and Content Only, both worked. Tried with square brackets in the path, also worked both ways. Weird.
Welsh_J_2000
Post Mon Sep 30, 2013 12:00 am
Very weird! Dunno why it works one way and not the other way at least it works.
