Can not remove folder from library
Betelgeuse
Post Fri Sep 27, 2013 9:15 am
I have added a network source containing the same content as a local resource. Now I want to remove the local resource from the library, but get "An unexpected error occurred (500). Check the log.". The same message appears if I try to change the content of the library to hide it.
I have tried to stop and start the Serviio server, service and console. The folder/files are still present (not deleted).
I can not find out what the source of the error is from the log file. Log file attached.
I can remove or change other entries in the Library Folder List
I am running Serviio PRO 1.3.1, Windows Home Server 2011
(205.92 KiB) Downloaded 373 times
Post Fri Sep 27, 2013 8:14 pm
Re: Can not remove folder from library
Looks like a corrupted library.
Can you enable detailed log and try to remove it again, then post the log.
Betelgeuse
Post Sat Sep 28, 2013 11:53 am
zip wrote:Looks like a corrupted library.
I made a new log, but quite big, so I RAR'ed it.
hmmm .... Too big - 1.5MB RAR'ed ...
If the library is corrupt, could I delete it and rebuild it?
Post Sat Sep 28, 2013 3:24 pm
easiest is to uninstall and install again
Betelgeuse
Post Sun Sep 29, 2013 4:37 pm
I simply reinstalled Serviio, and that made the trick!
