Wrong Series Identification
servant74
Post Tue Oct 08, 2013 5:54 pm
I have some episodes of "The Man From U.N.C.L.E." but it is being identified as "The Man From Blackhawk"
thetvdb.com lists them as 3323 and 76637 respectively. There is no alternate title for the series I want.
Is there a workaround?
Servio 1.3.1 pro, on XP
paniko
Post Tue Oct 08, 2013 8:21 pm
Re: Wrong Series Identification
are you using filebot?
Paniko
Sumsung EU46D6500 | XBox 360 | Samsung Galaxy S 6 Edge | Windows 10 - i7 64bit | Serviio 1.5.2 Pro
Beta Tester
servant74
Post Tue Oct 08, 2013 9:31 pm
No, I'll give it a try.
Tried it, now it wants to rename to the series 'The Man', again not the desired series.
More suggestions? Please!
Post Wed Oct 09, 2013 8:30 am
I think the dot's are screwing it up. The will be removed during the matching.
Might be out of luck for this one.
Return to User experiences
