sony bravia 2013 problems
wln
Post Wed Oct 09, 2013 7:53 pm
i have a macbook pro17 and sony bravia x9005a. Serviio is pro,i payed for it and i have a problem with it...the tv doesn t see the .avi files and doesn t load the subtitles. To see the .avi files,i have to use the transcoding option,witch over heat the pc and also the resolution on the tv fades...the movie quality fades...i m new to serviio,so hope i get some answers. Also i use as profile sony tv 2012,as the sony 2013 is not available....any ideeas,any help? At this time,the only available and working good as rezolution and all is .mkv files...
wln
Post Wed Oct 09, 2013 10:12 pm
Re: sony bravia 2013 problems
i finally succeded in adding the sony tv 2013 profile and now on some files,the serviio starts a process called ffmpeg,witch uses more than 50-60% of the cpu and over heats the laptop and doesn t cool down and doesn t stops unless stoped by me from the actuvuty monitor...any suggestions? haven t try the .avi files,guess the ffmpeg will also start...i have an i7...this is not normal...help pls
Post Thu Oct 10, 2013 7:23 am
wln wrote:i have a macbook pro17 and sony bravia x9005a. Serviio is pro,i payed for it and i have a problem with it...the tv doesn t see the .avi files and doesn t load the subtitles.
Could you provide information about these avi files ? (see signature link)
wln wrote:i finally succeded in adding the sony tv 2013 profile and now on some files,the serviio starts a process called ffmpeg,witch uses more than 50-60% of the cpu and over heats the laptop and doesn t cool down and doesn t stops unless stoped by me from the actuvuty monitor...any suggestions? haven t try the .avi files,guess the ffmpeg will also start...i have an i7...this is not normal...help pls
Could you enable detailed logging then find the log section when you start file ?
wln
Post Thu Oct 10, 2013 9:32 am
i tried to do that,and i think i manage to do the log thing...
i only modify that info-debug thing,started that movie and then copy the log and changed back that option. i don t know how to use very well this options,i m zero in codes and this things,so i didnt understand what u said about the avi file,so please be more specific,explain like in the log file,step by step please
2013-10-10 12:19:56,302 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2013-10-10 12:19:56,333 DEBUG [ConnectionManager] Sending protocol info using profile 'Sony Bravia TV (2013)'
2013-10-10 12:19:56,344 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-10-10 12:19:56,462 DEBUG [ServiioHttpService] Incoming request from /192.168.1.100:51729: GET /deviceDescription/d5d83c03-42e3-377d-afa7-8f5cd9997f2a HTTP/1.1, headers = [Host: 192.168.1.103:8895,Date: Thu, 10 Oct 2013 09:19:55 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KD-65X9005A";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KD-65X9005A"; mv="1.7";]]
2013-10-10 12:19:56,462 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2013-10-10 12:19:56,463 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device d5d83c03-42e3-377d-afa7-8f5cd9997f2a from 192.168.1.100 (headers = [Host: 192.168.1.103:8895,Date: Thu, 10 Oct 2013 09:19:55 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KD-65X9005A";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KD-65X9005A"; mv="1.7";])
2013-10-10 12:19:56,464 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2013-10-10 12:19:56,467 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.103:8895,Date: Thu, 10 Oct 2013 09:19:55 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KD-65X9005A";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KD-65X9005A"; mv="1.7";]
2013-10-10 12:19:56,468 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2013-10-10 12:19:56,469 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony Bravia TV (2013)'
2013-10-10 12:19:56,543 DEBUG [ServiioHttpService] Incoming request from /192.168.1.100:51730: GET /serviceDescription/ConnectionManager HTTP/1.1, headers = [Host: 192.168.1.103:8895,Date: Thu, 10 Oct 2013 09:19:55 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KD-65X9005A";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KD-65X9005A"; mv="1.7";]]
2013-10-10 12:19:56,543 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2013-10-10 12:19:56,544 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2013-10-10 12:19:56,544 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2013-10-10 12:19:56,611 DEBUG [ServiioHttpService] Incoming request from /192.168.1.100:51731: GET /serviceDescription/ContentDirectory HTTP/1.1, headers = [Host: 192.168.1.103:8895,Date: Thu, 10 Oct 2013 09:19:55 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KD-65X9005A";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KD-65X9005A"; mv="1.7";]]
2013-10-10 12:19:56,612 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2013-10-10 12:19:56,612 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2013-10-10 12:19:56,612 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2013-10-10 12:19:56,701 DEBUG [ServiioHttpService] Incoming request from /192.168.1.100:51732: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KD-65X9005A";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KD-65X9005A"; mv="1.7";,Host: 192.168.1.103:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 280,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"]]
2013-10-10 12:19:56,701 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2013-10-10 12:19:56,702 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.1.100
2013-10-10 12:19:56,702 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2013-10-10 12:19:56,724 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-10-10 12:19:56,785 DEBUG [ServiioHttpService] Incoming request from /192.168.1.100:51733: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KD-65X9005A";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KD-65X9005A"; mv="1.7";,Host: 192.168.1.103:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 273,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"]]
2013-10-10 12:19:56,785 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2013-10-10 12:19:56,786 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from 192.168.1.100
2013-10-10 12:19:56,786 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2013-10-10 12:19:56,800 DEBUG [ConnectionManager] Sending protocol info using profile 'Sony Bravia TV (2013)'
2013-10-10 12:19:56,810 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-10-10 12:19:57,074 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:02:58 (advertisement duration is 1800 sec.)
2013-10-10 12:20:01,174 INFO  [FeedUpdaterThread] Started looking for information about online resources
2013-10-10 12:20:01,174 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-10-10 12:20:01,174 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-10-10 12:20:01,178 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-10-10 12:20:01,179 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-10-10 12:20:01,188 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-10-10 12:20:01,188 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-10-10 12:20:01,188 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2013-10-10 12:20:01,188 DEBUG [PlaylistDAOImpl] Reading all Playlists
2013-10-10 12:20:01,191 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/movies
2013-10-10 12:20:01,192 DEBUG [LibraryUpdatesCheckerThread] Looking for removed playlist files in repository: /Users/laurent/Downloads/torente/movies
2013-10-10 12:20:01,192 DEBUG [PlaylistDAOImpl] Reading Playlists for Repository (id = 2)
2013-10-10 12:20:01,200 DEBUG [LibraryUpdatesCheckerThread] Looking for removed/updated files in repository: /Users/laurent/Downloads/torente/movies
2013-10-10 12:20:01,200 DEBUG [MediaItemDAOImpl] Reading MediaItems for Repository (id = 2)
2013-10-10 12:20:01,211 DEBUG [MediaItemDAOImpl] Getting file of media item 192
2013-10-10 12:20:01,213 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/movies/Cody.The.Robosapien.2013.1080p.BluRay.x264-CzT
2013-10-10 12:20:01,217 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2013-10-10 12:20:01,228 DEBUG [LibraryAdditionsCheckerThread] Found file 'Cody.The.Robosapien.2013.1080p.BluRay.x264-CzT.mkv', checking if it's already in the Library
2013-10-10 12:20:01,228 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /Users/laurent/Downloads/torente/movies/Cody.The.Robosapien.2013.1080p.BluRay.x264-CzT/Cody.The.Robosapien.2013.1080p.BluRay.x264-CzT.mkv
2013-10-10 12:20:01,229 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /Users/laurent/Downloads/torente/movies/Cody.The.Robosapien.2013.1080p.BluRay.x264-CzT/Cody.The.Robosapien.2013.1080p.BluRay.x264-CzT.mkv, ignore case: false
2013-10-10 12:20:01,231 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2013-10-10 12:20:01,232 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type IMAGE
2013-10-10 12:20:01,236 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 192) and extractor EMBEDDED
2013-10-10 12:20:01,244 DEBUG [MediaItemDAOImpl] Media item /Users/laurent/Downloads/torente/movies/Cody.The.Robosapien.2013.1080p.BluRay.x264-CzT/Cody.The.Robosapien.2013.1080p.BluRay.x264-CzT.mkv already exists in DB
2013-10-10 12:20:01,246 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/movies/Europa.Report.2013.BluRay.720p.DTS.x264-CHD
2013-10-10 12:20:01,251 DEBUG [MediaItemDAOImpl] Getting file of media item 194
2013-10-10 12:20:01,251 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 194) and extractor EMBEDDED
2013-10-10 12:20:01,252 DEBUG [MediaItemDAOImpl] Getting file of media item 179
2013-10-10 12:20:01,252 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 179) and extractor EMBEDDED
2013-10-10 12:20:01,253 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 179) and extractor COVER_IMAGE_IN_FOLDER
2013-10-10 12:20:01,258 DEBUG [LibraryAdditionsCheckerThread] Found file 'Europa.Report.2013.BluRay.720p.DTS.x264-CHD.mkv', checking if it's already in the Library
2013-10-10 12:20:01,258 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /Users/laurent/Downloads/torente/movies/Europa.Report.2013.BluRay.720p.DTS.x264-CHD/Europa.Report.2013.BluRay.720p.DTS.x264-CHD.mkv
2013-10-10 12:20:01,258 DEBUG [MediaItemDAOImpl] Getting file of media item 180
2013-10-10 12:20:01,258 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /Users/laurent/Downloads/torente/movies/Europa.Report.2013.BluRay.720p.DTS.x264-CHD/Europa.Report.2013.BluRay.720p.DTS.x264-CHD.mkv, ignore case: false
2013-10-10 12:20:01,260 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 180) and extractor EMBEDDED
2013-10-10 12:20:01,260 DEBUG [MediaItemDAOImpl] Media item /Users/laurent/Downloads/torente/movies/Europa.Report.2013.BluRay.720p.DTS.x264-CHD/Europa.Report.2013.BluRay.720p.DTS.x264-CHD.mkv already exists in DB
2013-10-10 12:20:01,260 DEBUG [LibraryAdditionsCheckerThread] Found file 'sample.mkv', checking if it's already in the Library
2013-10-10 12:20:01,261 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /Users/laurent/Downloads/torente/movies/Europa.Report.2013.BluRay.720p.DTS.x264-CHD/sample.mkv
2013-10-10 12:20:01,261 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /Users/laurent/Downloads/torente/movies/Europa.Report.2013.BluRay.720p.DTS.x264-CHD/sample.mkv, ignore case: false
2013-10-10 12:20:01,262 DEBUG [MediaItemDAOImpl] Media item /Users/laurent/Downloads/torente/movies/Europa.Report.2013.BluRay.720p.DTS.x264-CHD/sample.mkv already exists in DB
2013-10-10 12:20:01,262 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 180) and extractor COVER_IMAGE_IN_FOLDER
2013-10-10 12:20:01,262 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/movies/Only.God.Forgives.2013.720p.BluRay.DTS.x264.RoSubbed-CzT
2013-10-10 12:20:01,263 DEBUG [MediaItemDAOImpl] Getting file of media item 181
2013-10-10 12:20:01,264 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 181) and extractor EMBEDDED
2013-10-10 12:20:01,265 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 181) and extractor COVER_IMAGE_IN_FOLDER
2013-10-10 12:20:01,266 DEBUG [MediaItemDAOImpl] Getting file of media item 182
2013-10-10 12:20:01,267 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 182) and extractor EMBEDDED
2013-10-10 12:20:01,268 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 182) and extractor COVER_IMAGE_IN_FOLDER
2013-10-10 12:20:01,311 DEBUG [LibraryAdditionsCheckerThread] Found file 'Only.God.Forgives.2013.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv', checking if it's already in the Library
2013-10-10 12:20:01,311 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /Users/laurent/Downloads/torente/movies/Only.God.Forgives.2013.720p.BluRay.DTS.x264.RoSubbed-CzT/Only.God.Forgives.2013.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv
2013-10-10 12:20:01,311 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /Users/laurent/Downloads/torente/movies/Only.God.Forgives.2013.720p.BluRay.DTS.x264.RoSubbed-CzT/Only.God.Forgives.2013.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv, ignore case: false
2013-10-10 12:20:01,311 DEBUG [MediaItemDAOImpl] Getting file of media item 183
2013-10-10 12:20:01,313 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 183) and extractor EMBEDDED
2013-10-10 12:20:01,313 DEBUG [MediaItemDAOImpl] Media item /Users/laurent/Downloads/torente/movies/Only.God.Forgives.2013.720p.BluRay.DTS.x264.RoSubbed-CzT/Only.God.Forgives.2013.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv already exists in DB
2013-10-10 12:20:01,314 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/movies/Pain.and.Gain.2013.NTSC.DVDR.RoSubbed-CzT
2013-10-10 12:20:01,314 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 183) and extractor COVER_IMAGE_IN_FOLDER
2013-10-10 12:20:01,341 DEBUG [LibraryAdditionsCheckerThread] Found file 'Sample.vob', checking if it's already in the Library
2013-10-10 12:20:01,341 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /Users/laurent/Downloads/torente/movies/Pain.and.Gain.2013.NTSC.DVDR.RoSubbed-CzT/Sample.vob
2013-10-10 12:20:01,341 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /Users/laurent/Downloads/torente/movies/Pain.and.Gain.2013.NTSC.DVDR.RoSubbed-CzT/Sample.vob, ignore case: false
2013-10-10 12:20:01,341 DEBUG [MediaItemDAOImpl] Getting file of media item 184
2013-10-10 12:20:01,343 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 184) and extractor EMBEDDED
2013-10-10 12:20:01,343 DEBUG [MediaItemDAOImpl] Media item /Users/laurent/Downloads/torente/movies/Pain.and.Gain.2013.NTSC.DVDR.RoSubbed-CzT/Sample.vob already exists in DB
2013-10-10 12:20:01,343 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/movies/Rise.of.the.Guardians.3D.2012.1080p.BluRay.Half.OU.DD5.1.x264-HDMaNiAcS
2013-10-10 12:20:01,344 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 184) and extractor COVER_IMAGE_IN_FOLDER
2013-10-10 12:20:01,346 DEBUG [LibraryAdditionsCheckerThread] Found file 'Rise.of.the.Guardians.3D.2012.1080p.BluRay.Half.OU.DD5.1.x264-HDMaNiAcS.mkv', checking if it's already in the Library
2013-10-10 12:20:01,346 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /Users/laurent/Downloads/torente/movies/Rise.of.the.Guardians.3D.2012.1080p.BluRay.Half.OU.DD5.1.x264-HDMaNiAcS/Rise.of.the.Guardians.3D.2012.1080p.BluRay.Half.OU.DD5.1.x264-HDMaNiAcS.mkv
2013-10-10 12:20:01,346 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /Users/laurent/Downloads/torente/movies/Rise.of.the.Guardians.3D.2012.1080p.BluRay.Half.OU.DD5.1.x264-HDMaNiAcS/Rise.of.the.Guardians.3D.2012.1080p.BluRay.Half.OU.DD5.1.x264-HDMaNiAcS.mkv, ignore case: false
2013-10-10 12:20:01,346 DEBUG [MediaItemDAOImpl] Getting file of media item 185
2013-10-10 12:20:01,347 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 185) and extractor EMBEDDED
2013-10-10 12:20:01,348 DEBUG [MediaItemDAOImpl] Media item /Users/laurent/Downloads/torente/movies/Rise.of.the.Guardians.3D.2012.1080p.BluRay.Half.OU.DD5.1.x264-HDMaNiAcS/Rise.of.the.Guardians.3D.2012.1080p.BluRay.Half.OU.DD5.1.x264-HDMaNiAcS.mkv already exists in DB
2013-10-10 12:20:01,348 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/movies/Rise.of.the.Guardians.3D.2012.1080p.BluRay.Half.OU.DD5.1.x264-HDMaNiAcS/subs
2013-10-10 12:20:01,348 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 185) and extractor COVER_IMAGE_IN_FOLDER
2013-10-10 12:20:01,370 DEBUG [MediaItemDAOImpl] Getting file of media item 186
2013-10-10 12:20:01,371 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/movies/The.Call.2013.720p.BluRay.DTS.x264.RoSubbed-CzT
2013-10-10 12:20:01,371 DEBUG [LibraryAdditionsCheckerThread] Found file 'The.Call.2013.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv', checking if it's already in the Library
2013-10-10 12:20:01,372 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /Users/laurent/Downloads/torente/movies/The.Call.2013.720p.BluRay.DTS.x264.RoSubbed-CzT/The.Call.2013.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv
2013-10-10 12:20:01,372 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /Users/laurent/Downloads/torente/movies/The.Call.2013.720p.BluRay.DTS.x264.RoSubbed-CzT/The.Call.2013.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv, ignore case: false
2013-10-10 12:20:01,372 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 186) and extractor EMBEDDED
2013-10-10 12:20:01,373 DEBUG [MediaItemDAOImpl] Media item /Users/laurent/Downloads/torente/movies/The.Call.2013.720p.BluRay.DTS.x264.RoSubbed-CzT/The.Call.2013.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv already exists in DB
2013-10-10 12:20:01,373 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 186) and extractor COVER_IMAGE_IN_FOLDER
2013-10-10 12:20:01,374 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/movies/The.Colony.2013.720p.BluRay.DTS.x264.RoSubbed-CzT
2013-10-10 12:20:01,374 DEBUG [LibraryAdditionsCheckerThread] Found file 'The.Colony.2013.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv', checking if it's already in the Library
2013-10-10 12:20:01,374 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /Users/laurent/Downloads/torente/movies/The.Colony.2013.720p.BluRay.DTS.x264.RoSubbed-CzT/The.Colony.2013.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv
2013-10-10 12:20:01,374 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /Users/laurent/Downloads/torente/movies/The.Colony.2013.720p.BluRay.DTS.x264.RoSubbed-CzT/The.Colony.2013.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv, ignore case: false
2013-10-10 12:20:01,375 DEBUG [MediaItemDAOImpl] Getting file of media item 187
2013-10-10 12:20:01,376 DEBUG [MediaItemDAOImpl] Media item /Users/laurent/Downloads/torente/movies/The.Colony.2013.720p.BluRay.DTS.x264.RoSubbed-CzT/The.Colony.2013.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv already exists in DB
2013-10-10 12:20:01,376 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/movies/The.Crown.and.the.Dragon.2013.720p.BluRay.DTS.x264-CzT
2013-10-10 12:20:01,376 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 187) and extractor EMBEDDED
2013-10-10 12:20:01,377 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 187) and extractor COVER_IMAGE_IN_FOLDER
2013-10-10 12:20:01,379 DEBUG [MediaItemDAOImpl] Getting file of media item 190
2013-10-10 12:20:01,380 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 190) and extractor EMBEDDED
2013-10-10 12:20:01,381 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 190) and extractor COVER_IMAGE_IN_FOLDER
2013-10-10 12:20:01,381 DEBUG [LibraryUpdatesCheckerThread] Looking for removed playlist files in repository: /Users/laurent/Downloads/torente
2013-10-10 12:20:01,381 DEBUG [PlaylistDAOImpl] Reading Playlists for Repository (id = 3)
2013-10-10 12:20:01,382 DEBUG [LibraryUpdatesCheckerThread] Looking for removed/updated files in repository: /Users/laurent/Downloads/torente
2013-10-10 12:20:01,382 DEBUG [MediaItemDAOImpl] Reading MediaItems for Repository (id = 3)
2013-10-10 12:20:01,383 DEBUG [MediaItemDAOImpl] Getting file of media item 195
2013-10-10 12:20:01,383 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 195) and extractor EMBEDDED
2013-10-10 12:20:01,384 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 195) and extractor COVER_IMAGE_IN_FOLDER
2013-10-10 12:20:01,410 DEBUG [LibraryAdditionsCheckerThread] Found file 'The.Crown.and.the.Dragon.2013.720p.BluRay.DTS.x264-CzT.jpg', checking if it's already in the Library
2013-10-10 12:20:01,410 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /Users/laurent/Downloads/torente/movies/The.Crown.and.the.Dragon.2013.720p.BluRay.DTS.x264-CzT/The.Crown.and.the.Dragon.2013.720p.BluRay.DTS.x264-CzT.jpg
2013-10-10 12:20:01,410 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /Users/laurent/Downloads/torente/movies/The.Crown.and.the.Dragon.2013.720p.BluRay.DTS.x264-CzT/The.Crown.and.the.Dragon.2013.720p.BluRay.DTS.x264-CzT.jpg, ignore case: false
2013-10-10 12:20:01,412 DEBUG [MediaItemDAOImpl] Media item /Users/laurent/Downloads/torente/movies/The.Crown.and.the.Dragon.2013.720p.BluRay.DTS.x264-CzT/The.Crown.and.the.Dragon.2013.720p.BluRay.DTS.x264-CzT.jpg already exists in DB
2013-10-10 12:20:01,412 DEBUG [LibraryAdditionsCheckerThread] Found file 'The.Crown.and.the.Dragon.2013.720p.BluRay.DTS.x264-CzT.mkv', checking if it's already in the Library
2013-10-10 12:20:01,412 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /Users/laurent/Downloads/torente/movies/The.Crown.and.the.Dragon.2013.720p.BluRay.DTS.x264-CzT/The.Crown.and.the.Dragon.2013.720p.BluRay.DTS.x264-CzT.mkv
2013-10-10 12:20:01,412 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /Users/laurent/Downloads/torente/movies/The.Crown.and.the.Dragon.2013.720p.BluRay.DTS.x264-CzT/The.Crown.and.the.Dragon.2013.720p.BluRay.DTS.x264-CzT.mkv, ignore case: false
2013-10-10 12:20:01,413 DEBUG [MediaItemDAOImpl] Media item /Users/laurent/Downloads/torente/movies/The.Crown.and.the.Dragon.2013.720p.BluRay.DTS.x264-CzT/The.Crown.and.the.Dragon.2013.720p.BluRay.DTS.x264-CzT.mkv already exists in DB
2013-10-10 12:20:01,414 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/movies/World.War.Z.2013.Unrated.Cut.720p.BluRay.DTS.x264.RoSubbed-CzT
2013-10-10 12:20:01,424 DEBUG [LibraryAdditionsCheckerThread] Found file 'World.War.Z.2013.Unrated.Cut.720p.BluRay.DTS.x264.RoSubbed-CzT.jpg', checking if it's already in the Library
2013-10-10 12:20:01,424 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /Users/laurent/Downloads/torente/movies/World.War.Z.2013.Unrated.Cut.720p.BluRay.DTS.x264.RoSubbed-CzT/World.War.Z.2013.Unrated.Cut.720p.BluRay.DTS.x264.RoSubbed-CzT.jpg
2013-10-10 12:20:01,424 DEBUG [MediaItemDAOImpl] Getting file of media item 201
2013-10-10 12:20:01,424 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /Users/laurent/Downloads/torente/movies/World.War.Z.2013.Unrated.Cut.720p.BluRay.DTS.x264.RoSubbed-CzT/World.War.Z.2013.Unrated.Cut.720p.BluRay.DTS.x264.RoSubbed-CzT.jpg, ignore case: false
2013-10-10 12:20:01,425 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 201) and extractor EMBEDDED
2013-10-10 12:20:01,425 DEBUG [MediaItemDAOImpl] Media item /Users/laurent/Downloads/torente/movies/World.War.Z.2013.Unrated.Cut.720p.BluRay.DTS.x264.RoSubbed-CzT/World.War.Z.2013.Unrated.Cut.720p.BluRay.DTS.x264.RoSubbed-CzT.jpg already exists in DB
2013-10-10 12:20:01,425 DEBUG [LibraryAdditionsCheckerThread] Found file 'World.War.Z.2013.Unrated.Cut.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv', checking if it's already in the Library
2013-10-10 12:20:01,425 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /Users/laurent/Downloads/torente/movies/World.War.Z.2013.Unrated.Cut.720p.BluRay.DTS.x264.RoSubbed-CzT/World.War.Z.2013.Unrated.Cut.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv
2013-10-10 12:20:01,425 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /Users/laurent/Downloads/torente/movies/World.War.Z.2013.Unrated.Cut.720p.BluRay.DTS.x264.RoSubbed-CzT/World.War.Z.2013.Unrated.Cut.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv, ignore case: false
2013-10-10 12:20:01,426 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 201) and extractor COVER_IMAGE_IN_FOLDER
2013-10-10 12:20:01,426 DEBUG [MediaItemDAOImpl] Media item /Users/laurent/Downloads/torente/movies/World.War.Z.2013.Unrated.Cut.720p.BluRay.DTS.x264.RoSubbed-CzT/World.War.Z.2013.Unrated.Cut.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv already exists in DB
2013-10-10 12:20:01,426 DEBUG [RepositoryDAOImpl] Marking Repository 2 as scanned with current timestamp
2013-10-10 12:20:01,437 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 2)
2013-10-10 12:20:01,437 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente
2013-10-10 12:20:01,446 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/BMW Update DVD Road MAP Europe. Professional. 2013
2013-10-10 12:20:01,455 DEBUG [RepositoryDAOImpl] Marking Repository 2 as scanned with current timestamp
2013-10-10 12:20:01,461 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/BMW Update DVD Road MAP Europe. Professional. 2013/Covers 2013 Professional
2013-10-10 12:20:01,461 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 3)
2013-10-10 12:20:01,461 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/BMW Update DVD Road MAP Europe. Professional. 2013/Disk1
2013-10-10 12:20:01,461 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/BMW Update DVD Road MAP Europe. Professional. 2013/Disk2
2013-10-10 12:20:01,461 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/BMW Update DVD Road MAP Europe. Professional. 2013/Disk3
2013-10-10 12:20:01,462 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app
2013-10-10 12:20:01,462 DEBUG [RepositoryDAOImpl] Marking Repository 3 as scanned with current timestamp
2013-10-10 12:20:01,468 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents
2013-10-10 12:20:01,468 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/_CodeSignature
2013-10-10 12:20:01,468 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks
2013-10-10 12:20:01,468 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Growl.framework
2013-10-10 12:20:01,476 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Growl.framework/Headers
2013-10-10 12:20:01,476 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Growl.framework/Resources
2013-10-10 12:20:01,477 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Growl.framework/Versions
2013-10-10 12:20:01,477 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Growl.framework/Versions/A
2013-10-10 12:20:01,477 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Growl.framework/Versions/A/_CodeSignature
2013-10-10 12:20:01,477 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Growl.framework/Versions/A/Headers
2013-10-10 12:20:01,477 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Growl.framework/Versions/A/Resources
2013-10-10 12:20:01,477 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Growl.framework/Versions/Current
2013-10-10 12:20:01,477 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Growl.framework/Versions/Current/_CodeSignature
2013-10-10 12:20:01,478 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Growl.framework/Versions/Current/Headers
2013-10-10 12:20:01,478 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Growl.framework/Versions/Current/Resources
2013-10-10 12:20:01,478 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/ReactiveCocoa.framework
2013-10-10 12:20:01,492 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/ReactiveCocoa.framework/Headers
2013-10-10 12:20:01,496 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/ReactiveCocoa.framework/Resources
2013-10-10 12:20:01,496 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/ReactiveCocoa.framework/Versions
2013-10-10 12:20:01,497 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/ReactiveCocoa.framework/Versions/A
2013-10-10 12:20:01,497 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/ReactiveCocoa.framework/Versions/A/_CodeSignature
2013-10-10 12:20:01,497 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/ReactiveCocoa.framework/Versions/A/Headers
2013-10-10 12:20:01,499 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/ReactiveCocoa.framework/Versions/A/Resources
2013-10-10 12:20:01,499 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/ReactiveCocoa.framework/Versions/Current
2013-10-10 12:20:01,500 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/ReactiveCocoa.framework/Versions/Current/_CodeSignature
2013-10-10 12:20:01,500 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/ReactiveCocoa.framework/Versions/Current/Headers
2013-10-10 12:20:01,502 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/ReactiveCocoa.framework/Versions/Current/Resources
2013-10-10 12:20:01,502 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework
2013-10-10 12:20:01,502 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Headers
2013-10-10 12:20:01,503 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources
2013-10-10 12:20:01,503 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/de.lproj
2013-10-10 12:20:01,503 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/de.lproj/SUAutomaticUpdateAlert.nib
2013-10-10 12:20:01,504 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/de.lproj/SUUpdateAlert.nib
2013-10-10 12:20:01,505 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/de.lproj/SUUpdatePermissionPrompt.nib
2013-10-10 12:20:01,505 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/en.lproj
2013-10-10 12:20:01,505 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/en.lproj/SUAutomaticUpdateAlert.nib
2013-10-10 12:20:01,506 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/en.lproj/SUUpdateAlert.nib
2013-10-10 12:20:01,506 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/en.lproj/SUUpdatePermissionPrompt.nib
2013-10-10 12:20:01,507 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/es.lproj
2013-10-10 12:20:01,507 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/es.lproj/SUAutomaticUpdateAlert.nib
2013-10-10 12:20:01,507 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/es.lproj/SUUpdateAlert.nib
2013-10-10 12:20:01,507 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/es.lproj/SUUpdatePermissionPrompt.nib
2013-10-10 12:20:01,508 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/fr.lproj
2013-10-10 12:20:01,508 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/fr.lproj/SUAutomaticUpdateAlert.nib
2013-10-10 12:20:01,508 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/fr.lproj/SUUpdateAlert.nib
2013-10-10 12:20:01,509 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/fr.lproj/SUUpdatePermissionPrompt.nib
2013-10-10 12:20:01,509 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/it.lproj
2013-10-10 12:20:01,509 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/it.lproj/SUAutomaticUpdateAlert.nib
2013-10-10 12:20:01,509 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/it.lproj/SUUpdateAlert.nib
2013-10-10 12:20:01,510 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/it.lproj/SUUpdatePermissionPrompt.nib
2013-10-10 12:20:01,510 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/nl.lproj
2013-10-10 12:20:01,510 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/nl.lproj/SUAutomaticUpdateAlert.nib
2013-10-10 12:20:01,511 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/nl.lproj/SUUpdateAlert.nib
2013-10-10 12:20:01,511 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/nl.lproj/SUUpdatePermissionPrompt.nib
2013-10-10 12:20:01,511 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/ru.lproj
2013-10-10 12:20:01,512 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/ru.lproj/SUAutomaticUpdateAlert.nib
2013-10-10 12:20:01,512 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/ru.lproj/SUUpdateAlert.nib
2013-10-10 12:20:01,512 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/ru.lproj/SUUpdatePermissionPrompt.nib
wln
and the second part...couldn t post the entire log....
2013-10-10 12:20:01,513 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/SUStatus.nib
2013-10-10 12:20:01,513 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/sv.lproj
2013-10-10 12:20:01,513 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/sv.lproj/SUAutomaticUpdateAlert.nib
2013-10-10 12:20:01,514 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/sv.lproj/SUUpdateAlert.nib
2013-10-10 12:20:01,514 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Resources/sv.lproj/SUUpdatePermissionPrompt.nib
2013-10-10 12:20:01,514 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions
2013-10-10 12:20:01,515 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A
2013-10-10 12:20:01,515 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/_CodeSignature
2013-10-10 12:20:01,515 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Headers
2013-10-10 12:20:01,515 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources
2013-10-10 12:20:01,516 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/de.lproj
2013-10-10 12:20:01,516 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/de.lproj/SUAutomaticUpdateAlert.nib
2013-10-10 12:20:01,516 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/de.lproj/SUUpdateAlert.nib
2013-10-10 12:20:01,516 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/de.lproj/SUUpdatePermissionPrompt.nib
2013-10-10 12:20:01,516 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/en.lproj
2013-10-10 12:20:01,517 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/en.lproj/SUAutomaticUpdateAlert.nib
2013-10-10 12:20:01,517 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/en.lproj/SUUpdateAlert.nib
2013-10-10 12:20:01,517 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/en.lproj/SUUpdatePermissionPrompt.nib
2013-10-10 12:20:01,517 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/es.lproj
2013-10-10 12:20:01,518 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/es.lproj/SUAutomaticUpdateAlert.nib
2013-10-10 12:20:01,518 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/es.lproj/SUUpdateAlert.nib
2013-10-10 12:20:01,518 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/es.lproj/SUUpdatePermissionPrompt.nib
2013-10-10 12:20:01,519 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/fr.lproj
2013-10-10 12:20:01,519 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/fr.lproj/SUAutomaticUpdateAlert.nib
2013-10-10 12:20:01,519 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/fr.lproj/SUUpdateAlert.nib
2013-10-10 12:20:01,519 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/fr.lproj/SUUpdatePermissionPrompt.nib
2013-10-10 12:20:01,520 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/it.lproj
2013-10-10 12:20:01,520 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/it.lproj/SUAutomaticUpdateAlert.nib
2013-10-10 12:20:01,520 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/it.lproj/SUUpdateAlert.nib
2013-10-10 12:20:01,520 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/it.lproj/SUUpdatePermissionPrompt.nib
2013-10-10 12:20:01,520 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/nl.lproj
2013-10-10 12:20:01,521 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/nl.lproj/SUAutomaticUpdateAlert.nib
2013-10-10 12:20:01,521 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/nl.lproj/SUUpdateAlert.nib
2013-10-10 12:20:01,521 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/nl.lproj/SUUpdatePermissionPrompt.nib
2013-10-10 12:20:01,521 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/ru.lproj
2013-10-10 12:20:01,521 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/ru.lproj/SUAutomaticUpdateAlert.nib
2013-10-10 12:20:01,522 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/ru.lproj/SUUpdateAlert.nib
2013-10-10 12:20:01,522 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/ru.lproj/SUUpdatePermissionPrompt.nib
2013-10-10 12:20:01,522 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/SUStatus.nib
2013-10-10 12:20:01,523 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/sv.lproj
2013-10-10 12:20:01,523 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/sv.lproj/SUAutomaticUpdateAlert.nib
2013-10-10 12:20:01,523 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/sv.lproj/SUUpdateAlert.nib
2013-10-10 12:20:01,523 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/A/Resources/sv.lproj/SUUpdatePermissionPrompt.nib
2013-10-10 12:20:01,524 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current
2013-10-10 12:20:01,524 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/_CodeSignature
2013-10-10 12:20:01,524 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Headers
2013-10-10 12:20:01,524 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources
2013-10-10 12:20:01,525 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/de.lproj
2013-10-10 12:20:01,525 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/de.lproj/SUAutomaticUpdateAlert.nib
2013-10-10 12:20:01,525 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/de.lproj/SUUpdateAlert.nib
2013-10-10 12:20:01,525 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/de.lproj/SUUpdatePermissionPrompt.nib
2013-10-10 12:20:01,526 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/en.lproj
2013-10-10 12:20:01,526 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/en.lproj/SUAutomaticUpdateAlert.nib
2013-10-10 12:20:01,526 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/en.lproj/SUUpdateAlert.nib
2013-10-10 12:20:01,526 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/en.lproj/SUUpdatePermissionPrompt.nib
2013-10-10 12:20:01,527 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/es.lproj
2013-10-10 12:20:01,527 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/es.lproj/SUAutomaticUpdateAlert.nib
2013-10-10 12:20:01,527 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/es.lproj/SUUpdateAlert.nib
2013-10-10 12:20:01,528 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/es.lproj/SUUpdatePermissionPrompt.nib
2013-10-10 12:20:01,528 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/fr.lproj
2013-10-10 12:20:01,528 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/fr.lproj/SUAutomaticUpdateAlert.nib
2013-10-10 12:20:01,528 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/fr.lproj/SUUpdateAlert.nib
2013-10-10 12:20:01,529 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/fr.lproj/SUUpdatePermissionPrompt.nib
2013-10-10 12:20:01,529 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/it.lproj
2013-10-10 12:20:01,529 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/it.lproj/SUAutomaticUpdateAlert.nib
2013-10-10 12:20:01,530 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/it.lproj/SUUpdateAlert.nib
2013-10-10 12:20:01,530 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/it.lproj/SUUpdatePermissionPrompt.nib
2013-10-10 12:20:01,530 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/nl.lproj
2013-10-10 12:20:01,530 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/nl.lproj/SUAutomaticUpdateAlert.nib
2013-10-10 12:20:01,530 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/nl.lproj/SUUpdateAlert.nib
2013-10-10 12:20:01,531 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/nl.lproj/SUUpdatePermissionPrompt.nib
2013-10-10 12:20:01,531 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/ru.lproj
2013-10-10 12:20:01,531 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/ru.lproj/SUAutomaticUpdateAlert.nib
2013-10-10 12:20:01,531 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/ru.lproj/SUUpdateAlert.nib
2013-10-10 12:20:01,532 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/ru.lproj/SUUpdatePermissionPrompt.nib
2013-10-10 12:20:01,532 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/SUStatus.nib
2013-10-10 12:20:01,532 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/sv.lproj
2013-10-10 12:20:01,532 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/sv.lproj/SUAutomaticUpdateAlert.nib
2013-10-10 12:20:01,533 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/sv.lproj/SUUpdateAlert.nib
2013-10-10 12:20:01,533 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Frameworks/Sparkle.framework/Versions/Current/Resources/sv.lproj/SUUpdatePermissionPrompt.nib
2013-10-10 12:20:01,534 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/MacOS
2013-10-10 12:20:01,534 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Resources
2013-10-10 12:20:01,534 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Resources/cs.lproj
2013-10-10 12:20:01,534 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Resources/Danish.lproj
2013-10-10 12:20:01,535 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Resources/el.lproj
2013-10-10 12:20:01,535 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Resources/English.lproj
2013-10-10 12:20:01,535 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Resources/fi.lproj
2013-10-10 12:20:01,535 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Resources/French.lproj
2013-10-10 12:20:01,535 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Resources/German.lproj
2013-10-10 12:20:01,536 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Resources/Italian.lproj
2013-10-10 12:20:01,536 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Resources/ko.lproj
2013-10-10 12:20:01,536 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Resources/lv.lproj
2013-10-10 12:20:01,536 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Resources/nl.lproj
2013-10-10 12:20:01,536 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Resources/pl.lproj
2013-10-10 12:20:01,537 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Resources/pt-BR.lproj
2013-10-10 12:20:01,537 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Resources/pt-PT.lproj
2013-10-10 12:20:01,537 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Resources/pt.lproj
2013-10-10 12:20:01,537 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Resources/ru-RU.lproj
2013-10-10 12:20:01,537 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Resources/ru.lproj
2013-10-10 12:20:01,538 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Resources/sk.lproj
2013-10-10 12:20:01,538 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Resources/Spanish.lproj
2013-10-10 12:20:01,538 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Resources/Swedish.lproj
2013-10-10 12:20:01,538 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Resources/tr.lproj
2013-10-10 12:20:01,538 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Resources/uk-UA.lproj
2013-10-10 12:20:01,538 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Resources/zh_CN.lproj
2013-10-10 12:20:01,539 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/gfxCardStatus.app/Contents/Resources/zh_TW.lproj
2013-10-10 12:20:01,539 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/How.I.Met.Your.Mother.S09E04.720p.HDTV.x264-CzT
2013-10-10 12:20:01,539 DEBUG [LibraryAdditionsCheckerThread] Found file 'How.I.Met.Your.Mother.S09E04.720p.HDTV.x264-CzT.mkv', checking if it's already in the Library
2013-10-10 12:20:01,539 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /Users/laurent/Downloads/torente/How.I.Met.Your.Mother.S09E04.720p.HDTV.x264-CzT/How.I.Met.Your.Mother.S09E04.720p.HDTV.x264-CzT.mkv
2013-10-10 12:20:01,539 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /Users/laurent/Downloads/torente/How.I.Met.Your.Mother.S09E04.720p.HDTV.x264-CzT/How.I.Met.Your.Mother.S09E04.720p.HDTV.x264-CzT.mkv, ignore case: false
2013-10-10 12:20:01,540 DEBUG [MediaItemDAOImpl] Media item /Users/laurent/Downloads/torente/How.I.Met.Your.Mother.S09E04.720p.HDTV.x264-CzT/How.I.Met.Your.Mother.S09E04.720p.HDTV.x264-CzT.mkv already exists in DB
2013-10-10 12:20:01,540 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/Monsters.University.2013.1080p.WEB-DL.H264-CzT
2013-10-10 12:20:01,540 DEBUG [LibraryAdditionsCheckerThread] Found file 'Monsters.University.2013.1080p.WEB-DL.H264-CzT.mkv', checking if it's already in the Library
2013-10-10 12:20:01,541 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /Users/laurent/Downloads/torente/Monsters.University.2013.1080p.WEB-DL.H264-CzT/Monsters.University.2013.1080p.WEB-DL.H264-CzT.mkv
2013-10-10 12:20:01,541 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /Users/laurent/Downloads/torente/Monsters.University.2013.1080p.WEB-DL.H264-CzT/Monsters.University.2013.1080p.WEB-DL.H264-CzT.mkv, ignore case: false
2013-10-10 12:20:01,541 DEBUG [MediaItemDAOImpl] Media item /Users/laurent/Downloads/torente/Monsters.University.2013.1080p.WEB-DL.H264-CzT/Monsters.University.2013.1080p.WEB-DL.H264-CzT.mkv already exists in DB
2013-10-10 12:20:01,541 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/movies
2013-10-10 12:20:01,542 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/movies/Cody.The.Robosapien.2013.1080p.BluRay.x264-CzT
2013-10-10 12:20:01,542 DEBUG [LibraryAdditionsCheckerThread] Found file 'Cody.The.Robosapien.2013.1080p.BluRay.x264-CzT.mkv', checking if it's already in the Library
2013-10-10 12:20:01,542 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /Users/laurent/Downloads/torente/movies/Cody.The.Robosapien.2013.1080p.BluRay.x264-CzT/Cody.The.Robosapien.2013.1080p.BluRay.x264-CzT.mkv
2013-10-10 12:20:01,542 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /Users/laurent/Downloads/torente/movies/Cody.The.Robosapien.2013.1080p.BluRay.x264-CzT/Cody.The.Robosapien.2013.1080p.BluRay.x264-CzT.mkv, ignore case: false
2013-10-10 12:20:01,543 DEBUG [MediaItemDAOImpl] Media item /Users/laurent/Downloads/torente/movies/Cody.The.Robosapien.2013.1080p.BluRay.x264-CzT/Cody.The.Robosapien.2013.1080p.BluRay.x264-CzT.mkv already exists in DB
2013-10-10 12:20:01,543 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/movies/Europa.Report.2013.BluRay.720p.DTS.x264-CHD
2013-10-10 12:20:01,543 DEBUG [LibraryAdditionsCheckerThread] Found file 'Europa.Report.2013.BluRay.720p.DTS.x264-CHD.mkv', checking if it's already in the Library
2013-10-10 12:20:01,543 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /Users/laurent/Downloads/torente/movies/Europa.Report.2013.BluRay.720p.DTS.x264-CHD/Europa.Report.2013.BluRay.720p.DTS.x264-CHD.mkv
2013-10-10 12:20:01,543 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /Users/laurent/Downloads/torente/movies/Europa.Report.2013.BluRay.720p.DTS.x264-CHD/Europa.Report.2013.BluRay.720p.DTS.x264-CHD.mkv, ignore case: false
2013-10-10 12:20:01,544 DEBUG [MediaItemDAOImpl] Media item /Users/laurent/Downloads/torente/movies/Europa.Report.2013.BluRay.720p.DTS.x264-CHD/Europa.Report.2013.BluRay.720p.DTS.x264-CHD.mkv already exists in DB
2013-10-10 12:20:01,544 DEBUG [LibraryAdditionsCheckerThread] Found file 'sample.mkv', checking if it's already in the Library
2013-10-10 12:20:01,544 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /Users/laurent/Downloads/torente/movies/Europa.Report.2013.BluRay.720p.DTS.x264-CHD/sample.mkv
2013-10-10 12:20:01,544 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /Users/laurent/Downloads/torente/movies/Europa.Report.2013.BluRay.720p.DTS.x264-CHD/sample.mkv, ignore case: false
2013-10-10 12:20:01,545 DEBUG [MediaItemDAOImpl] Media item /Users/laurent/Downloads/torente/movies/Europa.Report.2013.BluRay.720p.DTS.x264-CHD/sample.mkv already exists in DB
2013-10-10 12:20:01,545 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/movies/Only.God.Forgives.2013.720p.BluRay.DTS.x264.RoSubbed-CzT
2013-10-10 12:20:01,545 DEBUG [LibraryAdditionsCheckerThread] Found file 'Only.God.Forgives.2013.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv', checking if it's already in the Library
2013-10-10 12:20:01,545 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /Users/laurent/Downloads/torente/movies/Only.God.Forgives.2013.720p.BluRay.DTS.x264.RoSubbed-CzT/Only.God.Forgives.2013.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv
2013-10-10 12:20:01,545 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /Users/laurent/Downloads/torente/movies/Only.God.Forgives.2013.720p.BluRay.DTS.x264.RoSubbed-CzT/Only.God.Forgives.2013.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv, ignore case: false
2013-10-10 12:20:01,546 DEBUG [MediaItemDAOImpl] Media item /Users/laurent/Downloads/torente/movies/Only.God.Forgives.2013.720p.BluRay.DTS.x264.RoSubbed-CzT/Only.God.Forgives.2013.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv already exists in DB
2013-10-10 12:20:01,546 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/movies/Pain.and.Gain.2013.NTSC.DVDR.RoSubbed-CzT
2013-10-10 12:20:01,546 DEBUG [LibraryAdditionsCheckerThread] Found file 'Sample.vob', checking if it's already in the Library
2013-10-10 12:20:01,546 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /Users/laurent/Downloads/torente/movies/Pain.and.Gain.2013.NTSC.DVDR.RoSubbed-CzT/Sample.vob
2013-10-10 12:20:01,547 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /Users/laurent/Downloads/torente/movies/Pain.and.Gain.2013.NTSC.DVDR.RoSubbed-CzT/Sample.vob, ignore case: false
2013-10-10 12:20:01,547 DEBUG [MediaItemDAOImpl] Media item /Users/laurent/Downloads/torente/movies/Pain.and.Gain.2013.NTSC.DVDR.RoSubbed-CzT/Sample.vob already exists in DB
2013-10-10 12:20:01,547 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/movies/Rise.of.the.Guardians.3D.2012.1080p.BluRay.Half.OU.DD5.1.x264-HDMaNiAcS
2013-10-10 12:20:01,548 DEBUG [LibraryAdditionsCheckerThread] Found file 'Rise.of.the.Guardians.3D.2012.1080p.BluRay.Half.OU.DD5.1.x264-HDMaNiAcS.mkv', checking if it's already in the Library
2013-10-10 12:20:01,548 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /Users/laurent/Downloads/torente/movies/Rise.of.the.Guardians.3D.2012.1080p.BluRay.Half.OU.DD5.1.x264-HDMaNiAcS/Rise.of.the.Guardians.3D.2012.1080p.BluRay.Half.OU.DD5.1.x264-HDMaNiAcS.mkv
2013-10-10 12:20:01,548 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /Users/laurent/Downloads/torente/movies/Rise.of.the.Guardians.3D.2012.1080p.BluRay.Half.OU.DD5.1.x264-HDMaNiAcS/Rise.of.the.Guardians.3D.2012.1080p.BluRay.Half.OU.DD5.1.x264-HDMaNiAcS.mkv, ignore case: false
2013-10-10 12:20:01,548 DEBUG [MediaItemDAOImpl] Media item /Users/laurent/Downloads/torente/movies/Rise.of.the.Guardians.3D.2012.1080p.BluRay.Half.OU.DD5.1.x264-HDMaNiAcS/Rise.of.the.Guardians.3D.2012.1080p.BluRay.Half.OU.DD5.1.x264-HDMaNiAcS.mkv already exists in DB
2013-10-10 12:20:01,548 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/movies/Rise.of.the.Guardians.3D.2012.1080p.BluRay.Half.OU.DD5.1.x264-HDMaNiAcS/subs
2013-10-10 12:20:01,549 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/movies/The.Call.2013.720p.BluRay.DTS.x264.RoSubbed-CzT
2013-10-10 12:20:01,549 DEBUG [LibraryAdditionsCheckerThread] Found file 'The.Call.2013.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv', checking if it's already in the Library
2013-10-10 12:20:01,549 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /Users/laurent/Downloads/torente/movies/The.Call.2013.720p.BluRay.DTS.x264.RoSubbed-CzT/The.Call.2013.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv
2013-10-10 12:20:01,549 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /Users/laurent/Downloads/torente/movies/The.Call.2013.720p.BluRay.DTS.x264.RoSubbed-CzT/The.Call.2013.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv, ignore case: false
2013-10-10 12:20:01,550 DEBUG [MediaItemDAOImpl] Media item /Users/laurent/Downloads/torente/movies/The.Call.2013.720p.BluRay.DTS.x264.RoSubbed-CzT/The.Call.2013.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv already exists in DB
2013-10-10 12:20:01,550 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/movies/The.Colony.2013.720p.BluRay.DTS.x264.RoSubbed-CzT
2013-10-10 12:20:01,550 DEBUG [LibraryAdditionsCheckerThread] Found file 'The.Colony.2013.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv', checking if it's already in the Library
2013-10-10 12:20:01,550 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /Users/laurent/Downloads/torente/movies/The.Colony.2013.720p.BluRay.DTS.x264.RoSubbed-CzT/The.Colony.2013.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv
2013-10-10 12:20:01,550 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /Users/laurent/Downloads/torente/movies/The.Colony.2013.720p.BluRay.DTS.x264.RoSubbed-CzT/The.Colony.2013.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv, ignore case: false
2013-10-10 12:20:01,551 DEBUG [MediaItemDAOImpl] Media item /Users/laurent/Downloads/torente/movies/The.Colony.2013.720p.BluRay.DTS.x264.RoSubbed-CzT/The.Colony.2013.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv already exists in DB
2013-10-10 12:20:01,551 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/movies/The.Crown.and.the.Dragon.2013.720p.BluRay.DTS.x264-CzT
2013-10-10 12:20:01,551 DEBUG [LibraryAdditionsCheckerThread] Found file 'The.Crown.and.the.Dragon.2013.720p.BluRay.DTS.x264-CzT.mkv', checking if it's already in the Library
2013-10-10 12:20:01,551 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /Users/laurent/Downloads/torente/movies/The.Crown.and.the.Dragon.2013.720p.BluRay.DTS.x264-CzT/The.Crown.and.the.Dragon.2013.720p.BluRay.DTS.x264-CzT.mkv
2013-10-10 12:20:01,551 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /Users/laurent/Downloads/torente/movies/The.Crown.and.the.Dragon.2013.720p.BluRay.DTS.x264-CzT/The.Crown.and.the.Dragon.2013.720p.BluRay.DTS.x264-CzT.mkv, ignore case: false
2013-10-10 12:20:01,552 DEBUG [MediaItemDAOImpl] Media item /Users/laurent/Downloads/torente/movies/The.Crown.and.the.Dragon.2013.720p.BluRay.DTS.x264-CzT/The.Crown.and.the.Dragon.2013.720p.BluRay.DTS.x264-CzT.mkv already exists in DB
2013-10-10 12:20:01,552 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/movies/World.War.Z.2013.Unrated.Cut.720p.BluRay.DTS.x264.RoSubbed-CzT
2013-10-10 12:20:01,552 DEBUG [LibraryAdditionsCheckerThread] Found file 'World.War.Z.2013.Unrated.Cut.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv', checking if it's already in the Library
2013-10-10 12:20:01,552 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /Users/laurent/Downloads/torente/movies/World.War.Z.2013.Unrated.Cut.720p.BluRay.DTS.x264.RoSubbed-CzT/World.War.Z.2013.Unrated.Cut.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv
2013-10-10 12:20:01,552 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /Users/laurent/Downloads/torente/movies/World.War.Z.2013.Unrated.Cut.720p.BluRay.DTS.x264.RoSubbed-CzT/World.War.Z.2013.Unrated.Cut.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv, ignore case: false
2013-10-10 12:20:01,553 DEBUG [MediaItemDAOImpl] Media item /Users/laurent/Downloads/torente/movies/World.War.Z.2013.Unrated.Cut.720p.BluRay.DTS.x264.RoSubbed-CzT/World.War.Z.2013.Unrated.Cut.720p.BluRay.DTS.x264.RoSubbed-CzT.mkv already exists in DB
2013-10-10 12:20:01,553 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /Users/laurent/Downloads/torente/Native.Instruments.Traktor.Pro.2.v2.0.3.MAC.OSX-UNION
2013-10-10 12:20:01,577 DEBUG [RepositoryDAOImpl] Marking Repository 3 as scanned with current timestamp
2013-10-10 12:20:20,054 DEBUG [WebServer] I/O error: Broken pipe
2013-10-10 12:20:20,392 DEBUG [ServiioHttpService] Incoming request from /192.168.1.100:51734: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KD-65X9005A";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KD-65X9005A"; mv="1.7";,Host: 192.168.1.103:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 688,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2013-10-10 12:20:20,392 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2013-10-10 12:20:20,393 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.100
2013-10-10 12:20:20,393 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2013-10-10 12:20:20,397 DEBUG [ContentDirectory] Browse() called for renderer KD-65X9005A (profile sony2013) with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:rating,upnp:rating@type,upnp:class,res@resolution,res@av:mpfEntries,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2013-10-10 12:20:20,397 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-10-10 12:20:20,398 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2013-10-10 12:20:20,415 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-10-10 12:20:21,928 DEBUG [ServiioHttpService] Incoming request from /192.168.1.100:51735: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KD-65X9005A";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KD-65X9005A"; mv="1.7";,Host: 192.168.1.103:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 686,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2013-10-10 12:20:21,928 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2013-10-10 12:20:21,929 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.100
2013-10-10 12:20:21,929 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2013-10-10 12:20:21,933 DEBUG [ContentDirectory] Browse() called for renderer KD-65X9005A (profile sony2013) with parameters: objectID = 2, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:rating,upnp:rating@type,upnp:class,res@resolution,res@av:mpfEntries,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2013-10-10 12:20:21,933 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-10-10 12:20:21,934 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2 [No_Restriction]
2013-10-10 12:20:21,937 DEBUG [SeriesDAOImpl] Retrieving number of series
2013-10-10 12:20:21,939 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2013-10-10 12:20:21,946 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-10-10 12:21:01,191 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-10-10 12:21:01,214 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-10-10 12:22:01,214 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-10-10 12:22:01,214 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
wln
Post Thu Oct 10, 2013 9:35 am
Re: sony bravia 2013 problems
Could you provide information about these avi files ? (see signature link)
where or how can i see that signature???
Also there are times when the tv doesn t see the server and the only way to make it work is restart for the pc,or enter the activity monitor and stop the serviio process from there and then start it again...
Post Thu Oct 10, 2013 12:06 pm
(see my signature links)
below...
HowTo ...
wln
Post Thu Oct 10, 2013 7:25 pm
now with the 2013 profile,i guess it sees it,cause i noticed that it has some kind of automatic start for transcoding...that ffmpeg service...but it overheats the pc...it is keeping the i7 proccesor up to 60% of its capacity,which is very much...any idea from the log,what causes this?
Post Thu Oct 10, 2013 7:37 pm
Do you enable subtitle burning on serviio console ?
Do you have embedded subtitles on your files ?
wln
Post Thu Oct 10, 2013 7:48 pm
all 3 options in subtitles are checked,including the burned-in subtitles-only when required and the movies also have subtitles in it,but it runs well,only in some movies starts that ffmpeg process. For example,one movie in particular that i see it does like this all the time it is a mkv file...also in .avi also starts that ffmpeg process and overheats...the problem is that i left the pc runnig,stopped the movie and that process doesnt stop
I checked now for an .avi file and the tv sees the movie,but when i try to play,it says could not connect to media server,pls try again...
getting sick already of this...does anyone tryied apple tv? it works on all movie formats?
Post Fri Oct 11, 2013 6:45 am
wln wrote:all 3 options in subtitles are checked,including the burned-in subtitles-only when required and the movies also have subtitles in it,but it runs well,only in some movies starts that ffmpeg process.
Could you try to disabled these 3 options for subtitles and check if ffmpeg process is present and overheats ?
I suspect that the problem comes from the extraction of the embedded subtitle (done by a ffmpeg process), and for some reason I can't explain, this process can be very long !
Does your movies are in a local HDD (C: D:), a remote HDD (\\Share), or a SSD drive ?
Post Fri Oct 11, 2013 7:16 am
As an aside, you may want to check the cooling on your laptop - 50-60% CPU utilisation, even when sustained, shouldn't cause overheating. Check your vents for a buildup of lint etc.
Also try setting the number of CPU's being used for transcoding to the maximum you have (Serviio console, Delivery, Transcoding tab).
wln
Post Fri Oct 11, 2013 8:54 am
i did that,it uses 8 cores...there s nothing wrong with my laptop,serviio is the only application that does like this...normally i don t hear the fans,but when serviio starts that ffmpeg procces,the fans run loud...don t u think that s very much for such software to keep an i7 quad core proc to 60% and above usage??? and it s not temporary,even after i stop the movie,that ffmpeg procces doesn t stop,it runs until i stop it from activity monitor...that s not ok at all i think...
wln
Post Fri Oct 11, 2013 9:03 am
i will disable those options,but now i don t have any movie to try it...i erased that movie that was always starting the ffmpeg and the .avi files can not be played...it says on tv that could not acces the server,please try again...also my movies are on my hdd,local hdd. As soon as i find a movie that does something like this,i ll get back to you...but isn t suppose to see .avi files? i tried 5 different movies,i can see the movies titles on the tv,but can not be played...like i said...could not acces the server...i fogot to mention that the transcoding is off by default in the 2013 profile...should i turn it on? i m not very happy with the picture qualitty when transcoding is on...
back with an aswer
So i unchecked the subtitles options and also activate the transcoding...now it plays .avi files also,and ffmpeg doesn t start. Also i tried and check only the first option,allow subtitles and the other two off and same...the ffmpeg doesn t start...i ll leave it like this for now...hope u come up with a final version for the 2013 profile...let me know if you want me to test anything else and thanks for the answers
