Redirecting only serviio traffic via tunnel on Linux
wae3iejohhohZae5
Post Mon Oct 07, 2013 10:25 am
Let
  • serviio be the username running the Serviio process
  • eth0 be the primary interface where default traffic is sent out on
  • tun0 be the interface of the tunnel
  • 192.168.0.0/24 be the local area network ip subnet on eth0
  • 192.168.0.1 be the default gateway on the local area network eth0
  • 172.20.0.1 be the gateway on tun0
Then the following sends all Serviio traffic along tun0.
echo 2 > /proc/sys/net/ipv4/conf/tun0/rp_filter
iptables -t mangle -A OUTPUT -o eth0 -m owner --uid-owner serviio -j MARK --set-mark 11
iptables -t nat -A POSTROUTING -o tun0 -j MASQUERADE
ip rule add fwmark 11 table 11
ip route add 192.168.0.0/24 dev eth0 table 11 # no VPN for LAN
#ip route add 1.2.3.4 via 192.168.0.1 dev eth0 table 11 # no VPN for 1.2.3.4
ip route add default via 172.20.0.1 dev tun0 table 11
Post Mon Oct 07, 2013 11:43 am
Re: Redirecting only serviio traffic via tunnel on Linux
is this an actual guide? Maybe it should go to the wiki.
Iveky
Post Mon Oct 07, 2013 12:15 pm
but with little better explanation
wae3iejohhohZae5
Post Mon Oct 07, 2013 8:16 pm
I am just sharing this with you because it took me too many hours to figure it out. Feel free to improve it or put it on the wiki.
paniko
Post Thu Oct 10, 2013 6:27 am
wae3iejohhohZae5 wrote:I am just sharing this with you because it took me too many hours to figure it out. Feel free to improve it or put it on the wiki.
with this configuration you are able to route the uPnP traffic too?
Paniko
Sumsung EU46D6500 | XBox 360 | Samsung Galaxy S 6 Edge | Windows 10 - i7 64bit | Serviio 1.5.2 Pro
Beta Tester
wae3iejohhohZae5
Post Thu Oct 10, 2013 1:20 pm
I don't think so.
Return to General discussion
