3d movies
Gogica01
Post Fri Oct 11, 2013 1:27 pm
3d movies
Im new to this forum and the program servio in general. Im having problems when i try to play 3d movies. I have them on my computer and i use the share folder option which i then use with my samsung tv. The problem is i cant see the files on my tv when i access the shared folder. I could be a total retard and not c something obvius but im kinda stuck. Also sometimes when i play my blue ray movies they tend to studder. I use my servio over my home wireless so im kinda suprised it cant handle a movie stream (or i could be just talking shxx here ?)
Any help would be much appriciated.
Iveky
Post Fri Oct 11, 2013 3:23 pm
Re: 3d movies
wireless G isn't enough fast for HD, try wired connection or wireless N.
also, 3d movies from serviio are same as other movies, nothing special, so check out how to set properly serviio and it's database and 3d films will fit into it.
(i have one extra folder for them)
