Serviio console wont start
agucortes
Post Sat Oct 12, 2013 2:31 am
I have a problem with the console, i can't make it work.
I've read all the threads about this problem but i didnt find the answer.
Here is the log file
2013-10-11 23:27:37,745 INFO  [ServiioConsole] Starting Serviio Console
2013-10-11 23:27:37,903 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2013-10-11 23:27:38,696 INFO  [Messages] Loaded console message bundle for locale: en
2013-10-11 23:27:50,206 WARN  [ServiioStatusService] IllegalArgumentException occured. Returning error code 500 to the REST layer. Message: Invalid UUID string: 7b831ba999b44816909f0c341a682791
2013-10-11 23:27:50,315 ERROR [ServiioConsole] Unexpected exception occured: null
   at org.serviio.ui.view.swing.ServiioFrameView.onApplicationDataUpdate(ServiioFrameView.java:102)
   at org.serviio.console.ServiioConsole.updateLicense(ServiioConsole.java:284)
   at org.serviio.console.ServiioConsole.startLicenseCheckingThread(ServiioConsole.java:272)
   at org.serviio.console.ServiioConsole.main(ServiioConsole.java:108)
   at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
   at com.exe4j.runtime.WinLauncher.main(Unknown Source)
2013-10-11 23:27:50,343 INFO  [ServiioConsole] Leaving Serviio Console
so, please if anyone can help me.
PS: is there any link to download the ver 1.21?
Post Sat Oct 12, 2013 10:43 am
Re: Serviio console wont start
Do you have the Pro license? Did you change it in any way?
agucortes
Post Sat Oct 12, 2013 3:56 pm
yes, i have the pro license.
I've unistalled the 1.3.1 because it has problems with the playback, the server gets disconnected.
With the 1.2.1 everything is working fine, but the console isn't working. Before of all the procedure, the console was working fine.
Post Sat Oct 12, 2013 7:58 pm
are you using server and the console, both the same version?
agucortes
Post Sat Oct 12, 2013 10:43 pm
well, i've uninstalled everything and then install again; and the console start working.
So perhaps the problem was the difference of version.
I thought that i've made that procedure previously, evidently that wasn't real.
Sorry for the bother and thanks for the help
Return to User experiences
