Serviio on headless Linux
brainbug
Post Sat Oct 12, 2013 8:45 pm
I'm trying to run Serviio on a headless Linux server box. For some reason, even though the serviio startup script explicitly sets java.awt.headless=true, it tries to access the java.awt.AppContext and java.awt.SunToolkit all the time, which fails miserably:
Exception in thread "LibraryAdditionsCheckerThread" java.lang.NoClassDefFoundError: Could not initialize class sun.awt.SunToolkit
        at sun.awt.AppContext$2.run(AppContext.java:271)
        at sun.awt.AppContext$2.run(AppContext.java:260)
        at sun.awt.AppContext.initMainAppContext(AppContext.java:260)
        at sun.awt.AppContext.access$200(AppContext.java:133)
        at sun.awt.AppContext$3.run(AppContext.java:314)
        at sun.awt.AppContext$3.run(AppContext.java:298)
        at sun.awt.AppContext.getAppContext(AppContext.java:297)
        at sun.awt.AppContext$6.getContext(AppContext.java:841)
        at sun.misc.SharedSecrets.getJavaAWTAccess(SharedSecrets.java:201)
        at java.util.TimeZone.getDefaultInAppContext(TimeZone.java:730)
        at java.util.TimeZone.getDefaultRef(TimeZone.java:620)
        at java.util.GregorianCalendar.<init>(GregorianCalendar.java:586)
        at org.apache.derby.iapi.types.SQLTimestamp.setNumericTimestamp(Unknown Source)
        at org.apache.derby.iapi.types.SQLTimestamp.setValue(Unknown Source)
        at org.apache.derby.impl.jdbc.EmbedPreparedStatement.setTimestamp(Unknown Source)
        at org.serviio.util.JdbcUtils.setTimestampValueOnStatement(JdbcUtils.java:239)
        at org.serviio.library.dao.ImageDAOImpl.create(ImageDAOImpl.java:69)
        at org.serviio.library.dao.ImageDAOImpl.create(ImageDAOImpl.java:37)
        at org.serviio.library.local.service.ImageService.addImageToLibrary(ImageService.java:79)
        at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.addNewMediaFile(LibraryAdditionsCheckerThread.java:191)
        at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.searchForNewFiles(LibraryAdditionsCheckerThread.java:145)
        at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.searchForNewFiles(LibraryAdditionsCheckerThread.java:134)
        at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.run(LibraryAdditionsCheckerThread.java:83)
As a result, it's impossible to do pretty much anything with the server.
The interesting thing is that with the same JRE on the same machine, test code executing the same calls runs just fine (e.g. new GregorianCalendar() or even SharedSecrets.getJavaAWTAccess(), which just returns null).
This is on an Arch Linux, running jre7-openjdk 7.u40_2.4.2-1
Edit: The offending AppContext gets initialized by this call:
 Daemon Thread [LibraryAdditionsCheckerThread] (Suspended (entry into method setJavaAWTAccess in sun.misc.SharedSecrets))
   sun.misc.SharedSecrets.setJavaAWTAccess(sun.misc.JavaAWTAccess) line: 195
   sun.awt.AppContext.<clinit>() line: 816
   javax.imageio.spi.IIORegistry.getDefaultInstance() line: 154
   javax.imageio.ImageIO.<clinit>() line: 65
   org.serviio.util.ImageUtils.resizeImageAsJPG(byte[], int, int) line: 61
   org.serviio.util.ImageUtils.resizeImageAsJPG(java.io.File, int, int) line: 109
   org.serviio.library.local.service.ImageService.createThumbnail(org.serviio.library.local.metadata.ImageMetadata) line: 312
   org.serviio.library.local.service.ImageService.addImageToLibrary(org.serviio.library.local.metadata.ImageMetadata, org.serviio.library.entities.Repository) line: 64
   org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.addNewMediaFile(org.serviio.library.entities.Repository, java.io.File, org.serviio.library.metadata.MediaFileType) line: 191
   org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.searchForNewFiles(java.io.File, org.serviio.library.entities.Repository) line: 145
   org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.searchForNewFiles(java.io.File, org.serviio.library.entities.Repository) line: 134
   org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.run() line: 83
Post Sun Oct 13, 2013 12:33 am
Re: Serviio on headless Linux
It's the image resize functionality. the -D parameter should get around this, so I'm not sure. Serviio normally runs on headless servers (like NASes), maybe try the Oracle Java instead of OpenJdk, if you can.
