Purge transcode dir
sleky
Post Thu Oct 17, 2013 6:52 pm
Purge transcode dir
Is it possible to safely purge the transcode directory?
root@nix-01:/transcoding# du -h Serviio/
23G   Serviio/transcoding-temp-13954-ios-ORIGINAL.stf
682M   Serviio/transcoding-temp-13956-serviigo_hls-MEDIUM.stf
37G   Serviio/
If I delete that dir, would it get rebuilt upon someone requesting media?
Post Thu Oct 17, 2013 9:23 pm
Re: Purge transcode dir
You can, if your next transcoded video is going to be a different one than what you have there. Or restart Serviio and then you can delete these files without any hesitation.
sleky
Post Fri Oct 18, 2013 12:12 am
Just the files? Dir as well? Just the directory that houses the transcoding. I can live with that. Thanks Zip!
Users browsing this forum: Google [Bot] and 44 guests
