Waiting for Serviio 1.3 for Synology NAS
blase
Post Mon Oct 14, 2013 11:03 am
Re: Waiting for Serviio 1.3 for Synology NAS
Result ./ffmpeg
DiskStation> ./ffmpeg
ffmpeg version 2.0-fa7e9f9-compiled_by_patters_for_Serviio Copyright (c) 2000-2013 the FFmpeg developers
  built on Oct 14 2013 00:38:28 with gcc 4.6.4 (Linaro GCC branch-4.6.4. Marvell GCC 201303-1655.6f19debc) 20120731 (prerelease)
  configuration: --arch=arm --enable-cross-compile --cross-prefix=/usr/local/arm-marvell-linux-gnueabi/bin/arm-marvell-linux-gnueabi- --target-os=linux --prefix=/usr/local/arm-marvell-linux-gnueabi --extra-cflags=-I/usr/local/arm-marvell-linux-gnueabi/include --enable-shared --disable-static --enable-pic --disable-ffplay --disable-ffserver --disable-neon --enable-thumb --disable-debug --enable-pthreads --enable-libmp3lame --enable-libshine --enable-librtmp --enable-libass --enable-libx264 --enable-gpl --pkg-config=pkg-config --extra-version=compiled_by_patters_for_Serviio
  libavutil      52. 46.101 / 52. 46.101
  libavcodec     55. 35.100 / 55. 35.100
  libavformat    55. 19.100 / 55. 19.100
  libavdevice    55.  4.100 / 55.  4.100
  libavfilter     3. 88.101 /  3. 88.101
  libswscale      2.  5.101 /  2.  5.101
  libswresample   0. 17.103 /  0. 17.103
Use -h to get full help or, even better, run 'man ffmpeg'
Result lld ./ffmpeg
DiskStation> lld ./ffmpeg
-sh: lld: not found
neuronik
Post Wed Oct 16, 2013 9:45 pm
I'm late.. :)
NAS>  ./ffmpeg
NAS>  ldd ./ffmpeg
-ash: ldd: not found
patters
Post Thu Oct 17, 2013 4:21 pm
I have published the Serviio 1.3.1 package on the repo. DSM Package Center will show the update. Get it while it's hot!
Six
Post Thu Oct 17, 2013 4:27 pm
Thank you!
But error on DS213+ (QorIQ) :
2013-10-17 19:32:26,980 INFO [UpdateChecker] Checking if a new version is available
2013-10-17 19:32:27,040 ERROR [MediaServer] FFMPEG not found. Serviio will not work properly.
And all mkv files are unrecognized. Message: Unknown video type.
EDIT: Thank you Patters for quick solution!
patters wrote:I have published the Serviio 1.3.1 package on the repo. DSM Package Center will show the update. Get it while it's hot!
drSHLEFF
Post Thu Oct 17, 2013 5:51 pm
Patters, and what about the owners of Intel platform, we should wait for the update? For example I have DS713+
Koramchad
Post Thu Oct 17, 2013 6:25 pm
I got the following error when updating on my DS213j: https://www.dropbox.com/s/7r325wqsdr6ke4o/Screenshot%202013-10-17%2011.04.16.png
I went ahead and downloaded the file manually from http://sourceforge.net/projects/dejavu/ ... javu/2.33/ and put in in the public folder. After that it installed normally.
I'll write back when I check everything is working OK.
Thanks patters!
Koramchad
Post Thu Oct 17, 2013 8:15 pm
Everything working wonderfully!
I had to add again all my media folders, but other than that awesome work patters!
neuronik
Post Thu Oct 17, 2013 8:30 pm
hurray! :D
Ger-sh-win
Post Thu Oct 17, 2013 9:11 pm
Got following error on my synology ds812+ when running ffmpeg:
./ffmpeg: error while loading shared libraries: libz.so: cannot open shared object file: No such file or directory
Renamed the file libz.so.1 to libz.so in the lib-folder and now everything seems fine.
Thanks :D
Ryster
Post Thu Oct 17, 2013 10:44 pm
Unfortunately after waiting for and looking forward to 1.3.1, I find it's rendered my media box useless. It seems this new version doesn't want to scan my folders for files.
I've removed the folders from the "Shared Folders" panel, and re-added them, and I've checked the serviio user has rights to my media share on the NAS box.
No matter what I do though, when I click Force refresh, the checking for new files light only stays green for a couple of seconds before going back to red with no files scanned.
My renderer sees the TV folder, but says there are no files within.
Any ideas please?
Update: Well I just found the log in the Package Center. Seems this new version thinks my videos are an "Unknown video file type." all of a sudden. Here's a line from the log:
2013-10-17 23:46:09.799 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Game of Thrones - 2x07 - A Man Without Honor.mkv). Message: Unknown video file type.
Confused. What's changed?
Update 2: After completely removing Serviio and reinstalling it again, all now seems well. A shame the update wasn't as easy as it first appeared.
Serviio Pro Purchaser - 24/07/2012
drSHLEFF
Post Fri Oct 18, 2013 5:25 am
Thank you! On my the DS713 + upgrade was no problem and without dancing with tambourines. It seem all working good :-)
patters
Post Fri Oct 18, 2013 6:20 am
Ger-sh-win wrote:Got following error on my synology ds812+ when running ffmpeg:
Thanks :D
Yes I fixed a zlib linking issue with FFmpeg (QorIQ and Intel) a few hours after publishing. Sorry!
zlib has a bug that means it can build without a soname (which is a version number) which then confused the library linker when building all the other libs that use it:
http://forums.gentoo.org/viewtopic-p-7156392.html
Morbeas
Post Fri Oct 18, 2013 6:25 am
patters wrote:Yes I fixed a zlib linking issue with FFmpeg (QorIQ and Intel) a few hours after publishing. Sorry!
I'm assuming this means a new one will be published soon?
subora
Post Fri Oct 18, 2013 4:01 pm
uninstall serviio, uninstall Java. install last java, install last serviio 1.3.1 21 on synology ds413 qoriq. serviio can't starting. no even log directory with debug option
patters
Post Fri Oct 18, 2013 4:47 pm
What does the Java package log tab show?
patters
Done.
subora
Post Fri Oct 18, 2013 4:59 pm
patters wrote:What does the Java package log tab show?
Error occurred during initialization of VM
java/lang/ClassNotFoundException: error in opening JAR file /volumel/@appstore/java7/jre/lib/rt.jar
System installed locales:
С
en_US.utf8
POSIX
JAVA_HOME=/volumel/@appstore/java7/jre
TZ=Europe/Moscow
any idea?
ejre-7u45-fcs-b15-linux-ppc-e500v2-headless-26_sep_2013.tar.gz was installed
wow! it was error in downloaded java install archive... sorry
patters
Post Fri Oct 18, 2013 11:57 pm
So it works now?
subora
Post Sat Oct 19, 2013 6:26 am
patters wrote:So it works now?
yes. no problems
Morbeas
Post Sat Oct 19, 2013 6:54 am
Woohoo, it works! Thank you sir. :)
Previous
