Re: NHL Gamecenter Live
However nothing is shown on in the library under 'Online' in videos.
My NHL GCL subscription is active.
Anyone has the same issue ? I'm on Windows 8 x64, serviio 1.3.1
Edit: When browsing from my xbox I have this message now:
<string>$JAVAROOT/dependencies/http-builder-0.7-SNAPSHOT.jar</string>
<string>$JAVAROOT/dependencies/antlr-2.7.7.jar</string>
<string>$JAVAROOT/dependencies/appengine-api-1.0-sdk-1.3.8.jar</string>
<string>$JAVAROOT/dependencies/asm-3.2.jar</string>
<string>$JAVAROOT/dependencies/asm-analysis-3.2.jar</string>
<string>$JAVAROOT/dependencies/asm-commons-3.2.jar</string>
<string>$JAVAROOT/dependencies/asm-tree-3.2.jar</string>
<string>$JAVAROOT/dependencies/asm-util-3.2.jar</string>
<string>$JAVAROOT/dependencies/commons-beanutils-1.8.0.jar</string>
<string>$JAVAROOT/dependencies/commons-codec-1.6.jar</string>
<string>$JAVAROOT/dependencies/commons-collections-3.2.1.jar</string>
<string>$JAVAROOT/dependencies/commons-lang-2.4.jar</string>
<string>$JAVAROOT/dependencies/commons-logging-1.1.1.jar</string>
<string>$JAVAROOT/dependencies/ezmorph-1.0.6.jar</string>
<string>$JAVAROOT/dependencies/groovy-1.8.8.jar</string>
<string>$JAVAROOT/dependencies/httpclient-4.2.1.jar</string>
<string>$JAVAROOT/dependencies/httpcore-4.2.1.jar</string>
<string>$JAVAROOT/dependencies/json-lib-2.3-jdk15.jar</string>
<string>$JAVAROOT/dependencies/nekohtml-1.9.16.jar</string>
<string>$JAVAROOT/dependencies/signpost-commonshttp4-1.2.1.1.jar</string>
<string>$JAVAROOT/dependencies/signpost-core-1.2.1.1.jar</string>
<string>$JAVAROOT/dependencies/xercesImpl-2.9.1.jar</string>
<string>$JAVAROOT/dependencies/xml-apis-1.4.01.jar</string>
<string>$JAVAROOT/dependencies/xml-resolver-1.2.jar</string>
Munq wrote:Hello,
I'm running Serviio on Mac streaming to my WDTV Live. I followed the instructions outlined in the post above. The streams appear on my WDTV, but it tells me "Unable to play the selected file. Please see the User Manual for a list of supported file formats." My log gives the following message:6 errors
Any ideas?
allmac wrote:I believe you did not step 5.
After unzip HTTP-Builder, inside the unziped folder you will see many things.
Including a dependencies folder and a http-builder-0.7-SNAPSHOT.jar file.
You need to copy the file http-builder-0.7-SNAPSHOT.jar inside dependeces folder, and after this you will copy dependencies folder from HTTP-Builder into Java folder.
*** One more think!!
Info.plist file is different for each Serviio version.
So... you need only add the following lines in the correct place.Munq wrote:Hello,
Any ideas?
2013-10-20 18:21:32,408 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000010001336, format AVC_TS_MP_SD_AC3_ISO and profile Generic DLNA profile
2013-10-20 18:21:32,409 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file http://nlds135.cdnak.neulion.com/nlds/nhl/bluejackets/as/live/bluejackets_hd_ced.m3u8
2013-10-20 18:21:32,409 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://nlds135.cdnak.neulion.com/nlds/nhl/bluejackets/as/live/bluejackets_hd_ced.m3u8: AVC_TS_MP_SD_AC3_ISO
2013-10-20 18:21:32,411 WARN [GETMethodProcessor] A range header was found on the incoming request for a live stream, sending back the whole stream
2013-10-20 18:21:32,411 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000010001336 (online)
2013-10-20 18:21:32,411 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2013-10-20 18:21:32,412 DEBUG [VideoDeliveryEngine] Delivering item '1000000010001336' for client 'Identifier=192.168.1.110, Profile=Generic DLNA profile'
2013-10-20 18:21:32,412 DEBUG [VideoDeliveryEngine] Delivering file 'http://nlds135.cdnak.neulion.com/nlds/nhl/bluejackets/as/live/bluejackets_hd_ced.m3u8' using transcoding
2013-10-20 18:21:32,412 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.1.110, Profile=Generic DLNA profile'
2013-10-20 18:21:32,413 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: http://nlds135.cdnak.neulion.com/nlds/nhl/bluejackets/as/live/bluejackets_hd_ced.m3u8
2013-10-20 18:21:32,413 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -analyzeduration 10000000 -fflags +genpts -threads auto -i http://nlds135.cdnak.neulion.com/nlds/nhl/bluejackets/as/live/bluejackets_hd_ced.m3u8 -y -threads auto -c:v copy -c:a ac3 -b:a 384k -ar 48000 -ac 1 -map 0:1 -map 0:0 -sn -f mpegts pipe:
2013-10-20 18:21:34,255 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error. Detailed output follows.
[http @ 01F19A80] HTTP error 403 Forbidden
Unable to open key file http://nlsk.neulion.com/nlsk/hls/securekey?id=135&url=/nlds/nhl/bluejackets/as/live/bluejackets_hd_800/20131020180000.m3u8.key
[hls,applehttp @ 01EFBF80] Error when loading first segment 'http://nlds135.cdnak.neulion.com/nlds/nhl/bluejackets/as/live/bluejackets_hd_800_20131020203510.ts'
http://nlds135.cdnak.neulion.com/nlds/nhl/bluejackets/as/live/bluejackets_hd_ced.m3u8: Invalid data found when processing input
2013-10-20 18:21:34,255 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2013-10-20 18:21:36,240 DEBUG [SearchManager] Committing search index
2013-12-08 21:13:07,743 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2013-12-08 21:13:07,742 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2013-12-08 21:13:07,742 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2013-12-08 21:13:10,444 INFO [WebServer] WebServer starting on port 8895
2013-12-08 21:13:10,577 INFO [Device] Updated bound IP address of Device with UUID: 4e97ce0c-21f3-3bf7-a94b-ac43c325a2c0, bound address: 192.168.1.5
2013-12-08 21:13:10,577 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-12-08 21:13:10,578 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-12-08 21:13:10,578 INFO [EventDispatcher] Starting EventDispatcher
2013-12-08 21:13:10,602 INFO [RendererSearchSender] Searching for Renderer devices
2013-12-08 21:13:10,604 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.1.5, timeout = 0
2013-12-08 21:13:51,887 WARN [PlaylistParser] Could not find a suitable playlist parser for file 'E:\Kims Music\Matchbox 20 Yourself Or Someone Like You\Matchbox 20 - Yourself Or Someone Like You.pls', it is either not supported or the file is corrupted.
2013-12-08 21:17:38,484 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2013-12-08 21:17:38,484 INFO [WebServer] WebServer shutting down
2013-12-08 21:17:38,485 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2013-12-08 21:17:38,485 INFO [EventDispatcher] Leaving EventDispatcher
2013-12-08 21:17:38,485 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2013-12-08 21:17:40,389 INFO [WebServer] WebServer starting on port 8895
2013-12-08 21:17:40,523 INFO [Device] Updated bound IP address of Device with UUID: 4e97ce0c-21f3-3bf7-a94b-ac43c325a2c0, bound address: 192.168.1.5
2013-12-08 21:17:40,523 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-12-08 21:17:40,523 INFO [EventDispatcher] Starting EventDispatcher
2013-12-08 21:17:40,523 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-12-08 21:17:40,544 INFO [RendererSearchSender] Searching for Renderer devices
2013-12-08 21:17:40,544 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.1.5, timeout = 0
Directory of C:\Program Files\Serviio\lib
12/08/2013 09:17 PM <DIR> .
12/08/2013 09:17 PM <DIR> ..
05/15/2010 08:21 AM 445,288 antlr-2.7.7.jar
12/02/2010 09:50 AM 11,648,873 appengine-api-1.0-sdk-1.3.8.jar
05/15/2010 08:21 AM 43,398 asm-3.2.jar
05/15/2010 08:22 AM 17,985 asm-analysis-3.2.jar
05/15/2010 08:22 AM 33,094 asm-commons-3.2.jar
05/15/2010 08:22 AM 21,878 asm-tree-3.2.jar
05/15/2010 08:22 AM 36,551 asm-util-3.2.jar
05/15/2010 08:21 AM 231,320 commons-beanutils-1.8.0.jar
05/15/2010 08:21 AM 46,725 commons-codec-1.3.jar
08/07/2013 06:20 PM 46,725 commons-codec.jar
05/15/2010 08:22 AM 575,389 commons-collections-3.2.1.jar
08/07/2013 06:20 PM 707,972 commons-imaging.jar
08/07/2013 06:20 PM 163,151 commons-io.jar
08/07/2013 06:20 PM 268,794 commons-jxpath.jar
05/15/2010 08:20 AM 261,809 commons-lang-2.4.jar
08/07/2013 06:20 PM 284,220 commons-lang.jar
05/15/2010 08:21 AM 60,686 commons-logging-1.1.1.jar
08/07/2013 06:20 PM 189,284 concurrent.jar
08/07/2013 06:20 PM 329,073 dcraw.exe
02/16/2013 12:43 PM <DIR> dependencies
08/07/2013 06:20 PM 2,831,358 derby.jar
05/15/2010 08:21 AM 86,487 ezmorph-1.0.6.jar
08/07/2013 06:20 PM 14,559,744 ffmpeg.exe
08/07/2013 06:20 PM 879,259 freemarker.jar
03/18/2011 07:39 AM 5,097,471 groovy-1.7.10.jar
08/07/2013 06:20 PM 6,167,362 groovy-all.jar
08/07/2013 06:20 PM 173,590 gson.jar
12/08/2013 08:47 PM <DIR> http-builder-0.5.2
12/27/2011 12:43 PM 449,973 http-builder-0.5.2.jar
12/08/2013 09:12 PM <DIR> http-builder-0.7-SNAPSHOT
09/19/2010 12:11 PM 292,893 httpclient-4.0.3.jar
05/15/2010 08:22 AM 172,888 httpcore-4.0.1.jar
08/07/2013 06:20 PM 174,611 httpcore.jar
12/08/2013 09:17 PM 1,514 Info.plist
08/07/2013 06:20 PM 779,880 jaudiotagger.jar
08/07/2013 06:20 PM 17,306 jcl-over-slf4j.jar
08/07/2013 06:20 PM 435,347 jcs.jar
08/07/2013 06:20 PM 153,253 jdom.jar
08/07/2013 06:20 PM 28,151 jnat-pmplib.jar
05/15/2010 08:21 AM 151,839 json-lib-2.3-jdk15.jar
08/07/2013 06:20 PM 4,461 jul-to-slf4j.jar
08/07/2013 06:20 PM 481,535 log4j.jar
08/07/2013 06:20 PM 1,583,470 lucene-analyzers-common.jar
08/07/2013 06:20 PM 2,215,242 lucene-core.jar
05/15/2010 08:21 AM 116,162 nekohtml-1.9.9.jar
08/07/2013 06:20 PM 4,363 org.restlet.ext.gson.jar
08/07/2013 06:20 PM 10,544 org.restlet.ext.net.jar
08/07/2013 06:20 PM 6,083 org.restlet.ext.xstream.jar
08/07/2013 06:20 PM 703,270 org.restlet.jar
08/07/2013 06:20 PM 52,263 padlock.jar
12/27/2011 12:43 PM 13,526 pom.xml
08/07/2013 06:20 PM 252,769 rome-modules.jar
08/07/2013 06:20 PM 219,683 rome.jar
08/07/2013 06:20 PM 162,481 sbbi-upnp.jar
08/07/2013 06:20 PM 441,616 serviio-client.jar
08/07/2013 06:20 PM 895,558 serviio-media-browser.jar
08/07/2013 06:20 PM 1,598,688 serviio.jar
09/16/2010 09:46 AM 6,456 signpost-commonshttp4-1.2.1.1.jar
09/16/2010 09:46 AM 44,557 signpost-core-1.2.1.1.jar
08/07/2013 06:20 PM 25,496 slf4j-api.jar
08/07/2013 06:20 PM 9,750 slf4j-log4j12.jar
08/07/2013 06:20 PM 42,451 streamflyer-core.jar
08/07/2013 06:20 PM 18,629 winp.jar
08/07/2013 06:20 PM 7,680 winp.x64.dll
05/15/2010 08:21 AM 1,212,965 xercesImpl-2.8.1.jar
09/23/2011 07:47 PM 220,536 xml-apis-1.4.01.jar
05/15/2010 08:21 AM 84,091 xml-resolver-1.2.jar
08/07/2013 06:20 PM 481,672 xstream.jar
65 File(s) 58,781,138 bytes
5 Dir(s) 9,672,077,312 bytes freeMunq wrote:Hello,
2013-10-19 18:14:18,757 WARN [PluginCompilerThread] Plugin NHLGameCenterPlugin.groovy failed to compile: startup failed:
/Applications/serviio-1.3.1-osx/Serviio.app/Contents/Resources/Java/plugins/NHLGameCenterPlugin.groovy: 9: unable to resolve class groovyx.net.http.ContentType
@ line 9, column 1.
import static groovyx.net.http.ContentType.*
@ line 9, column 1.
/Applications/serviio-1.3.1-osx/Serviio.app/Contents/Resources/Java/plugins/NHLGameCenterPlugin.groovy: 52: unable to resolve class HTTPBuilder
@ line 52, column 16.
def tvHttp = new HTTPBuilder(tvAuthUrl);
/Applications/serviio-1.3.1-osx/Serviio.app/Contents/Resources/Java/plugins/NHLGameCenterPlugin.groovy: 104: unable to resolve class HTTPBuilder
@ line 104, column 16.
def tvHttp = new HTTPBuilder(tvReqUrl);
/Applications/serviio-1.3.1-osx/Serviio.app/Contents/Resources/Java/plugins/NHLGameCenterPlugin.groovy: 137: unable to resolve class HTTPBuilder
@ line 137, column 22.
def tvGameHttp = new HTTPBuilder('http://gamecenter.nhl.com');
/Applications/serviio-1.3.1-osx/Serviio.app/Contents/Resources/Java/plugins/NHLGameCenterPlugin.groovy: 213: unable to resolve class HTTPBuilder
@ line 213, column 16.
Any ideas?
2014-01-08 22:36:20,358 WARN [ProcessExecutor] Process /Applications/serviio-1.3.1-osx/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
[http @ 0x16379a0] HTTP error 403 Forbidden
Unable to open key file http://nlsk.neulion.com/nlsk/hls/securekey?id=143&url=/nlds/nhl/senators/as/live/senators_hd_800/20140108180000.m3u8.key
[hls,applehttp @ 0x1988800] Error when loading first segment 'http://nlds143.cdnak.neulion.com/nlds/nhl/senators/as/live/senators_hd_800_20140109010810.ts'
http://nlds143.cdnak.neulion.com/nlds/nhl/senators/as/live/senators_hd_ced.m3u8: Invalid data found when processing input
2014-01-11 15:47:02,222 DEBUG [ServiioHttpService] Incoming request from /192.168.0.12:48571: HEAD
/resource/1000000010003385/MEDIA_ITEM/AVC_TS_MP_SD_AC3_ISO-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 192.168.0.10:8895]]
2014-01-11 15:47:02,222 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.12
2014-01-11 15:47:02,222 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.12, Profile=Samsung TV / player
(C/D-series)'
2014-01-11 15:47:02,222 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000010003385 and type 'MEDIA_ITEM' received
2014-01-11 15:47:02,222 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000010003385 (online)
2014-01-11 15:47:02,222 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2014-01-11 15:47:02,223 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2014-01-11 15:47:02,223 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000010003385, format AVC_TS_MP_SD_AC3_ISO and profile
Samsung TV / player (C/D-series)
2014-01-11 15:47:02,223 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file
http://devimages.apple.com/iphone/samples/bipbop/bipbopall.m3u8
2014-01-11 15:47:02,223 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file
http://devimages.apple.com/iphone/samples/bipbop/bipbopall.m3u8: AVC_TS_MP_SD_AC3_ISO
2014-01-11 15:47:02,223 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date:
Sat, 11 Jan 2014 14:47:02 GMT,Server: Windows 8, UPnP/1.0 DLNADOC/1.50, Serviio/1.4,Cache-control: no-cache,contentFeatures.dlna.org:
DLNA.ORG_PN=AVC_TS_MP_SD_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org:
Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-01-11 15:47:02,223 WARN [WebServer] Unrecoverable HTTP protocol violation: Content-Length header already present
2014-01-11 15:47:02,233 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:c40a518f-6e4b-3d4a-b2ea-
f39bd2e8b629 from address /192.168.0.12:1025s
2014-01-11 15:47:02,233 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.12:1025
2014-01-11 15:47:02,439 DEBUG [ServiioHttpService] Incoming request from /192.168.0.12:43323: HEAD
/resource/1000000010003385/MEDIA_ITEM/AVC_TS_MP_SD_AC3_ISO-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2014-01-11 15:47:02,439 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.12
2014-01-11 15:47:02,439 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.12, Profile=Samsung TV / player
(C/D-series)'
2014-01-11 15:47:02,439 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000010003385 and type 'MEDIA_ITEM' received
2014-01-11 15:47:02,439 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000010003385 (online)
2014-01-11 15:47:02,439 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2014-01-11 15:47:02,440 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2014-01-11 15:47:02,440 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000010003385, format AVC_TS_MP_SD_AC3_ISO and profile
2014-01-11 15:47:02,440 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file
2014-01-11 15:47:02,440 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file
2014-01-11 15:47:02,441 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date:
Sat, 11 Jan 2014 14:47:02 GMT,Server: Windows 8, UPnP/1.0 DLNADOC/1.50, Serviio/1.4,Cache-control: no-cache,transferMode.dlna.org:
2014-01-11 15:47:02,441 WARN [WebServer] Unrecoverable HTTP protocol violation: Content-Length header already present
2014-01-11 15:47:02,534 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:c40a518f-6e4b-3d4a-b2ea-
2014-01-11 15:47:02,534 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.12:1025
2014-01-11 15:47:02,838 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:c40a518f-6e4b-3d4a-b2ea-
2014-01-11 15:47:02,838 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.12:1025
2014-01-11 15:47:03,739 DEBUG [ServiioHttpService] Incoming request from /192.168.0.12:40527: HEAD
2014-01-11 15:47:03,739 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.12
2014-01-11 15:47:03,740 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.12, Profile=Samsung TV / player
(C/D-series)'
2014-01-11 15:47:03,740 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000010003385 and type 'MEDIA_ITEM' received
2014-01-11 15:47:03,740 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000010003385 (online)
2014-01-11 15:47:03,740 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2014-01-11 15:47:03,740 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000010003385, format AVC_TS_MP_SD_AC3_ISO and profile
2014-01-11 15:47:03,740 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file
2014-01-11 15:47:03,740 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file
2014-01-11 15:47:03,740 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date:
Sat, 11 Jan 2014 14:47:03 GMT,Server: Windows 8, UPnP/1.0 DLNADOC/1.50, Serviio/1.4,Cache-control: no-cache,transferMode.dlna.org:
2014-01-11 15:47:03,741 WARN [WebServer] Unrecoverable HTTP protocol violation: Content-Length header already present
2014-01-11 15:47:03,972 DEBUG [ServiioHttpService] Incoming request from /192.168.0.12:41148: HEAD
2014-01-11 15:47:03,972 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.12
2014-01-11 15:47:03,973 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.12
2014-01-11 15:47:03,973 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.12, Profile=Samsung TV / player
(C/D-series)'
2014-01-11 15:47:03,973 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000010003385 and type 'MEDIA_ITEM' received
2014-01-11 15:47:03,973 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000010003385 (online)
2014-01-11 15:47:03,973 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2014-01-11 15:47:03,974 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000010003385, format AVC_TS_MP_SD_AC3_ISO and profile
2014-01-11 15:47:03,974 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file
2014-01-11 15:47:03,974 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file
2014-01-11 15:47:03,974 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date:
2014-01-11 15:47:03,974 WARN [WebServer] Unrecoverable HTTP protocol violation: Content-Length header already present
2014-01-11 15:47:05,485 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:byebye) message from Renderer 4411e97e-5689-8e7c-1aaa-
e8340d256dc4 from address 192.168.0.12
2014-01-11 15:47:05,485 DEBUG [RendererManager] Removing renderer 4411e97e-5689-8e7c-1aaa-e8340d256dc4 from list of active renderers
lapincube wrote:Hello, i have a problem with the streaming part
Using Serviio 1.4 with http-builder 0.7 (i tried 0.5 to 0.7 same problem) and Samsung UE40D5000
I can list the games but can't stream them
Here is my debug
- Code:
(C/D-series)'
(C/D-series)'
(C/D-series)'
(C/D-series)'
If i try with mediabrowser, it's not working too. I have a screen like oxez (http://i.imgur.com/hkxfMrH.png)
Do you have an idea ?
