Samsung LE40C750R2KXXU Help
J3rkMyTurk3y
Post Sun Oct 20, 2013 9:52 am
I usualy watch 3D movies on my pc thats conected to the TV, Now i discovered you can stream over your DLNAi thaught i would give it a try. I have just installed Serviio on my pc and have updated my firmware on the TV also. I have added my share folder and let it refresh and everything is there. When i try to play this .mkv file i get the error on the TV "Video Codec Not Supported". I went to find out what codec's my tv supporets here http://www.samsung.com/us/support/Suppo ... _seq=51097.
It says it supports .mkv files so now im lost. The file in question i opend with mediainfo and the results are below, any help would be much apreciated.
Complete name : C:\Users\J3rk My Turk3y\Downloads\Manchester United - Champions Story.mkv
Format : Matroska
Format version : Version 2
File size : 2.82 GiB
Duration : 26mn 30s
Overall bit rate : 15.2 Mbps
Writing application : libmatroska 1.3.0
Writing library : SolveigMM Matroska Muxer Version 1.0.1208.20
Format : AVC
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=4, N=12
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 14.6 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Original frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Language : English
Default : No
Forced : No
Color primaries : BT.709
Matrix coefficients : BT.709
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 26mn 30s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Original Channel count : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 72.8 MiB (3%)
Language : English
Default : No
Forced : No
Post Mon Oct 28, 2013 7:38 pm
Re: Samsung LE40C750R2KXXU Help
Probably something in the file's encoding settings that is causing the TV to reject the file. It normally plays h264 files, but can be picky with certain files.
Users browsing this forum: No registered users and 53 guests
