Post Sun Oct 20, 2013 6:20 pm
How Get Stream Movies from Sites Like Putlocker, etc
1) Open the Streaming link in Google Chrome
2) Right Click on Webpage, and click Inspect element
3) Now A Box Should appear on the bottom of the screen, select Network.
4) Refresh Browsers Link
5) Click Play on The Stream
6) Now Look In the Box that You Clicked on Network
for some thing like this http://media-b561.putlocker.com/downloa ... e7edeb.flv
you will know when you have the stream as the timeline will move and size of mb will increase
7) Now Right Click on Copy Link Address
8) Now Click on Serviio and Select Online Sources under Library.
9) Click Add, Select Source Type as Live Stream, Click Source URL and copy link address, click check url
if a green tickets comes up then click display name give the stream a name. Now Save
And you Should now be able to watch The Stream online
WORKS ON :-Putlocker, Vidxden.com, Shared2.me, Vidplay.net, Played.To (Remove ?start=0 from The Copyed Link), vodu.ch
