Maxing CPU, rogue playlist, and no router
sleky
Post Sun Oct 20, 2013 7:17 pm
Good morning. A few issues in this thread:
1 I have an Eee PC 1005HA that is having playback problems. Very jerky, and audio all jenky. The CPU maxes at 100% on playback. (The screen is ubber small, obviously, and it would be nice to reduce the size of the thumbnails to get more choices on the screen, as to opposed to 4 videos at a time...)
I think that a new profile might be in order? Would that resolve a regular web connection via media browser?
2 I'm getting some weird playlist issues. The log keeps referencing a folder/mount point that has never existed. Very odd.
2013-10-20 13:10:48,794 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2013-10-20 13:10:48,831 DEBUG [PlaylistMaintainerThread] Playlist Hey, Soul Sister has unresolved items, checking if they are in the library now
2013-10-20 13:10:48,863 DEBUG [PlaylistMaintainerThread] Found playlist item that has not been added yet: /Volumes/Big Disk/Media/Music/Train/Save Me, San Fancisco/02 Hey, Soul Sister.mp3
2013-10-20 13:10:48,914 DEBUG [PlaylistMaintainerThread] Item '/Volumes/Big Disk/Media/Music/Train/Save Me, San Fancisco/02 Hey, Soul Sister.mp3' cannot be resolved to an entity in the Serviio library, will try again later
2013-10-20 13:10:48,915 DEBUG [PlaylistMaintainerThread] Found playlist item that has not been added yet: /Volumes/Big Disk/Media/Music/John Mayer/Continuum/08 Slow Dancing In A Burning Room.mp3
2013-10-20 13:10:48,915 DEBUG [PlaylistMaintainerThread] Item '/Volumes/Big Disk/Media/Music/John Mayer/Continuum/08 Slow Dancing In A Burning Room.mp3' cannot be resolved to an entity in the Serviio library, will try again later
2013-10-20 13:10:48,916 DEBUG [PlaylistMaintainerThread] Found playlist item that has not been added yet: /Volumes/Big Disk/Media/Music/Iron & Wine/The Shepherd's Dog/12 Flightless Bird, American Mouth.mp3
2013-10-20 13:10:48,916 DEBUG [PlaylistMaintainerThread] Item '/Volumes/Big Disk/Media/Music/Iron & Wine/The Shepherd's Dog/12 Flightless Bird, American Mouth.mp3' cannot be resolved to an entity in the Serviio library, will try again later
3 As far as I can tell, network access is just fine, but I keep getting these errors:
2013-10-20 13:10:25,732 WARN  [PortMapper] Could not find a router on the network. Autodiscovery (UPnP/NAP PMP) might be disabled or the router is not currently supported.
Post Mon Oct 21, 2013 7:52 pm
Re: Maxing CPU, rogue playlist, and no gateway!?!?!
2) what is the contents of playlist Hey, Soul Sister ?
3) That is a case of being unable to open MediaBrowser ports on your router automatically via UPnP. Either the router doesn't support it, you disabled it, or the router is not supported by Serviio
sleky
Post Mon Oct 21, 2013 8:11 pm
2Thats just it, I don't have a playlist. Anywhere, at all.
3I'm curious what the router needs to open for this to work. I have an ASA, I'll turn up the logging and maybe I can intercept something, but... What specifically is it trying to configure?
Post Tue Oct 22, 2013 12:26 pm
Re: Maxing CPU, rogue playlist, and no router
trying to use UPnP to open / forward the 23424 ports of MediaBrowser (so that you can use it via internet). This is only attempted if you enable the option in the console (Remote tab)
Post Tue Oct 22, 2013 12:27 pm
sleky
Post Tue Oct 22, 2013 4:51 pm
Ah. So I can setup everything per normal (using firewall rules) I know I can reduce that URL externally and forward port 80 to appropriate ports. Disabling that box should just kill that warning? Thats an easy fix. For the router message.
Still unclear as to the issue regarding the playlist. Is it possible an old plugin or something saved that string in my DB? Would purging the DB clear that do you think? Where are the playlists information stored?
Users browsing this forum: Google [Bot] and 33 guests
