Series D&E file sorting
shmulikgazit
Post Wed Oct 23, 2013 7:22 pm
Hi!
I have a D6000 and an E5300 TV. The "Last added"/"Last Viewed" are sorted by newest first on the D series TV while on the E one, the files (Video) are sorted alphabetically.
I saw a post here that explained that it is up to the renderer, but I'm pretty sure that at some point, the sort on the E series TV was also newest first for a few days and I can't figure out how it changed and changed back.
If there is a trick that can be done by making a copy of the profile and changing something for the E series TV, that will also be a viable option (if the order that is shown on the E series TV is the order by which serviio sends them).
Thanks very much for serviio. Will definitely buy it to show my appreciation.
/Shmulik.
Post Sun Nov 10, 2013 6:46 pm
Re: Series D&E file sorting
It is renderer responsibility. It might have worked for a bit, but a TV firmware update might have broken it.
