Exception in thread "main" java.lang.NoClassDefFoundError
scanf
Post Tue Oct 22, 2013 1:03 pm
While trying this out on a Linux box, I have the following error:
Exception in thread "main" java.lang.NoClassDefFoundError: org/restlet/service/StatusService
I also set
export SERVIIO_HOME=/usr/local/serviio-1.3.1
but it doesn't matter. Here is a full -x
++ dirname /usr/local/serviio-1.3.1/bin/serviio.sh
+ DIRNAME=/usr/local/serviio-1.3.1/bin
++ basename /usr/local/serviio-1.3.1/bin/serviio.sh
+ PROGNAME=serviio.sh
+ cygwin=false
+ darwin=false
+ linux=false
+ case "`uname`" in
++ uname
+ linux=true
+ false
+ '[' x/usr/local/serviio-1.3.1 = x ']'
+ export SERVIIO_HOME
+ '[' x = x ']'
+ '[' x/usr/lib/jvm/java-6-sun-1.6.0.26 '!=' x ']'
+ JAVA=/usr/lib/jvm/java-6-sun-1.6.0.26/bin/java
+ SERVIIO_CLASS_PATH='/usr/local/serviio-1.3.1/lib/*:/usr/local/serviio-1.3.1/config'
+ JAVA_OPTS='-Djava.net.preferIPv4Stack=true -Djava.awt.headless=true -Dderby.system.home=/usr/local/serviio-1.3.1/library -Dserviio.home=/usr/local/serviio-1.3.1'
+ false
+ /usr/lib/jvm/java-6-sun-1.6.0.26/bin/java -Xmx512M -Xms20M -XX:+UseParNewGC -XX:MinHeapFreeRatio=10 -XX:MaxHeapFreeRatio=20 -Djava.net.preferIPv4Stack=true -Djava.awt.headless=true -Dderby.system.home=/usr/local/serviio-1.3.1/library -Dserviio.home=/usr/local/serviio-1.3.1 -classpath '/usr/local/serviio-1.3.1/lib/*:/usr/local/serviio-1.3.1/config' org.serviio.MediaServer
at org.serviio.MediaServer.main(MediaServer.java:112)
Caused by: java.lang.ClassNotFoundException: org.restlet.service.StatusService
at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
... 1 more
Looks like the Linux Serviio 1.31 is missing jar files for the Restlet toolkit they use? Please advise.
Post Tue Oct 22, 2013 10:27 pm
Re: Exception in thread "main" java.lang.NoClassDefFoundErro
The jar files are there. It might be the Linux java doesn't work properly with the * class path notation, so you might have to add all the jar files to the class path list.
scanf
Post Fri Oct 25, 2013 10:43 am
Wouldn't be my first thought, as CLASSPATH wildcards are equally supported under Windows and Linux:
http://docs.oracle.com/javase/7/docs/technotes/tools/solaris/classpath.html
Anyway as you suggest:
+ cygwin=false
+ darwin=false
+ linux=false
+ case "`uname`" in
++ uname
+ linux=true
+ false
+ '[' x = x ']'
+ SERVIIO_CLASS_PATH=/usr/local/serviio-1.3.1/lib/commons-io.jar:/usr/local/serviio-1.3.1/lib/concurrent.jar:/usr/local/serviio-1.3.1/lib/derby.jar:/usr/local/serviio-1.3.1/lib/freemarker.jar:/usr/local/serviio-1.3.1/lib/gson.jar:/usr/local/serviio-1.3.1/lib/jaudiotagger.jar:/usr/local/serviio-1.3.1/lib/jcl-over-slf4j.jar:/usr/local/serviio-1.3.1/lib/jcs.jar:/usr/local/serviio-1.3.1/lib/jdom.jar:/usr/local/serviio-1.3.1/lib/jul-to-slf4j.jar:/usr/local/serviio-1.3.1/lib/log4j.jar:/usr/local/serviio-1.3.1/lib/org.restlet.ext.net.jar:/usr/local/serviio-1.3.1/lib/org.restlet.ext.xstream.jar:/usr/local/serviio-1.3.1/lib/rome.jar:/usr/local/serviio-1.3.1/lib/rome-modules.jar:/usr/local/serviio-1.3.1/lib/serviio-client.jar:/usr/local/serviio-1.3.1/lib/serviio.jar:/usr/local/serviio-1.3.1/lib/serviio-media-browser.jar:/usr/local/serviio-1.3.1/lib/slf4j-api.jar:/usr/local/serviio-1.3.1/lib/slf4j-log4j12.jar:/usr/local/serviio-1.3.1/lib/xstream.jar:/usr/local/serviio-1.3.1/config
+ false
+ /usr/lib/jvm/java-6-sun-1.6.0.26/bin/java -classpath /usr/local/serviio-1.3.1/lib/commons-io.jar:/usr/local/serviio-1.3.1/lib/concurrent.jar:/usr/local/serviio-1.3.1/lib/derby.jar:/usr/local/serviio-1.3.1/lib/freemarker.jar:/usr/local/serviio-1.3.1/lib/gson.jar:/usr/local/serviio-1.3.1/lib/jaudiotagger.jar:/usr/local/serviio-1.3.1/lib/jcl-over-slf4j.jar:/usr/local/serviio-1.3.1/lib/jcs.jar:/usr/local/serviio-1.3.1/lib/jdom.jar:/usr/local/serviio-1.3.1/lib/jul-to-slf4j.jar:/usr/local/serviio-1.3.1/lib/log4j.jar:/usr/local/serviio-1.3.1/lib/org.restlet.ext.net.jar:/usr/local/serviio-1.3.1/lib/org.restlet.ext.xstream.jar:/usr/local/serviio-1.3.1/lib/rome.jar:/usr/local/serviio-1.3.1/lib/rome-modules.jar:/usr/local/serviio-1.3.1/lib/serviio-client.jar:/usr/local/serviio-1.3.1/lib/serviio.jar:/usr/local/serviio-1.3.1/lib/serviio-media-browser.jar:/usr/local/serviio-1.3.1/lib/slf4j-api.jar:/usr/local/serviio-1.3.1/lib/slf4j-log4j12.jar:/usr/local/serviio-1.3.1/lib/xstream.jar:/usr/local/serviio-1.3.1/config -Xmx512M -Xms20M -XX:+UseParNewGC -XX:MinHeapFreeRatio=10 -XX:MaxHeapFreeRatio=20 -Djava.net.preferIPv4Stack=true -Djava.awt.headless=true -Dderby.system.home=/usr/local/serviio-1.3.1/library -Dserviio.home=/usr/local/serviio-1.3.1 org.serviio.MediaServer
... 1 more
Post Fri Oct 25, 2013 3:50 pm
Looks like the restlet jar (org.restlet.jar) is missing on your classpath. I just tried to download the Linux bundle and it's there
zachofalltrades
Post Fri Oct 25, 2013 4:09 pm
@scanf
Wildcard support for classpath entries was introduced with Java6.You probably have an earlier version of Java that is getting used in place of Java6. If multiple versions of Java are present, the best way to ensure that the correct version is used is to fully specify the path to the java binary when launching the application rather than just calling "java ___".
